zj trailer wiring issue help - JeepForum.com
post #1 of 6 Old 08-14-2011, 10:30 PM Thread Starter
tbirdsc
I have a 96 zj that didn't come with a factory hitch or harness. I added the hitch and a 4 wire plug. No problems until today when i used a 7 prong adapter to haul a trailer. Everything worked for about 20 seconds and the trailer lights went dead and the left tail light on my jeep went out. Thought it was the bulb but its like it reset itself and the tail light worked again. Tried this 3 times, and each time trailer lights would work for 20 seconds and then go out. Any ideas would be much appreciated...
tbirdsc is offline
post #2 of 6 Old 08-15-2011, 03:32 PM Thread Starter
tbirdsc
btw found a pic of the harness i am using......did not hook up any other wire besides the white ground which i had temporarily stuck into the ground when connecting the 4 wire plugs together....would i have better luck with hooking the power and ground up?...i dont have a brake controller http://www.etrailer.com/Wiring/Tow-Ready/30717.html
tbirdsc is offline
post #3 of 6 Old 08-15-2011, 10:03 PM
jnicewan
Well, if it all works ok until you hook the trailer up, I would be looking at the wiring on the trailer. I dont know whats going on with the LH tail lamp though, are you sure it was only the LH tail lamp, since the LH and RH tail lamps are wired together?
jnicewan is offline
post #4 of 6 Old 08-15-2011, 10:42 PM
SAR-Swimmer
I'd agree, sounds like something going on with the trailer wiring, a short or ground somewhere?
SAR-Swimmer is offline
post #5 of 6 Old 08-25-2011, 11:30 AM Thread Starter
tbirdsc
No problem with the trailer. Decided to order the wiring kit from etrailer. Just installed yesterday and works great. Worth the price for such little effort. Thanks for the replies.
tbirdsc is offline
post #6 of 6 Old 08-25-2011, 04:11 PM
Katesdad
Katesdad's Avatar
Thats what I did painless!
Katesdad is offline
help please , lights , towing , trailer wiring
Trailer Wiring f-series ZJ Grand Cherokee Forum 9 01-21-2010 08:54 AM
HELP!!!!!!!!!!! Trailer Wiring W2001J ZJ Grand Cherokee Forum 10 08-21-2009 12:06 AM
1997 ZJ trailer wiring issue with rear lamps SnowLeopard ZJ Grand Cherokee Forum 17 06-24-2009 10:25 PM
trailer wiring brake light issue MACHJGC ZJ Grand Cherokee Forum 0 04-04-2009 08:51 PM
trailer wiring driabyor ZJ Grand Cherokee Forum 2 02-13-2005 06:43 PM
