ZJ steering problems - JeepForum.com
post #1 of 3 Old 09-13-2012, 10:14 PM Thread Starter
stevsand77
1994 ZJ
So my jeep has been giving me some problems lately. the steering has been creaking when i turn the wheel both left and right. Its also been wobbling a little bit when Im driving. It starts anywhere between 40 and 45 mph then seems to be less noticeable after 50 mph. its a really light wobble, nothing as bad as the death wobble but its really annoying. I put the jeep on jack stands and checked for any play in the tie rod ends and joints but found nothing. I noticed the dust boots are all cracked though. as for the creaking I thought it was the steering stabilizer because I know it needs to be replaced but I disconnected it and the creaking was still there. I also made sure everything is greased up but that still didn't help. Can anyone help me solve this? Thanks!
stevsand77 is offline
post #2 of 3 Old 09-17-2012, 02:22 PM
oldsixinarow
Check your steering knuckle u-joints. Pull the hub bearing off and yank an axle shaft. Betcha find that its all bound up.
A Bunch of ZJ's, A TJ, A CJ2A and an FSJ
oldsixinarow is offline
post #3 of 3 Old 09-17-2012, 03:59 PM
ajmorell
ajmorell's Avatar
You don't need to pull the hub off to check axle u-joints. Just reach under there and try to rotate them. If there's any play they're shot.
ajmorell is offline
steering , wobble , zj
steering problems cleanslate ZJ Grand Cherokee Forum 4 01-28-2012 04:26 AM
05 WK steering problems bull_blaster WK Grand Cherokee & XK Commander Forum 11 12-24-2007 12:01 PM
Help steering problems 95GCV8 ZJ Grand Cherokee Forum 2 03-15-2006 12:48 AM
Steering Problems??? illz302 ZJ Grand Cherokee Forum 4 08-30-2005 10:38 PM
Problems with steering Jeremy ZJ Grand Cherokee Forum 1 05-31-2002 01:45 AM
