ZJ Washer Fluid Reservoir in place of a WJ's - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > ZJ Washer Fluid Reservoir in place of a WJ's
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 09-27-2006, 09:33 PM   #1
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Ok if you anybody who's anybody (ie you have lifted your WJ 4"+) then you have ripped out your washer fluid pumps & sensors. Leaving you with a reservoir that leaks as fast as you can fill it
Forunantly if you have a WJ you're in luck of an easy swap! Unfortunantly to compensate for the I6 missing two cylinders god only allows this to work on I6's. V8's have a different air filter configuration so it won't fit. The second catch is that you need a K&N intake to make this fit - as this goes where the stock airbox was.
What you need:
1) ZJ Washer Fluid Reservoir (with or without sensors & pumps).
2) Pumps from either the WJ or ZJ.
3) Sensor from either the WJ or ZJ.
The pumps and sensors are interchangable, however the WJ pumps are by far superior (read larger and we all know bigger = better):
ZJ pumps in the back, WJ pumps in the middle, and ZJ float fluid sensor in the front:
When I ripped out my connections from my stock reservoir I lost my sensor - it is somewhere in Moab on the Hells Revenge trail. So I am using the WJ Pumps with the ZJ sensor.
This is a pic of the sensor with the outside of the connector dremmeled off so I could solder directly to the pins. Since the ZJ and WJ use different connectors it isn't just plug and play.
FYI: Each connector, pump, and sensor can only plug into the connection. From left to right we have the Rear Pump, Front Pump, and the Sensor:
I snipped off my sensors connector (viewable on the bottom of the pic) and hardwired it to the sensor (solder it if you want it to last) I then drilled some holes in the engine compartment frame and ziptied the bottle to the "frame". WALA it works!
At this point I had cleaned up my garage and went to close my hood. Ahhhh crap, it is toooooo tall!!!
So out with the dremmel to cut a notch so it can sit lower:
Before:
After:
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline   Reply With Quote Quick reply to this message
Unread 09-27-2006, 09:34 PM   #2
ArloGuthroJeep
Mr. Hyde!
Other mics pics if ya want more "info pics": http://www.arlojeep.com/Misc-Pics/ZJ...er-Fluid-Tank/
Unread 09-27-2006, 09:54 PM   #3
ArloGuthroJeep
Mr. Hyde!
The Dentist did his differently: http://www.jeepforum.com/forum/f13/relocating-wiper-fluid-resevior-wj-319077/
And 10achik (Ken) did his ghetto fab: http://www.jeepforum.com/forum/f13/windshield-wiper-reservoir-302921/
Unread 09-27-2006, 10:20 PM   #4
BlaineWasHere
BecauseRacecar
BlaineWasHere's Avatar
I can't wait untill I have to takle this! Any reason why eveyone uses the ZJ bot? What about just cutting the bottom of the WJ bot and getting that part of it out of the way. Yea less washer fluid but whatever.
It will be a fun winter project to get ready for spring wheeling.
2013 FR-S
BlaineWasHere is offline   Reply With Quote Quick reply to this message
Unread 09-27-2006, 11:30 PM   #5
ArloGuthroJeep
Mr. Hyde!
The ZJ bottle fits in there near perfectly...just easy to use it. I question whether the WJ bottle could be fitted with a single cut and not have to piece together 10 different cuts...
I would certainly do this before winter if you have it ripped out already...
The ZJ tank is already about half the size of the WJ's...the WJ's fits over a gallon. I remember my old ZJ not even fitting a gallon
Unread 09-27-2006, 11:34 PM   #6
FlashLCD33
Bump for me selling that tank to him only to get hacked up
'93 Grand Cherokee Larado 4.0l - 4wd - Wrecked.
FlashLCD33 is offline   Reply With Quote Quick reply to this message
Unread 09-28-2006, 12:30 AM   #7
FearTheDentist
Just a suggestion...
FearTheDentist's Avatar
The WJ bottle is a really odd, assymetrical shape, where the ZJ bottle is nearly rectangular and the mounting tabs are even (IIRC the WJ bottle's tabs are offset)-this makes it much easier to mount.
'04 4.7 WJ 6" Clayton's, full width 60\14b, 37" Nitto mud grapplers, lots of bits and pieces
FearTheDentist is offline   Reply With Quote Quick reply to this message
Unread 09-28-2006, 01:04 AM   #8
10achik
I ate what?
10achik's Avatar
Well Arlo, I can't call you a copy cat because once again someone has found a way to mount it that wasn't ghetto fabulous
Looks great, nice install.
Ken
99 GC Limited - 4.7L HO V8, 6.5" IRO HC LA lift, F&R D44s locked & trussed, 242HD, IRO TC Skid, KMA Bumper, 35's
2006 Saturn Redline -2.0L Eaton supercharged I4, GMPP Stage 2, Custom Tune, AEM CAI, Ebiach Pro Kit w/ swaybars, EVO Ventus V12s (13.76 @ 103.85)
2006 Pontiac G6 GTP
2012 Nissan Juke - (hers)
2000 SV650 - naked, integrated tail light, sliders, corbin, pilot roads, RK chain & sprokets, D&D full exhaust, FactoryPro Stage I jet kit, +4 Ignition Advancer, Barnett race clutch
2006 Triumph America 900 - Full Dresser
January 2009 Grand Cherokee of the Month (GCOTM)
10achik is offline   Reply With Quote Quick reply to this message
Unread 09-28-2006, 07:16 AM   #9
BlaineWasHere
BecauseRacecar
What about a bottle from a whole different rig? AS in XJ, TJ or even a non Jeep bottle.
2013 FR-S
Unread 09-28-2006, 08:15 AM   #10
ArloGuthroJeep
Mr. Hyde!
A non-Jeep model!?!?!?! I'll pretend I didn't hear that.
Never looked at any other models washer fluid bottle...Normally when I see a new vehicle I don't say "Hey, pop your hood, I want to see your washer fluid reservoir!"
Unread 09-28-2006, 06:39 PM   #11
10achik
I ate what?
10achik's Avatar
Blaine, I went out ot ebay and did a search for windshield washer reservior and it came back with all makes and models, I knew about the space I had to play with and in the end it was the ZJ one that made the most sense. I'm sure there's something that would roks, but good luck finding it.
Ken
2006 Pontiac G6 GTP
Unread 09-28-2006, 06:41 PM   #12
ArloGuthroJeep
Mr. Hyde!
I thought about making my own with plating (possibly copper) and solder but got lazy when FlashLCD started to part out his other Jeep...
Unread 09-28-2006, 07:26 PM   #13
EMTimZJ
GSMW!
EMTimZJ's Avatar
1994 ZJ
Hey nice write up! I'm digging this nice WJ tech that is starting to flow! It is not a real project unless you have to cut something
-Tim GS-MW 2009 INFO
KD8EBC
'94 ZJ 5.2 LTD
Project TORTOISE Build-up thread
JCR Rock Sliders Ford Taurus E-fan Install Dana 20 Twin Stick
EMTimZJ is offline   Reply With Quote Quick reply to this message
Unread 09-28-2006, 07:53 PM   #14
ArloGuthroJeep
Mr. Hyde!
If you want more tech from me give me money!
Unread 09-28-2006, 11:20 PM   #15
EMTimZJ
GSMW!
EMTimZJ's Avatar
1994 ZJ
I will give you (1) one dollar (USD). No really, I will.
... but you will have to wait until I make it to CO and you show me some nice trails
KD8EBC
'94 ZJ 5.2 LTD
