ZJ Starts then Dies - grounded alarm wire - JeepForum.com
post #1 of 20 Old 07-14-2011, 01:20 PM Thread Starter
orchimaxi
Alright, here's the issue - I have a 1995 ZJ Limited 5.2 that I've been slowly getting in order and finally got inspected today. I've been doing 90% of the work on my own and have a pretty good grasp on how to do things. I replaced the stereo head unit and all four door speakers today, and when I went to start it up and move it from in front of my garage (in an apartment complex, absolutely need to move it ASAP) it would start then stall in about 2 seconds - pretty much exactly like the alarm was going off. However, the alarm is NOT going off and I can't get it started by locking and unlocking the back door (which is a struggle, because it only unlocks about every 10th attempt). Next I cut the purple/yellow wire in my drivers side door and screwed it to the door panel. Same result, only this time when I reconnected the battery I didn't have the 4-ways going like normal. I need advice on getting this thing going ASAP!! Thanks in advance!
1999 XJ SE 5 spd 4.0 -- Dead
2001 TJ Sahara 5 spd 4.0 -- Sold
1995 ZJ 5.2L -- Sold
1997 TJ 4 cyl 5 spd - still figuring it out...
orchimaxi is offline
post #2 of 20 Old 07-14-2011, 02:07 PM Thread Starter
orchimaxi
Only codes I have are:
12 - Direct battery input to PCM was disconnected within the last 50 Key-on cycles.
55 - Completion of fault code display on Check Engine lamp.
post #3 of 20 Old 07-15-2011, 05:07 AM Thread Starter
orchimaxi
Please help! I NEED to have this running by next week!
post #4 of 20 Old 07-18-2011, 05:04 PM Thread Starter
orchimaxi
Anybody have any ideas?
post #5 of 20 Old 07-18-2011, 06:19 PM
FPKites
ZJjazzyJim
FPKites's Avatar
Check your battery cables - dirty power does that to me all the time.
Loosen, pull off, spread out with a screwdriver, and seat them all the way on the post. Re-tighten.
Jim Karlin
"Duh! Big RED Jeep!!!"
or
96 ZJ Laredo
5" lift, Claytons, KOR radiator support, rear bumper, steering brace, etc, etc, etc.
04 WJ Overland
Clean.... :D
FPKites is offline
post #6 of 20 Old 07-18-2011, 06:19 PM
melk
Are the battery terminals clean?
I had the same problem last week, went to leave work and it would start and die, wasn't the alarm. Pulled the battery cables off and cleaned them up real good and it fired back up like normal. GL....
melk is offline
post #7 of 20 Old 07-18-2011, 06:44 PM
WhiteOut
WhiteOut's Avatar
Locking and unlocking the hatch does nothing. Try locking and unlocking the drivers door.
Side of the wire did you ground? Which wire was cut.
WhiteOut is offline
post #8 of 20 Old 07-19-2011, 05:00 AM Thread Starter
orchimaxi
I'll pull and clean the terminals, but I had just replaced them a few months back, as I recall they look pretty good. I grounded the forward side of the purple/yellow wire in the drivers side door.... maybe I'll yank that and make sure it's got a good connection...
post #9 of 20 Old 07-19-2011, 07:47 AM Thread Starter
orchimaxi
Cleaned battery cables and used a wire brush to make sure I had metal-metal contact with the wire terminal... no luck. Any other ideas?
post #10 of 20 Old 07-19-2011, 07:52 AM
newfieZJ
Fuel pump
BTW , unlocking the hatch will work fine on a 95 to dis-arm the alarm
newfieZJ is offline
post #11 of 20 Old 07-19-2011, 08:32 AM Thread Starter
orchimaxi
Tried the hatch, wasn't working - but my lock is also messed up back there, so wouldn't have been surprised if that was part of the problem....
Would a bad fuel pump allow it to start for a few seconds before dying? If I crank the key straight from "Off" to "Start" it will start and run for maybe 2 seconds, but if the key is sitting at "Run" when I start it it never gets the chance to idle, it dies almost immediately.
Would suck if it were the fuel pump, I just filled it with gas the other day!
post #12 of 20 Old 07-19-2011, 08:34 AM
newfieZJ
I would certainly do a fuel pressure test before continuing
newfieZJ is offline
post #13 of 20 Old 07-19-2011, 10:15 AM Thread Starter
orchimaxi
Just pulled, cleaned and reattached PCM 60-pin connector, no luck...
Guess I'll pick up a fuel pressure gauge after lunch and check that... Though unless the pressure is low with the engine off it probably wont tell me much since the ASD would shut off fuel to kill the engine...right?
post #14 of 20 Old 07-19-2011, 10:23 AM
newfieZJ
The pump will prime to a certain psi (gotta check) even with just the key forward to the on position . I think the PSI is 39 +/- 2 on the 95
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #15 of 20 Old 07-19-2011, 06:15 PM
FPKites
ZJjazzyJim
FPKites's Avatar
Try switching the ASD and ABS relays just for giggles?
Jim Karlin
or
96 ZJ Laredo
04 WJ Overland
Clean.... :D
FPKites is offline
93 5.2L Starts then dies ubu ZJ Grand Cherokee Forum 16 04-08-2013 04:07 PM
Starts and dies, starts and dies. LucasP ZJ Grand Cherokee Forum 9 01-14-2011 08:36 PM
97 jgc starts and dies SpeedyMcready87 ZJ Grand Cherokee Forum 11 10-14-2010 12:29 PM
96 GC starts then dies Amandael08 ZJ Grand Cherokee Forum 6 02-09-2010 07:57 AM
Starts than dies... Casper4x4 ZJ Grand Cherokee Forum 15 06-06-2009 05:45 AM
