ZJ - transmission cooler line, I think - JeepForum.com
post #1 of 7 Old 05-28-2006, 01:06 AM Thread Starter
jeep_on
All right people, I need some help tonight.
I think my ZJís transmission cooler line is leaking. Well I donít think, I know it is. Itís a small pin hole in the line and its spraying fluid out at a pretty good rate while running. Not sure when it started doing this. Must have been some where between my buddyís place and mine. I noticed it when I was at a stop light, it turned green and when I stepped on the gas nothing happened until it revíed to about 1,300 and the tranny grabbed first.
I zipped into the nearest gas station and popped the hood and saw what I thought was motor oil at first. When I looked closer I saw it wasnít motor oil, it was transmission fluid. Grabbed a flash night I saw where it was spraying out from and it seems to be the cooler line.
Iím kinda SOL on another vehicle at the moment. The WJs on a road trip in Oregon, and the wifeís YJ has its top end apart. So what are my options at this moment? Can I just JB weld the thing temporarily until the dealer opens on Tuesday? Or will the PSI of the line blow that off? I really donít think a stop leak will fix this. And need to get this fixed now b/c I need my Jeep tomorrow and have no choice.
Ideas are very welcome.
- Ross
2006 Dodge RAM Laramie w/ 5.9L I6
2010 Volkswagen Jetta w/ TDI 2.0L I4
Waiting on a 2013 RHD JK Unlimited
Originally Posted by PM Thor View Post
Wait, you can't cross creeks up there? What the Hell is up with these Canadians?
jeep_on is offline
post #2 of 7 Old 05-28-2006, 01:26 AM
fasta76
They are low pressure Lines .. I had mine crack at the fitting so i just cut the line and used a fuel pressure hose clamp to clamp it down on the cooler end.. I herd that the lines are a problem with the little plastic clips. And its alot cheaper.. Hope this helps.
fasta76 is offline
post #3 of 7 Old 05-28-2006, 01:29 AM Thread Starter
jeep_on
Thats a good idea. I wonder if I can cut the line and use a small peace of fuel line and clamps to fix it?
jeep_on is offline
post #4 of 7 Old 05-28-2006, 01:36 AM
fasta76
i dont see why not! But you will need some way to splice them together.. Mine has been good now for over 10,000km
fasta76 is offline
post #5 of 7 Old 05-28-2006, 01:38 AM
fasta76
But make sure to use High pressure hose clamps cause the normal ones dont stay to well. I think they are hose clamps for fuel injection
fasta76 is offline
post #6 of 7 Old 05-28-2006, 01:47 AM Thread Starter
jeep_on
Well ****, I dont have any EFI clamps. Have some normal hose clamps around here.
Not sure if I can even cut the line either. Dont have any way of doing it, and getting to the line it self is a problem. So I think I'm gonna clean it real good and JB-Weld the hell out of it. Let it sit until moring and see what happens.
jeep_on is offline
post #7 of 7 Old 05-28-2006, 01:37 PM Thread Starter
jeep_on
Well, I got the line fixed / rigged with WB Weld. Hopefully it will hold until next week when I can go to the stealership and get a new line. Added 1 1/2qt of AFT+3 and it seems to drive fine and not slip any more.
I just love how stuff loves to break on a weekend, and not only a weekend but a holiday weekend at that.
jeep_on is offline
transmission cooler line Q@uestion rschuler ZJ Grand Cherokee Forum 18 05-04-2010 08:24 PM
transmission cooler line leak bigphil76 ZJ Grand Cherokee Forum 1 01-29-2010 11:43 AM
Transmission Cooler Line leaking... 1badjk WK Grand Cherokee & XK Commander Forum 3 10-25-2009 08:32 PM
Transmission Cooler Line Fitting Bricolage ZJ Grand Cherokee Forum 5 09-08-2009 09:44 AM
Transmission line cooler djdoug99 ZJ Grand Cherokee Forum 2 07-21-2007 09:50 AM
