ZJ vs WJ transfer case - JeepForum.com
post #1 of 46 Old 06-24-2007, 05:14 PM Thread Starter
Astrodokk
Location: Sonoma County, an hour north of San Francisco in wine country.
I went looking for a WJ for my son and was told by the salesperson that the WJ TC that is 4WD all time is the same as the 249 in the ZJ. I know the ZJ tc's had vc probs and I'm surprised that they would use the same one in the WJ's. Is that true, or is the all time 4WD (Quadradrive I think) different than the 249TC on the ZJ's?
2000 Jeep WJ Grand Cherokee Limited, Black/Black, 4.7L
Astrodokk is offline
post #2 of 46 Old 06-24-2007, 05:18 PM
MuddyLuxury
MuddyLuxury's Avatar
Diffrent TC the WJ uses a 247... mine had 120ish on the clock when i pulled it for a 242 with no issues, but yes the VC may eventually wear out.. just outa curriosity... how old is your kid? and why are you getting him a V8?
MuddyLuxury is offline
post #3 of 46 Old 06-24-2007, 05:35 PM
Sporer65
Sporer65's Avatar
Location: Powder Springs, Georgia/University of Tennessee
Like said above, the WJ uses the 247. That transfer case uses a Progressive Coupler instead of a Viscous Coupler and should not burn out.
Ben
1993 Jeep Grand Wagoneer ZJ V8: Rear Aussie, 3.5" Lift, 31" M/Ts
Sporer65 is offline
post #4 of 46 Old 06-24-2007, 05:43 PM
10achik
I ate what?
10achik's Avatar
Yep PC > VC
Ken
99 GC Limited - 4.7L HO V8, 6.5" IRO HC LA lift, F&R D44s locked & trussed, 242HD, IRO TC Skid, KMA Bumper, 35's
2006 Saturn Redline -2.0L Eaton supercharged I4, GMPP Stage 2, Custom Tune, AEM CAI, Ebiach Pro Kit w/ swaybars, EVO Ventus V12s (13.76 @ 103.85)
2006 Pontiac G6 GTP
2012 Nissan Juke - (hers)
2000 SV650 - naked, integrated tail light, sliders, corbin, pilot roads, RK chain & sprokets, D&D full exhaust, FactoryPro Stage I jet kit, +4 Ignition Advancer, Barnett race clutch
2006 Triumph America 900 - Full Dresser
January 2009 Grand Cherokee of the Month (GCOTM)
10achik is offline
post #5 of 46 Old 06-25-2007, 06:43 AM
greco gixxer
greco gixxer's Avatar
I'm pretty sure that my 247 with the PC is cooked (as diagnosed by a local shop). I have a 242 on the way to replace it.
2000 Grand Cherokee Limited 4.0L
For Sale: 1999 Yamaha R6 track bike - 11k miles, clear title.
greco gixxer is offline
post #6 of 46 Old 06-25-2007, 06:44 AM
greco gixxer
I'm pretty sure that my 247 with the PC is cooked (as diagnosed by a local shop). Binding at full lock turn, and a clunking coming at 50-60 mph!? I have a 242 on the way to replace it.
post #7 of 46 Old 06-25-2007, 07:06 AM
mendelmax
With ZJ the coupler will wear out whatever you'll do. It's just a part that wears out, like tires for example. In WJ with proper maintenance, the PC will least for the whole vehicle life. But it demands proper maintenance. Drive a bit with low or improper oil, forget to change it at proper time etc, and you'll have to prepare your wallet.
POLISH JEEP OWNERS CLUB #11
Anyway, nothing will beat Suzuki :D
mendelmax is offline
post #8 of 46 Old 06-25-2007, 07:07 AM
UUJ1
The WJ's utilize 3 different T.C.'s. The 242 = Viscious Coupler(Select-Trac), The 247(Quadratrac-II)= Progressive Coupler, and The 249(Quadratrac)= Viscious Coupler.
Oh and... the Progressive Couplers DO burn out on the 247's, mine did and I had to replace it.
'99 4.7 WJ,
3" IRO/Addco rear sway bar/ 31x10.5 Pro Comp XMT's(Yes, I changed my mind and decided on these)/ Pro Comp Mountain Crawler soft 8's 15x7 w/3.75" BS
242 in my garage... still
UUJ1 is offline
post #9 of 46 Old 06-25-2007, 07:11 AM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
JEEP! what are you talking about? The 249 was never used in the WJ.
The WJ only uses the 242 and 247 TC's and if you're really special, the 147 (1-speed AWD TC - no 4-low).
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #10 of 46 Old 06-25-2007, 07:15 AM
UUJ1
My bad... I thought I had heard once that it was used. Oh well, two outta three ain't bad. Thanks for the correction. So if the Selec-Trac is the 242, and the 247 is the Quadra-TracII, what T.C. do they use for the Quadra-Trac?
'99 4.7 WJ,
UUJ1 is offline
post #11 of 46 Old 06-25-2007, 07:22 AM
ajmorell
ajmorell's Avatar
Quadra Trac and Quadra-Drive use the same t-case (247), Quadra-drive just has LS diffs front and rear, whereas QT doesn't
ajmorell is offline
post #12 of 46 Old 06-25-2007, 07:25 AM
UUJ1
God... I knew that too!
.........and it's Monday!
'99 4.7 WJ,
UUJ1 is offline
post #13 of 46 Old 06-25-2007, 07:59 AM
mendelmax
And, 242 doesn't have any automatic coupling, nor viscous, nor progressive. Simple, mechanical locking device.
If the PC was burned in your WJ it had to be badly maintained or got some serious failure or worked in very hard conditions. By design it should easily outlive the tranny
post #14 of 46 Old 06-25-2007, 08:08 AM
greco gixxer
Unfortunately I just purchased my vehicle and from the interior and exterior it looks spectacular, I would have hoped the maintenance reflected that as well. Oh well.. I kinda like the fact of have a select-trac setup and the 2wd should yield a few more mpg..
post #15 of 46 Old 06-25-2007, 08:12 AM
EMTimZJ
GSMW!
EMTimZJ's Avatar
1994 ZJ
2wd will not yield any significant gains in MPG. True story.
-Tim
KD8EBC
'94 ZJ 5.2 LTD
JCR Rock Sliders
EMTimZJ is offline
ZJ transfer case abregar ZJ Grand Cherokee Forum 8 09-08-2007 08:44 AM
Transfer Case Death-Mobile ZJ Grand Cherokee Forum 2 05-05-2007 11:12 PM
Transfer Case HELP!!! TheCompound ZJ Grand Cherokee Forum 3 04-30-2006 08:59 PM
transfer case bill9000 ZJ Grand Cherokee Forum 23 10-04-2005 09:53 PM
Transfer Case? cherokeevince12 ZJ Grand Cherokee Forum 1 09-22-2005 05:55 PM
