zj stereo wiring diagram - JeepForum.com
post #1 of 12 Old 05-20-2006, 10:04 AM Thread Starter
Jay1982
Does anyone know the stock wiring diagram, IE: which color wires do what, I am trying to hook up an aftermarket stereo.
Jay1982 is offline
post #2 of 12 Old 05-20-2006, 11:19 AM Thread Starter
Jay1982
Well to answer my own question:
Radio w/ Power AMP
Radio Connector:
BLACK HARNESS:
PIN Wire description Color
1. AMP On/OFF signal/antenna up signal Dark Green/Red
2. Left rear speaker feed (+) Brown/Yellow
3. Right rear speaker feed (+) Dark Blue/White
4. Left front speaker feed (+) Dark Green
5. Right front speaker feed (+) Violet/Yellow
6. Left rear speaker return (-) Brown/Light Blue
7. Right rear speaker return (-) Dark Blue/Pink
GRAY HARNESS:
PIN Wire Description Color
1. Radio Mute
2. Left front speaker return (-) Brown/Red
3. Right front speaker return (-) Dark Blue
4. Marker (Head/Park Lamp) Dark Blue/Red
5. Dimmer (Panel, Lamps, Variable) Orange
6. Accessory (Switched B+) Red/Grey
7. Battery (Memory) Red/White
There you go for anyone else who might need to know the same information.
Jay1982 is offline
post #3 of 12 Old 05-20-2006, 11:26 AM
nekked_frogg_52
Also if anyone needs the Wiring Diagram for the Infinity amp (under the rear seat) Im me and I will gladly Provide it
Mo
95 Red ZJ
5.2 MSD 6AL, Custom CAI, Blacked out windows, waiting on lift kit, in process of doing spring swap to clear 31's. In dash DVD/Nav, 2 12" Sony Xplod's, Old school Rockford amp, Boston Coustic mids/highs
nekked_frogg_52 is offline
post #4 of 12 Old 05-20-2006, 04:08 PM
Meerkat
Or you could do a search. If I had a nickel for every time I've posted the wiring diagrams for stereos and lights......
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline
post #5 of 12 Old 05-21-2006, 03:51 AM
GreenDean
GreenDean's Avatar
You would have 25 cents.
GreenDean is offline
post #6 of 12 Old 05-21-2006, 07:43 PM Thread Starter
Jay1982
Yeah dude, where do you think I got the diagram from??
Jay1982 is offline
post #7 of 12 Old 05-21-2006, 08:16 PM
Meerkat
I had no idea where you got it, Jay. It seems I simply assumed you found it elsewhere. So any way you look at it, good on you and bad on me for reacting that way.
Warren
Meerkat is offline
post #8 of 12 Old 05-21-2006, 09:15 PM Thread Starter
Jay1982
Does best buy or circuit city have a dash kit for this model? I was at walmart earlier today and they didnt have any that was made for a Jeep period.
Jay1982 is offline
post #9 of 12 Old 05-21-2006, 09:19 PM
anticrombie
anticrombie's Avatar
They should have it.
Charlie
anticrombie is offline
post #10 of 12 Old 05-21-2006, 10:47 PM
Virmagicus
Virmagicus's Avatar
Look for Chrysler . Buy the harness adapter also .
Jeff
Virmagicus is offline
post #11 of 12 Old 05-21-2006, 11:30 PM Thread Starter
Jay1982
I dont need a harness adapter, I hooked the cd deck up without cutting any factory stereo wires which is why I needed a wiring diagram, all you do is unsnap the wire at the bottom of the harness and the wire and metal end come out, so if you ever wanted to put a factory stereo back in for some odd reason just clip the wires back in the harness and presto.
Jay1982 is offline
post #12 of 12 Old 05-22-2006, 01:05 AM
cyberjedi
my walmart does check others and yes best buy does
cyberjedi is offline
96 GC Wiring Diagram Miss_Jeep ZJ Grand Cherokee Forum 10 07-19-2009 10:28 PM
looking for a wiring diagram for my 04 spider736 ZJ Grand Cherokee Forum 2 01-12-2009 07:40 AM
Fsm Or Wiring Diagram gsc1ugs ZJ Grand Cherokee Forum 5 03-10-2008 02:15 PM
wiring diagram mudd ZJ Grand Cherokee Forum 4 06-01-2007 04:29 PM
Wiring diagram?? Stang5lgt ZJ Grand Cherokee Forum 4 11-19-2005 07:44 PM
