-   -   ZJ Transmission (http://www.jeepforum.com/forum/f13/zj-transmission-2094889/)
123fisherc 02-10-2014 11:10 AM
ZJ Transmission
Bought a ZJ for dirt cheap with intention of turning it into an offroader, transmission won't shift outa first gear and slips outa gear when engaged. I knew it when I bought it and I figure I will just have to replace the tranni but curious if there's anything else I should check before I shell out the cash. Prolly being too optimistic but a cheap fix would mean more money for tires, lift, winch and all the goodies :2thumbsup:
123fisherc 02-10-2014 11:34 AM
also is anyone trying to get rid of a zj transmission and will any other tranni work?
shaban 02-10-2014 04:21 PM
Before you change the tranny, you can try the following things to get it to work (easiest to less easy):
- Check the transmission fluid level, park car on level surface, engine idling, tranny warm, in NEUTRAL (not park), only use ATF+4 to top-up.
- Drop the tranny pan, inspect pan bottom for shavings/chunks of metal etc. Anything more than grey powder is no good; replace the tranny filter, change the tranny oil (3-4 gallons required for full change, use ATF+4)
- Replace the governor solenoid and pressure sensor assembly, they're known to go bad and cause crappy shifting.
The best place to get a cheap ZJ tranny is a self-service junkyard, they go for about $150-200. You can also negotiate with them to organise a swap if the one you pull is no good.
No other trannies are an easy fit to a ZJ. AW-4 automatic from XJ and AX-15 manual from old ZJ are bolt-ins to 4.0 engine, but they all give grief with the electric side - permanent check engine light. Don't know about what bolts up to 5.2 engine.
ZJNewbi3 02-10-2014 05:27 PM
When you have the pan off I would also re-adjust the bands.
The time now is 05:52 PM.
