zj temp control problem - JeepForum.com
post #1 of 3 Old 07-31-2005, 09:41 PM Thread Starter
rm1515
having a problem with temperature control knob.. Fan control only works in the HI position.. anyone have any ideas. ran the fault code thingl. came up with 16 and 48.
thanks
Rob
rm1515 is offline
post #2 of 3 Old 07-31-2005, 09:56 PM
noreaga0221
16 Loss of battery voltage. Battery voltage sensor input below 4 volts with engine running.
Knock sensor circuit. Open or short has been detected in the knock sensor circuit.
and there is no code for 48.. unless you mean 47.
http://www.zjilla.com/tech_codes.htm
What does your battery guage say while its running?
noreaga0221 is offline
post #3 of 3 Old 08-01-2005, 07:50 AM Thread Starter
rm1515
sorry, the fault codes came from the temperature contron unit itself, not the ecu.
thanks
Rob
rm1515 is offline
Auto Temp Control -- Bulbs bandanaboyz ZJ Grand Cherokee Forum 2 01-24-2010 06:39 PM
A/C: temp control not working alexsious ZJ Grand Cherokee Forum 4 03-03-2009 11:48 AM
Dash light behind temp control out - how fix? lezmark7 ZJ Grand Cherokee Forum 2 10-22-2008 09:53 PM
Ac, temp control issues on laredo tyler711 ZJ Grand Cherokee Forum 7 06-30-2008 05:14 PM
auto temp control? Kcolg ZJ Grand Cherokee Forum 2 02-08-2006 11:09 AM
