ZJ Transmission - JeepForum.com
post #1 of 4 Old 02-10-2014, 10:10 AM Thread Starter
123fisherc
ZJ Transmission
Bought a ZJ for dirt cheap with intention of turning it into an offroader, transmission won't shift outa first gear and slips outa gear when engaged. I knew it when I bought it and I figure I will just have to replace the tranni but curious if there's anything else I should check before I shell out the cash. Prolly being too optimistic but a cheap fix would mean more money for tires, lift, winch and all the goodies
123fisherc is offline
post #2 of 4 Old 02-10-2014, 10:34 AM Thread Starter
123fisherc
also is anyone trying to get rid of a zj transmission and will any other tranni work?
post #3 of 4 Old 02-10-2014, 03:21 PM
shaban
Before you change the tranny, you can try the following things to get it to work (easiest to less easy):
- Check the transmission fluid level, park car on level surface, engine idling, tranny warm, in NEUTRAL (not park), only use ATF+4 to top-up.
- Drop the tranny pan, inspect pan bottom for shavings/chunks of metal etc. Anything more than grey powder is no good; replace the tranny filter, change the tranny oil (3-4 gallons required for full change, use ATF+4)
- Replace the governor solenoid and pressure sensor assembly, they're known to go bad and cause crappy shifting.
The best place to get a cheap ZJ tranny is a self-service junkyard, they go for about $150-200. You can also negotiate with them to organise a swap if the one you pull is no good.
No other trannies are an easy fit to a ZJ. AW-4 automatic from XJ and AX-15 manual from old ZJ are bolt-ins to 4.0 engine, but they all give grief with the electric side - permanent check engine light. Don't know about what bolts up to 5.2 engine.
shaban is offline
post #4 of 4 Old 02-10-2014, 04:27 PM
ZJNewbi3
When you have the pan off I would also re-adjust the bands.
Just trying to keep her goin'!!
ZJNewbi3 is offline
96 grand cherokee , zj
