ZJ trailer wiring - JeepForum.com
post #1 of 26 Old 05-11-2003, 09:30 PM Thread Starter
foundryrat
ZJ trailer wiring
Anyone have an easy explanation for a Dunderhead as to how you wire up a 97 Grand Cherokee for trailer wiring if, it isn't pre-wired for the trailer package and being an owner too cheap to buy a kit that will take care of the problem. I believe one has to cut or splice one wire or something......
foundryrat is offline
post #2 of 26 Old 05-11-2003, 10:03 PM
Swamp Boy
Swamp Boy's Avatar
UHaul makes plug in kits for almost every vehicle.. Go to a local uhaul dealer and see if they have one..
Even a dunder head can plug things in.. HAHAAHA
Also I believe its White = ground
Brown = markerlights
Yellow= Left turn and stop
Green= R turn and stop
That should do you.. All you need is a test light or volt meter to find the turn and marker lights on your rig.. Easy enough..
PS use those squeeze on clamps that join one wire to the other without cutting .. They work great..
Good luck..
Just another soccer moms Grocery getter....
Swamp Boy is offline
post #3 of 26 Old 05-12-2003, 07:29 AM Thread Starter
foundryrat
Hers what I'm getting at
The ZJ already has a wiring harness(pigtail) hooked up to it....but it is a pigtail made for ZJ's that were pre-wired for the trailer package... so when he has a trailer hooked up and hits the brake pedal all sorts of weird things happen...... It was bought that way....
There is a way by splicing and, or, running a wire to make this harness work. I used to have it printed out but when I actually needed it, its gone. He doesn't want to spend $60 for the correct pigtail if he can simply cut,splice and run another wire...
Thanks
post #4 of 26 Old 05-12-2003, 10:36 AM
Swamp Boy
Swamp Boy's Avatar
Oh I get it now.. Why dont you just cut off the factory harness.. and wire on a flat 4 pin.. make sure you cut the wires off flush and use crimp on wire caps... Those damn 7 pin plugs are a pain in the ***..
IF somone knows how to fix them .. Help the man out...
post #5 of 26 Old 05-12-2003, 07:03 PM
JEEPTECHNICIAN
there is a pigtail behind the spare tire behind the plastic. I think it is green. go get one from jeep if you want it done right. You dont want to splice and cut if you dont have to. I've seen these aftermarket hook ups cause all kinds of problems...
JEEPTECHNICIAN is offline
post #6 of 26 Old 06-18-2016, 09:52 AM
RedRiverT
Resurrecting an old thread:
I've been trying to find the right answer, and thought I had, so I ordered a trailer wiring harness (Curt brand). It is apparently not the right one, well, not the one I wanted. My 97 ZJ has the tow prep group. I'm pretty sure the plug shown in the attached pic is the one you're supposed to connect to. The harness I bought online has small square plugs, as if it connects inline with the tail lights. Does anyone know a part number for a trailer harness which connects to the plug shown in the pic? (and I mean KNOW, not suspect) If not a part number, a correct and detailed description. I thought about ordering a Mopar part, but couldn't decipher from their descriptions which one was the correct one. Thanks.
RedRiverT is offline
post #7 of 26 Old 06-19-2016, 04:27 PM
vlackattack
It's generally better to start your own thread rather than resurrecting a 13 year dead thread that's only vaguely related to your question. But I think you may have the record for oldest thread revival, so there's that.
vlackattack is online now
post #8 of 26 Old 06-19-2016, 07:40 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
If you have trailer tow its 82202423. Without it is 82203616, which is per the mopar accessories catalog for that year. So your "breaking the law" post paid off.
Originally Posted by HighLonesome
coralman is offline
post #9 of 26 Old 06-21-2016, 12:17 AM
RedRiverT
Thanks a ton, coralman.
Breakin' the law! Breakin' the law!
post #10 of 26 Old 06-30-2016, 11:56 PM
RedRiverT
Using the number coralman provided I was able to find one for sale online that showed a full picture. I was expecting it to have some sort of "module" or box in the wiring., but it was just wires. I thought about buying it, but $50 ticked me off. I cut the end of the insulation off of some butt connectors so I could push them on the pins in the harness plug and made my own shade tree mechanic version.
Here it is incomplete. I had to get some brown wire. I couldn't find purple easily, so I put black stripes on blue. Other than that, the colors match pretty well,
post #11 of 26 Old 07-02-2016, 11:14 AM
akk32
You might do better going to a junk yard and cutting out the other end of the connector, you also will need the relays. That is what I did
1997 Jeep Grand Cherokee Laredo 4.0 Selec-Trac 4WD Chargold II 230,000 Miles
1996 Jeep Grand Cherokee Laredo 4.0 Selec-Trac 4WD Chargold II 208,000 Miles (Totaled, working on rebuilding it)
akk32 is offline
post #12 of 26 Old 07-02-2016, 11:22 AM
GOLDWING
I suggest you just cut that connector out and solder/shrink tube the connections so you don't have to do it over again.
GW
2 '98 4.0 ZJs
Hers is stock, mine, BB, Aussie, 2x6 sliders, 31s, etc.
GOLDWING is offline
post #13 of 26 Old 07-02-2016, 11:45 AM
akk32
GW
Don't you need the relays, mine didn't flash without the relays. It just stayed on.
akk32 is offline
post #14 of 26 Old 07-02-2016, 02:56 PM
coralman
coralman's Avatar
With
Name:  pic harness1.jpg
without
coralman is offline
post #15 of 26 Old 07-02-2016, 03:40 PM
MrRoundel
So, how much do you want for that "with" assortment, coralman?
Kidding aside, my ZJ is in the "without" camp, and will probably remain that way. Plus, the rotten scoundrels at the local stealership who installed my replacement hitch, removed the factory one with the extra "appendage" for the plug, and installed a without. Weenies.
MrRoundel is offline
Trailer Wiring f-series ZJ Grand Cherokee Forum 9 01-21-2010 09:54 AM
ZJ Trailer Wiring ZJ5point2GCL ZJ Grand Cherokee Forum 4 12-06-2009 05:15 PM
HELP!!!!!!!!!!! Trailer Wiring W2001J ZJ Grand Cherokee Forum 10 08-21-2009 01:06 AM
97 ZJ trailer wiring ezrider327 ZJ Grand Cherokee Forum 10 10-30-2007 08:15 PM
trailer wiring b.lee ZJ Grand Cherokee Forum 5 07-14-2006 11:05 AM
