ZJ/WJ specifications thread - DRAFT - JeepForum.com
post #1 of 7 Old 05-07-2004, 09:20 PM Thread Starter
cfkingfish
cfkingfish's Avatar
Here it is: NOTE - there may be some discrepancies, Im a little tired, so let me know if I put down the wrong info.
Welcome to the Jeep ZJ/WJ sticky thread. Thanks to all that helped, I hope this provides a guide to all that have technical questions.
When in doubt, you can always get a build sheet for your Jeep specifically from DC by giving them your VIN.
ZJ/WJ trim models, listed from lowest priced to highest.
1993- Base, Laredo, Grand Wagoneer, Limited,
1994- SE, Laredo, Limited
1995- SE, Laredo, Limited, Orvis Limited
1996- Laredo, Limited
1997- Laredo, Tsi, Limited
1998- Laredo, Tsi, Limited, 5.9 Limited
1999- Laredo, Limited
2000- Laredo, Limited
2001- Laredo, Limited
2002- Sport, Laredo, Special Edition, Limited, Overland
2003- Laredo, Limited, Overland
2004- Laredo, Special Edition, Columbia/Freedom Edition, Limited, Overland
Updates:
1994 - Limited gets rear disc brakes instead of drums used on all 1993, and 1994 Laredo Models
1995- 2WD is offered in Limited trim, disc brakes for all trim models
1996- 2WD is offered in both Laredo and Limited, 6 and 8 cylinder models
1999- 4.7 Liter V8 takes over the 5.2 V8 spot
2002- Quadra-Drive is offered as an AWD system - 4.7 gets limited production High-Output (HO) version
Jeep ZJ Produced from 1993-1995
Exterior Dimensions:Length:
176.7 in. Width: 69.2 in.
Height: 64.9 in. Wheel Base: 105.9 in.
Ground Clearance: 8.2 in. Curb Weight: 3574 lbs
Interior Dimensions:
Front Head Room: 39 in. Front Hip Room: 56.9 in.
Front Shoulder Room: 58.2 in. Rear Head Room: 39 in.
Rear Shoulder Room: 57.6 in. Rear Hip Room: 49.3 in.
Front Leg Room: 40.8 in. Rear Leg Room: 35.7 in.
Luggage Capacity: 40.1 cu. ft. Maximum Cargo Capacity: 80 cu. ft.
Maximum Seating: 5
Performance:
Performance
Base Number of Cylinders: 6 Base Engine Size: 4 liters
Base Engine Type: Inline 6 Horsepower: 190 hp
Max Horsepower: 4750 rpm Torque: 225 ft-lbs.
Max Torque: 4000 rpm Maximum Payload: 1150 lbs.
Maximum Towing Capacity: 5000 lbs. Drive Type: RWD
Turning Circle: 36.6 ft.
Optional Engine - 5.2 MPI V8 (MPI stands for Multi-Port Injection)
Horsepower:220
Fuel Tank Capacity: 23 gal.
EPA Mileage Estimates: (City/Highway) for 6cyl
Manual: 16 mpg / 21 mpg Automatic: : 15 mpg / 20 mpg
Range in Miles: (City/Highway)
Automatic: 345 mi. / 460 mi. Manual: 368 mi. / 483 mi.
1996-98 ZJ Dimension changes - (If not shown, it did not change)
Exterior:
Length: 177.2 in. Width: 69.3 in.
Ground Clearance: 7.7 in. Curb Weight: 3926 lbs.
Interior:
Front Head Room: 38.9 in. Front Hip Room: 56.7 in.
Front Shoulder Room: 59.2 in. Rear Head Room: 39 in.
Front Leg Room: 40.9 in. Rear Leg Room: 35.7 in.
Luggage Capacity: 40.9 cu. ft. Maximum Cargo Capacity: 79 cu. ft.
Maximum Seating: 5
Performance Data
Performance for 6 cyl
Acceleration (0-60 mph): 8.6 sec. Braking Distance: 138 ft.
Road Holding Index: .75 g Base Number of Cylinders: 6
Base Engine Size: 4 liters Base Engine Type: Inline 6
Horsepower: 185 hp Max Horsepower: 4600 rpm
Torque: 220 ft-lbs. Max Torque: 2400 rpm
Maximum Payload: 1150 lbs. Turning Circle: 37.5 ft.
1998 5.9 Limited Performance:
Performance
Acceleration (0-60 mph): 7.1 sec. Braking Distance: 135 ft.
Road Holding Index: .75 g Base Number of Cylinders: 8
Base Engine Size: 5.9 liters Base Engine Type: V8
Horsepower: 245 hp Max Horsepower: 4000 rpm
Torque: 345 ft-lbs. Max Torque: 3200 rpm
Maximum Payload: 1150 lbs. Maximum Towing Capacity: 5000 lbs.
Drive Type: 4WD Turning Circle: 37.2 ft.
Fuel Data
Fuel
Automatic: : 13 mpg / 16 mpg
Automatic: 299 mi. / 368 mi.
1999-2004 Grand Cherokee - the WJ
Exterior
Length: 181.5 in. Width: 72.3 in.
Height: 69.4 in. Wheel Base: 105.9 in.
Ground Clearance: 9.1 in. Curb Weight: 3879 lbs.
Interior
Front Head Room: 39.7 in. Front Shoulder Room: 58.9 in.
Rear Head Room: 39.5 in. Rear Shoulder Room: 57.8 in.
Front Leg Room: 41.4 in. Rear Leg Room: 35.3 in.
