ZJ Torque Specifications - Page 2 - JeepForum.com
 1Likes
post #16 of 23 Old 03-17-2013, 04:56 PM
5-90
5-90's Avatar
1988 XJ Cherokee
Originally Posted by iser View Post
awesome website!!! mad props to you!!!
Thank you! I've got some more information, and should be working on updates (yes, including fixing the internal doc links.)
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
post #17 of 23 Old 05-25-2013, 07:44 AM
Candymancan
You sure these are correct ? The TSB sheet for the intake manifold says the lower plate bolts for the manifold need to be at 84 inch lbs.. and the upper outside bolts need to be at the 12ft lbs.. You have it backwords.. Unless yours is right and theres is wrong.. because i torqued my manifold down 12ft lbs, and the pan bolts to 84 inch lbs.
See the lower bolts need to be at 84 inchs lbs.. Not 12ft lbs which is 144inch lbs.. the manifold itself is what needs to be at 12ft lbs.
http://dodgeram.info/tsb/2000/09-05-00.htm
Candymancan is offline
post #18 of 23 Old 05-25-2013, 09:16 PM
tucsonzj
I thought brake calipers bolts were suppose to be ~20lbs.
Either way great stuff thank you!
His:00 TJ "Fiona" stuff/stuff/stuff
95 ZJ 3.5" w/242 swap-Sold
Hers: 15 JK Sahara-3" Teraflex
tucsonzj is offline
post #19 of 23 Old 02-23-2014, 08:43 PM
radean84
Thanks for posting this, coming in very handy right now.
Video Updates of my 96 ZJ
Follow me on Instagram @projectzj.c0m (with a zero)
radean84 is offline
post #20 of 23 Old 11-14-2014, 04:49 PM
justincdst
I've been using this forum for 8 months now while I work on my build. This is by far the sickest post I've found yet. Thank you for taking the time to post this.
justincdst is offline
post #21 of 23 Old 02-23-2017, 10:38 AM
CamoX413
Does anyone know the torque specs for the rear track bar?
CamoX413 is offline
post #22 of 23 Old 02-23-2017, 01:52 PM
xteban
From the FSM (Rear suspension 2 - 13):
Track Bar
Frame Bracket Nut: 100 Nm (74 ft. lbs.)
Axle Bracket Bolt: 100Nm (74ft.lbs.)
xteban is offline
post #23 of 23 Old 02-23-2017, 02:29 PM
CamoX413
Thank you!
CamoX413 is offline
grand cherokee , Torque , torque specifications , torque specs , zj
