zj trans help - JeepForum.com
post #1 of 9 Old 06-24-2013, 08:05 AM Thread Starter
skip11and1
2013 MK Patriot
zj trans help
Long story short I'm getting a 94 4.0 grand 4x4 with a bad trans before I comitt to it what year trans will fit?
2013 Jeep Patriot 4x4 FD1 5spd
2004 R6 lowered, stretched, full exhaust, HIDs etc
2004 TJ Columbia package long armed w/ 33's (Sold)
2005 WK, v6 QT1 (girlfriends)
skip11and1 is offline
post #2 of 9 Old 06-24-2013, 08:24 AM Thread Starter
skip11and1
2013 MK Patriot
I just found out too that a 98 ZJ trans is in it and it comes with a spare 98. So I guess all that has to be done is shave down the output shaft?
post #3 of 9 Old 06-24-2013, 09:31 AM
ZJMatt
If the transmission in it is from a 98 it's probably not bad... just isn't shifting right because it's a 98 in a 94! They made a lot of small changes internally in the transmission, and a different year transmission won't shift properly. 1993 through a build date of 1/13/95 should work as long as it's a 42RE.
The "Mall Crawler" - 1998 ZJ Grand Cherokee 5.2 V8, 5.5" LongArms, 32s, 12000lb winch & more.
ZJMatt is offline
post #4 of 9 Old 06-24-2013, 12:42 PM Thread Starter
skip11and1
2013 MK Patriot
thanks,yea it seems like the trans is going to be an issue cause the cheapest around here I cound find one was like a grand so I think Im just going to pass on it
post #5 of 9 Old 06-24-2013, 12:50 PM
zjosh93
When I was looking for a JY trans for my 93 I kept getting "none here" or expensive quotes. Turns out that all the 93-95 42RE are interchangeable but they have different numbers in the JY computer. I ended up going to a yard and picking a 42RE and just saying "give me that one". Make sure you get the flywheel too.
I also got a quote of like $900 and they had to ship it in. The local Pick-N-Pull has about ten 42RE sitting out there for $150 each...
zjosh93 is offline
post #6 of 9 Old 06-24-2013, 12:54 PM
MTBlue
Also, if you have a 94 with a 98 transmission, you could have issues with the OBDI to OBDII switch. That could cause some goofiness with shifts, etc. as well.
-Evan
Dirt Deprived
MTBlue is offline
post #7 of 9 Old 06-25-2013, 06:22 PM
masonroxy
1994 ZJ
alls you have to do is get a solinoid kit ... about $150 with the update for a four pin harness ... the trans is the same man,..yours is a three pin ,no big deal and while its out its sooo easy , u tube it guy
masonroxy is offline
post #8 of 9 Old 06-26-2013, 02:14 AM
eagsc7
1994 ZJ
it may or may not be the 3 or 4 pin... 93-95 had Both...
eagsc7 is offline
post #9 of 9 Old 06-28-2013, 01:58 PM Thread Starter
skip11and1
2013 MK Patriot
i just didnt get it cause the amount of money I would have to invest it wasnt worth it. Im just gonna wait cause I really want to get back into a wrangler for my trail vehicle