Luggage Capacity: 39 cu. ft. Maximum Cargo Capacity: 72 cu. ft.
Maximum Seating: 5
Performance
Acceleration (0-60 mph): 9.1 sec. Braking Distance: 145 ft.
Road Holding Index: .73 g Base Number of Cylinders: 6
Horsepower: 195 hp Max Horsepower: 4600 rpm
Torque: 230 ft-lbs. Max Torque: 2400 rpm
Maximum Towing Capacity: 2000 lbs. Optional 5000 lbs with Tow package
Optional Engine: 4.7 "Power-Tech Engine" 16-valve
Horsepower: 235 @ 4800 rpm
Torque: 295 ft/lbs @ 3200 rpm
Fuel Data
Fuel
Fuel Tank Capacity: 20.5 gal.
Automatic: : 16 mpg / 21 mpg
Automatic: 328 mi. / 430.5 mi.
Axles:
Front: Dana 30 used in all ZJs and WJs 3.55:1 final drive ratio
Rear: Dana 35 c-clip used in all ZJs and WJs. 3.55:1 final drive ratio
Towing package was an option, which had a Dana 44A (this stands for aluminum), it has an aluminum center section) with 3.73 gears with limited slip.
T-cases:
NP242 used on I6 ZJs and WJs - This is known as SelecTrac
NP249 used on all V8 ZJs and WJs, and was optional on 6 cylinder models - This is known as QuadraTrac.
2002 - Quadra-Trac II introduced as option on V8s- known as Quadra-Drive, this is an AWD system similar to Audis and Subarus.
Christian
89 XJ 4.0 AW4
K&N 6x9 cone filter setup
Converted to TJ axles - 5-297 U-joints
Optima Red Top
Custom exhaust
www.ishopfaulkner.com
cfkingfish is offline
post #2 of 7 Old 05-07-2004, 09:21 PM Thread Starter
cfkingfish
cfkingfish's Avatar
Feel free to give any feedback on this, let me know what to add/drop.
Christian
89 XJ 4.0 AW4
Optima Red Top
Custom exhaust
post #3 of 7 Old 05-07-2004, 10:36 PM
Meerkat
Looking pretty darn good!
Other than a couple typos, here is some information you might want:
The NP231 has an aluminum case and it should have a tag on the back saying New Process Gear, Model 231. New versions of the NP231 are refered to as NVG231 or NV231 which stands for New Venture Gear. The tag on the back of the transfer case will reflect the name change. Only the name is different. A NV231 HD model is used in some ZJs. Presumably this is a "heavy duty" version for Jeeps with the big V8s.
Usage
Since 1988, the NP231 has been the "Command Trac" transfer case used in Cherokees (XJ), Comanches (MJ), and Wranglers (YJ). It has been the "Command Trac" transfer case in the Grand Cherokee (ZJ) since its introduction.
Also, I believe the 5.9L was available starting in 2002 for the Overland.
HTH
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline
post #4 of 7 Old 05-07-2004, 11:07 PM Thread Starter
cfkingfish
cfkingfish's Avatar
Thanks for the feedback, I made a few corrections. I just want to get some sort of confirmation from Moabster that he can make this sticky for us. How about it?
-Christian
Christian
89 XJ 4.0 AW4
Optima Red Top
Custom exhaust
post #5 of 7 Old 05-08-2004, 02:06 AM
demtjcj
looks good and also a good idea. i would add, under the updates, where you listed engines changes about the 5.9 being available only in 98. i know you mentioned it later but thought it should go there too
dan
2004- Wrangler X stock
1977 full size cherokee-401 v8, quadratrac dana 44s
prev. jeeps: 98TJ on 33s, 00TJ on 35s, 01TJ on 35s, 78CJ on 31s, 85XJ stock, 94ZJ stock, 97 TJ on 35s, 03 on 35s, 93 GC on 33s
demtjcj is offline
post #6 of 7 Old 05-08-2004, 08:59 AM Thread Starter
cfkingfish
cfkingfish's Avatar
I went ahead and put that in. Im going to PM Moabster and see if he will make it sticky, after I give him the final draft.
-Christian
Christian
89 XJ 4.0 AW4
Optima Red Top
Custom exhaust
post #7 of 7 Old 05-08-2004, 12:43 PM
iroc22
iroc22's Avatar
93-94 V8 ZJ's could have the NP242 Selec-Trac t-case.
Also in 93-94 (not sure about 95) NP231 Command Trac was available with the I6's in SE's and Laredo's.
The Dana44A was introduced on V8 models (mandatory) midway through the 95 model year. The Dana 35C was available with a 3.73 ratio and LSD with the tow package previous to that, or with I6's after 95.
2002 Jeep TJ Sport 4.0L Patriot Blue/Black Hardtop Dana 44
1996 Jeep ZJ Orvis fully loaded
1995 Pontiac Trans Am 5.7L - 6 speed
1928 Ford Model A - Street Rod Project
iroc22 is offline
Specifications grwhite ZJ Grand Cherokee Forum 7 06-10-2006 08:51 PM
Cold draft coming in on passenger side lrickley ZJ Grand Cherokee Forum 0 01-28-2005 02:50 PM
Finding Vehicle Specifications Storml2age ZJ Grand Cherokee Forum 4 06-30-2003 11:13 PM
specifications trailboy ZJ Grand Cherokee Forum 2 03-13-2003 07:00 AM
JEEP Specifications? CLB ZJ Grand Cherokee Forum 1 12-14-2002 03:09 PM
