ZJ Trailer Wiring - JeepForum.com
post #1 of 5 Old 12-05-2009, 11:11 PM Thread Starter
ZJ5point2GCL
ZJ Trailer Wiring
I am Picking up a hitch tomorrow, but i need help wiring it, my question is where are the wires at the back? as far as i can tell there are the proper wires under the dash for a brake controller. but how do i connect the 7 pin plug at the back? btw its only for very occasional towing, i ve got an f350 v10, and a cummins 2500 for the tow rigs, but still want this one to be ready. Thanks
ZJ5point2GCL is offline
post #2 of 5 Old 12-05-2009, 11:35 PM
StellaTheZJ
For a 1993 (to 1995), the wires to the back terminate in a plug inside the passenger side quarterpanel. You'll have to remove the interior panel and plug the optional tow harness into the vehicle harness just above the wheel well.
For a 96 and up, the optional tow harness plugs into the vehicle harness on the driver's side.
StellaTheZJ is offline
post #3 of 5 Old 12-06-2009, 01:13 AM Thread Starter
ZJ5point2GCL
Ok thanks, so it's a harness that I should probably get from the dealer/ wrecker? Or could I just tap into it and make my own harness / connector?
post #4 of 5 Old 12-06-2009, 03:39 PM
StellaTheZJ
I like making things, but in this case, pop into a dealer, a parts store, or the wreckers. The clips and relays attached to the harness would make it a hassle to replicate. I picked up mine from the wrecker, and it came with the plug for where it goes through the body. You'll also get to see where it's supposed to run. Spend your time on something more interesting!!
On the other hand, while you're in there, I tapped into the constant 12V line in the harness to put in a 12V power outlet in the cargo area. It runs through a 20A fuse, so it's nice for running an inverter or a cooler or something. Watch out though, as it's always powered, so it will kill the battery if you're running something with the engine off!
post #5 of 5 Old 12-06-2009, 05:15 PM Thread Starter
ZJ5point2GCL
ok thanks, thats a good idea, but i actually already put a 1500 watt inverter, using my wire going to the former amp (never replaced it when i sunk the jeep)
Trailer Wiring f-series ZJ Grand Cherokee Forum 9 01-21-2010 09:54 AM
08 CRD Trailer Wiring Robert J. yates WK Grand Cherokee & XK Commander Forum 10 07-09-2009 12:40 AM
Trailer wiring rustydailey ZJ Grand Cherokee Forum 5 06-01-2008 02:36 AM
97 ZJ trailer wiring ezrider327 ZJ Grand Cherokee Forum 10 10-30-2007 08:15 PM
GC trailer wiring redgrandcheroke ZJ Grand Cherokee Forum 1 03-20-2006 11:34 PM
