Zj twerking problem miley fever - JeepForum.com
post #1 of 10 Old 04-04-2015, 04:36 PM Thread Starter
BudgetZJ
Aprox. 6" lift
33" tires
Front sway bar but no rear ( my main idea to what the problem will be )
Rear sway bar should i add extensions to it like in the front?
Like title says it shakes the rear like rocks side to side a lot. Not death wobble type of shaking but like boating not sure how to say it
Budget ZJ Topless 98 Grand Cherokee ZJ Check it out!
http://www.jeepforum.com/forum/f13/98-grand-cherokee-topless-project-2041409/
BudgetZJ is offline
post #2 of 10 Old 04-04-2015, 06:53 PM
chaZJones
install rear sway bar with extensions
96 ZJ 5.2L 156k
chaZJones is offline
post #3 of 10 Old 04-04-2015, 09:21 PM
firsttimeZJ13
Sounds almost like your track bar is letting the axle walk side to side. If its physically swaying, that's where I'd start.
1995 ZJ, 5.2L, NP249, stock suspension, e-fan, CAI, engine needs work!! Plan on lift and tires when money finds its way here...
firsttimeZJ13 is offline
post #4 of 10 Old 04-05-2015, 04:33 AM
Timo_90xj
Timo_90xj's Avatar
^- This. I would also add control arm bushings. Short arms or long arms?
Swaybar controls only body roll, has nothing to do with sideways motion.
***Under construction***
Timo_90xj is online now
post #5 of 10 Old 04-05-2015, 04:58 AM
PolkaPower
If shorts arms at that height I bet it chews through bushings in no time.
PolkaPower is online now
post #6 of 10 Old 04-05-2015, 09:53 PM Thread Starter
BudgetZJ
Ita not the axle shaking its the body
Car keeps going in a straight line even with it shaking like that
BudgetZJ is offline
post #7 of 10 Old 04-05-2015, 09:54 PM Thread Starter
BudgetZJ
Yea im already building long arms for it I'm waiting for tube to arrive
BudgetZJ is offline
post #8 of 10 Old 04-05-2015, 09:57 PM Thread Starter
BudgetZJ
Im gonna b installing dana44A in the rear so ill add the swaybar back it
Also long arms are being fabbed up so that will be changed cuz im not getting any downward flex
BudgetZJ is offline
post #9 of 10 Old 04-06-2015, 03:17 AM
Timo_90xj
Timo_90xj's Avatar
If the vehicle body really moves sideways and not rolling from side-to-side, it has to be because of the connection between unibody and axle -> trackbar or control arms. Trackbar does most of that work, so my main suspect would be trackbar.
If it is a fast "wobble"- kind of movement, it could be you have bent a wheel or axle shaft mounting flange. Have you looked at your side mirrors lately, how the rear wheels/ tires look like when the rear wobbles?
post #10 of 10 Old 04-06-2015, 08:47 AM Thread Starter
BudgetZJ
Originally Posted by Timo_90xj
If the vehicle body really moves sideways and not rolling from side-to-side, it has to be because of the connection between unibody and axle -> trackbar or control arms. Trackbar does most of that work, so my main suspect would be trackbar. If it is a fast "wobble"- kind of movement, it could be you have bent a wheel or axle shaft mounting flange. Have you looked at your side mirrors lately, how the rear wheels/ tires look like when the rear wobbles?
Thanks im gonna be puttin a dana 44 complete in so its gonna be replacing al the parts everyone has mentioned So i hopes it doesnt do it with new dif in
New dif complete disc to disc
New trckbar
And swaybar back in
Custom long arms got the new bushings
BudgetZJ is offline
