Zj wheelspacers. - JeepForum.com
post #1 of 3 Old 02-01-2013, 09:45 AM Thread Starter
johnldayii
Zj wheelspacers.
I have a 98 5.9, I have had a two inch rubi express 2 inch spacer lift and now it's time for new tires. If i were to add a wheel spacer as well would I be able to install larger tires?
johnldayii is offline
post #2 of 3 Old 02-01-2013, 09:47 AM
WhiteOut
WhiteOut's Avatar
Best size for you would be a 31x10.5 on the stock rims. They will fit well with the lift you have but may rub the control arms a bit at full lock. Adding wheel spacers will push the wheels out a bit (decrease backspacing) and allow the to clear and give it a bit wider stance.
WhiteOut is offline
post #3 of 3 Old 02-01-2013, 10:23 AM
lil_joe
Yes, you might have to trim depending on how much larger you go
Mike
____
lJeepl
--[.]IIIII[.]
Obsession is a word the lazy use to describe the dedicated
HER's: 92 YJ 4" RC 1.5 RC Booms, 1" BL on 33's
MINE's: 97 ZJ 5.2 Upcountry Limited Project 2" RE BB on 265/75 Mud Dogs, Locked front LSD rear, 242 swapped T-Case, RC Quick Disco's
lil_joe is offline
