zj tips and tricks - JeepForum.com
post #1 of 10 Old 10-09-2013, 06:16 PM Thread Starter
xj4ever81
1992 XJ Cherokee
zj tips and tricks
Hey guys bout trade my xj for a zj looking for some tips and tricks and what not to dos lol its a 94 zj coutry model 4.0 249 case lp 30 35 3.55 gears thanx
xj4ever81 is offline
post #2 of 10 Old 10-09-2013, 06:26 PM
jeepzj1998
If your going to do any type of lift and the jeep has the cv front drive shaft, swap it out. Second, you may want to think about swapping in a 231 or 242 transfer case as well.
jeepzj1998 is offline
post #3 of 10 Old 10-09-2013, 06:30 PM
Dubfire98
Swap the cv shaft for?
TN JEEPER
Dubfire98 is offline
post #4 of 10 Old 10-09-2013, 06:40 PM Thread Starter
xj4ever81
1992 XJ Cherokee
Sorry should put that in there its got u joint drive shafts fronts from a xj. And yes 231 is going in just reade the write up on keavins offroad
post #5 of 10 Old 10-09-2013, 06:41 PM Thread Starter
xj4ever81
1992 XJ Cherokee
A double cardon u joint style much stronger
post #6 of 10 Old 10-09-2013, 06:42 PM Thread Starter
xj4ever81
1992 XJ Cherokee
What about quarks anything the zj is famous for
post #7 of 10 Old 10-09-2013, 07:22 PM
ZeeJay1997
the fake "coolant sensor bad" message on the VIC
stalling because of random electrical gremlins
the 02 sensor harness around gets caught in moving parts or exhaust which, in turn, kills the PCM
see jasons list of common problems
ZeeJay1997 is offline
post #8 of 10 Old 10-09-2013, 07:41 PM Thread Starter
xj4ever81
1992 XJ Cherokee
You da man thanx
post #9 of 10 Old 10-09-2013, 09:08 PM
Pugulis
I think VIC might be HAL's little brother. "Open the pod bay doors HAL".
[_][]☺[][][]☺[][_] RIP to my 96' Grand Cherokee Laredo 344,700 miles and welcome to my new 2001 WJ
Pugulis is offline
post #10 of 10 Old 10-10-2013, 12:02 AM
power
1994 ZJ
I would check all the ground wires. If any power windows, door locks, alarm have problems check the wiring harness in the drivers door jamb first. Every ZJ my girlfriend and I have owned (4) has had a broken wire in the drivers door wiring harness. Sometimes in the passenger door as well.
Water pumps seem to go every few years. I carry a spare crank position sensor in my glove box, but have never had to use it yet....... A long list of things documented on this board.
94 ZJ,4.0, AX15, NP231
power is offline
