ZJ Tailgate window latch - Page 2 - JeepForum.com
post #16 of 30 Old 06-07-2011, 03:45 PM
jforse
Just finished this. Works great!!!!! many thanks!
1997 TJ - Build in process.
2004 WJ Freedom Edition 4.7HO
jforse is offline
post #17 of 30 Old 07-31-2011, 10:28 AM
qbit
Great info
Thanks for the great info on troubleshooting this problem (I too had a rear window that refused to open), but on further inspection I found a somewhat different problem.
The switch tested faulty but I looked at switch and noticed that the switch could not fully return to the upright position when released.
Here is the problem - the lever arm for the switch is connected to the main body of the switch through a rivet (the lever arm pivots through this rivet), BUT the one side of the rivet is closely approximated to the metal attachment bracket.
This bracket had some corrosion and placed pressure on the rivet and prevented the switch from returning from the fully upright position.
Removing the metal from the bracket (using a dremel) that was overtop of the rivet fixed the problem for good!
Thanks again for the info - hopes this helps someone else with their rear window problem.
qb
qbit is offline
post #18 of 30 Old 01-30-2012, 02:17 AM
daloveboat
1996 WJ
Thank you soooo much doogie1303. Microswitch fix totally worked. I am so stoked. Thanks for the priceless picture tutorial, super simple and glass is-a-workin.
You rule!!
daloveboat is offline
post #19 of 30 Old 10-29-2012, 06:13 PM
philstricker
This is great. Same exact problem. The pics are very helpful, too. I wish more people took pictures as they went.
1998 4.0 L6 Laredo ZJ 214,000
philstricker is offline
post #20 of 30 Old 10-30-2012, 04:03 AM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
This should be stickied , since it is a crafty repair to a part thats not available.
Originally Posted by HighLonesome
coralman is online now
post #21 of 30 Old 10-30-2012, 05:45 AM
KoreaZJ
1994 ZJ
Crafty repair for what appears to be a poor design.
KoreaZJ is offline
post #22 of 30 Old 10-30-2012, 11:41 AM
coralman
coralman's Avatar
Hey ratmonkey can this please be stickied ?
post #23 of 30 Old 10-31-2012, 06:28 PM
Bear304inc
I'm with coralman, this should be stickied. gonna be doing this very soon, damn window.
Bear304inc is offline
post #24 of 30 Old 11-08-2012, 08:47 AM
philstricker
I did some searching because I'm looking to do a replacement of the microswitch without replacing the entire handle setup.
Sub-Microswitch: E Series Sub-Mini switches (Cherry Electronics)
Cherry Electronics E62-00A (Mouser Electronics)
Microswitch: Cherry E70 Series (Cherry Electronics - closest I could find to original, interesting though, this may be able to replace both switches in one. If I try it I'll post results)
Cherry E72-40AT (Mouser Electronics)
post #25 of 30 Old 11-15-2012, 10:13 AM
philstricker
Cherry Electronics Part E72-40AT is an all in one modern replacement. All you need to do is change the lever to match the old one. Haven't done it yet but I'm going to clip it and bend it the best I can to mimic the original. Also need to get small screws and locking bolts in lieu of rivets that don't come with the part to attach it to the metal bracket.
I plugged it in and it worked like a charm. Now all I need to do is replace the old struts!
post #26 of 30 Old 11-15-2012, 01:12 PM
Bear304inc
Very good to know phil, this is exactly why I joined jf, lil bits of info that would be very difficult to otherwise learn. Thanks guys.. and gals.
post #27 of 30 Old 03-08-2013, 02:06 PM
jmonty0523
So I'm not where I found the picture if the switch with dimensions, but went to Radio Shack today with the dimensions and a dial caliper, they stock the micro switches...they have 2 styles, both same price, one has a roller switch, one is just a lever switch, but since top arm needs to be removed, it don't much matter. Anyways... Radio Shack part number is 275-0017, and was only $4
...________oooo_
/ ./.\...,\_____ \,_____
[_---_______---_\-\\\\\\-\
(o) )-o---) ) (o) )-o---) )______
jmonty0523 is offline
post #28 of 30 Old 03-08-2013, 03:02 PM
LouC
2007 WK
Thanks very much I have to fix this on my ZJ as well..
2007 WK Limited Hemi QDII
1998 ZJ Laredo 4.0 Selectrac
LouC is offline
post #29 of 30 Old 04-18-2013, 04:51 PM
Metallheadd
I just completed this fix on my 98 and it works great. Thanks for the info.
Metallheadd is offline
post #30 of 30 Old 09-27-2015, 01:10 PM
SSteveTX
I know this is an old thread, but wanted to say that this fixed my issue. I used the radio shack part number 275-0017 mentioned a few posts up which was under $4 still at my local RS. While you have everything apart, I suggest spraying some good lube on the moving parts. I used white lithium grease (spray can) which made everything move smoother.
One additional issue I had was on the blue/white plug connector at the opposite end of the microswitch. It had a loose connection which I couldn't get fixed 100%. I ended up cutting out that plug and connecting the wires directly using butt connectors.
SSteveTX is offline
96 GC tailgate latch will not release justtalkin ZJ Grand Cherokee Forum 6 11-20-2009 09:29 PM
Rear tailgate window washer fluid on 06 JGC? LordGriNz WK Grand Cherokee & XK Commander Forum 0 09-18-2006 05:37 AM
ZJ tailgate issues (wiper/window release button) MatrixRooster ZJ Grand Cherokee Forum 5 07-17-2004 10:29 PM
94 tailgate latch sticking jfw432 ZJ Grand Cherokee Forum 7 06-03-2003 09:25 PM
tailgate latch problem jeep_ivan ZJ Grand Cherokee Forum 5 07-19-2002 11:33 AM
