#1 | |
Zj Stalls!!!
HEY there guys, my zj has a weird problem that i cannot figure out.
when i pull up to a stop light, and jam on the brakes a little harder then normal, the vehicle just stalls!!!!!!!!!!! or sometimes, when from a complete stop, i try to give it some gas and it sputters and jerks crazily and then usually it drives normal.., this only happens occasionaly as well well, any help on this would be greatly appreciated
#2 |
Might your fuel pump be going bad? If all of the gas moves to the front of the tank on a hard stop, then a weak pump might have a hard time keeping up.
Kent '06 XK Limited, 5.7L Hemi, Quadra-Drive II, Black, 89K Miles '02 WJ Overland, 4.7L HO, Quadra-Drive, Inferno Red, 84K Miles |
#3 |
thats what i was afraid of, do u think its possible that it could be the fuel filter??
#4 |
replace the filter if you have one
Cheers Steve Trained Professional Crack-pot Go RU & WVU Football Teams 94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new 03 4Runner V8 (my wife's car) 94 Volvo 850 (my 16-yr old daughter's car) Five cylinder 88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new |
#5 |
You can replace the filter, but it is not easy. You have to drop the tank. I would have the pressure at the fuel rail checked first. Also, when my fuel pump died, it was also throwing a CEL. If you are not gettting any CEL, then it may not be your pump. I do know that mine took a while before it threw a code.
#6 |
try and change the coil
#7 |
I doubt it is your fuel pump itself or the filter. These would generally cause issues when under load (high fuel demand). I would check your TPS.
Dan [B]If you don't get stuck, keep trying![/B] '96 ZJ 7" LA, 318, 231, 8.8 (welded), d30 (LockRight), 4.10's, 33x13.5x16 TSL's, no interior... |
#8 | |
#9 |
Check your Battery! Mine had the same problem one weak cell, My cousin had the same problem as well
97 ZJ Chop Top-Buggy 5.2L V8, 249 T-Case 5" Lift, JKS Front and Rear Adj. Trackbars, RE Twin Tube Shocks, RE T-Case Drop, Cut Fenders, Chop Top, Half Doors. 33"x13"x16" Super Swamper TSLs on Black Steelies Custom Rack, 4 Roof Lights, Roof Back-up Lights |
#10 | |
Here's what you should be looking for: Battery & Battery terminals Crankshaft Position Sensor Throttle Position Sensor Fuel Filter Fuel Pump Start off by checking your fuel pressure, if the fuel pressuer is O.K. i'd move on the the sensors and battery. |
#11 |
My 93 gave me some greif today. Pulled off the highway and stopped at a store, came out and it would fire up and die. Kept the rpm's up for a little while and it seemed to clear up, thought maybe just a bit of vapor lock. Continued on our merry way and about a 1 1/2 hrs later got to our destination. Same crap again, had to keep the idle up to about 1500 to get it to stay running, volt gauge would take a dive every time I let off the throttle and it would die, almost didn't start again but I got it going and made my way to a parts store. Popped a new alternator in and ran it for a few minutes to bring the battery back up to full charge and it never missed a beat the rest of the day.
Sure glad I didn't take all the tools out of the back when I spring cleaned it the other day. Now I just need to do something about that crappy 249. |
#12 |
That was very intuitive... Computerized vehicles will not run with less than 10 volts so bad alt can keep you from idleing..
But I would go with What Ross said.. Check Codes.. If not codes.. Check battery cables and connections .. No swollen cables or crusty connections ... Check fuel pressure .. If thats good move on to TPS (throttle position sensor) then IAC (Idle air control) You can check TPS with a volt meter and IAC will need to be taken off and cleaned with a good throttle body cleaner ..Not carb cleaner..) Both parts are around $30 if you have to replace them... If neither of those clear up your problem.. Then it could be a bad Air charge temp sensor ... It causes simular problems... But since I dont know what year or engine type you have I cannot go any farther... That kind of thing is helpfull ...
Just another soccer moms Grocery getter.... [Url]http://www.jeepforum.com/gallery/files//8/5/6/5/hatt034.jpg[/url] |
#13 |
I would think it's not a fuel issue. Sensors and electrical are my guess. If it only happens when you brake HARD, I could see it being a TPS or possibly vacuum issue.
Jon Selman 96 Jeep Grand Cherokee 5.2L 3.5" RE Lift on 31x10.5's Daytona BEach, Fl. |
#14 |
My .02c.
Two years ago my ZJ did the same exact thing and progressivly got worse. Finally got real bad on a family vacation in Colorado. Replaced the fuel pump and cured the problem.Not saying this is the same problem you are having, but certainly worth a look. The fuel pump is in the tank but still very easy to replace. Did it in an hour at a friends house with limited tools. Good luck!
[U]2006 Dodge Cummins[/U]:Daystar leveling kit, 18" Pro Comp Extreme Alloys, 35" Cooper Discover STT's, Bushwacker Extend a Fender flares [U]2003 TJ[/U]: Full Traction 4" lift, 33" BFG Mud Terrains on 8" Atlas wheels, Russel braided brake lines, Tom Woods SYE and driveshaft, ATK winch bumper,VIAIR 450 onboard air, PIAA driving lights, Poison Spyder Rocker Knockers, full Skid Row skid plates, AEM intake w/throttle body spacer, Optima battery, full recovery gear, Sony Xplod stereo, Cobra CB, etc... [U]1997 ZJ Grand Cherokee[/U]: Rubicon Express lift, 31" BFG All Terrains, K&N FIPK, etc... [U]2001 Dodge Cummins[/U]: Work Horse!! [COLOR="Red"]SOLD[/COLOR] [U]1970 Dodge Challenger[/U]: Roller cammed small block, 4-speed, modern suspension, killer stereo, etc.... |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
