ZJ won't shift out of 1st gear when in 4WD Low. - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > ZJ won't shift out of 1st gear when in 4WD Low.
FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire
Unread 07-14-2013, 08:59 PM   #16
oldZJdog95018
Originally Posted by ZJfamilyfun View Post
Try manually shifting the gears. Start in 1, then shift it to 2, then D. See if that makes a difference.
I gave the manual shifting a shot and it just stays in first regardless. I miss have having all my gears on the trail... seriously, right now when it's 4wd low you could outrun my jeep on foot
oldZJdog95018 is offline   Reply With Quote Quick reply to this message
Unread 07-20-2013, 07:44 PM   #17
oldZJdog95018
Thanks to 96zedjay, problem solved
Replaced the TSS sensor for $16.95 & not only does it shift all the way through the gears in 4WD Low, but it shifts like it has a new transmission in 2WD High as well. I checked my OBDII codes this morning, before I changed out my TSS & it had a P0720 code (output shaft speed sensor failure). No check engine light with this code by the way. I cleared the code & replaced the sensor and everything seems to be working fine now.
Unread 07-20-2013, 09:48 PM   #18
96zedjay
Glad to be of service.
96zedjay is offline   Reply With Quote Quick reply to this message
