zj v8 swap - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > zj v8 swap
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 12-28-2014, 11:55 PM   #1
mxstar189
zj v8 swap
i have 97 with the 4.0 i'm in love with it and want to rip the motor out and go v8 but i want to go with a 360 from a van id go with a stand alone system for fuel management etc its the drive train im worried about like the tranny bolt pattern when i did the motor swap when i got it 40 to a 40 i noticed the tranny has an offset plate my question is will a 360 from a van mid 90s bolt to the tranny with the flywheel and such let me know what you think
mxstar189 is offline   Reply With Quote Quick reply to this message
Unread 12-29-2014, 12:16 AM   #2
kg6mov
kg6mov's Avatar
A V8 won't bolt up to the 4.0 trans. In either case the trans would **** itself the first launch.
Ideally you would pull a 46rh from a first gen V8 ZJ, that will give you a trans that can take the 360 and won't need a computer for control. A beefed up 44re might work, a jeep 46re would hold it but they're pretty rare as they only came in the niner.
A dodge tranny won't easily work as the starters are on the wrong side.
1996 ZJ Green Laredo V8, 2.5" OME and Bilsteins, 33's, Holes drilled in the roof.
kg6mov is offline   Reply With Quote Quick reply to this message
Unread 12-29-2014, 04:31 AM   #3
PolkaPower
You can build a 44RE way stronger than a stock 46,but what ever you can find that is readily available. Go over to www.thespeedfreaks.net. There is a ton if info on how to make your ZJ fast.
PolkaPower is online now   Reply With Quote Quick reply to this message
