zj transmission problems - JeepForum.com
post #1 of 5 Old 05-25-2010, 12:54 PM Thread Starter
dyenasty16
I bought a 93 zj with 42re and the trans was rebuilt but messed up and I put 3 in it first a 97 and 96 and a 94. Also switched from allwheel to part time 4wd. It will run good at first then nit wil stop pull and grindin noises when changing into gears. Does anyone know what could be wrong?
dyenasty16 is offline
post #2 of 5 Old 05-27-2010, 06:50 PM Thread Starter
dyenasty16
bump bump bump
post #3 of 5 Old 05-27-2010, 07:23 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
You ever flush the cooler and remove the check valve?
ratmonkey is offline
post #4 of 5 Old 05-28-2010, 09:21 AM Thread Starter
dyenasty16
No I thought about puttin an aftermarket cooler. And what do I just move the check valve all together or just replace it. Would the transfer case swap have anything to do with it?
post #5 of 5 Old 06-02-2010, 12:27 PM Thread Starter
dyenasty16
I noticed after drivn when I pull the dip stick out its smoking any iddeas why
New Transmission problems jeffp2152 ZJ Grand Cherokee Forum 0 04-11-2010 02:35 PM
96 GC Transmission problems TowMaster ZJ Grand Cherokee Forum 2 12-29-2008 09:24 PM
transmission problems dex1 ZJ Grand Cherokee Forum 1 11-29-2008 10:21 PM
transmission problems dex1 WK Grand Cherokee & XK Commander Forum 1 11-29-2008 05:22 PM
Transmission problems Bob K ZJ Grand Cherokee Forum 2 08-29-2003 08:32 AM
