ZJ snorkel - JeepForum.com
post #1 of 15 Old 12-26-2006, 12:54 PM Thread Starter
CJjacquez
ZJ snorkel
Guys , I'm about to order a snorkel for my ZJ 1993
I know there is not an arb snorkel for this model and I found a site at nagca about using an SS720HF snorkel for that ZJ
Question : Any of you have installed another model of snorkel from arb ??
Thanks!
ZJ Limited 1993 / 6 Cil. 4.0 / 242J Transfer Case / Throttle body spacer / Skyjacker 3" /Spacers 2"/Adjustable LCA's
Home made Disconnects / Custom Roof Rack / Optima Yellow / Rancho Steering Stabilizer / GPS, CB/ Jeep PC
Mud Terrain 31x10.5x15
CJjacquez is offline
post #2 of 15 Old 12-26-2006, 01:10 PM
Phil Gerard
Former Mod
Phil Gerard's Avatar
I honestly haven't seen many snorkles on here. Not many mudders mostly rock crawlers or stock plus our interiors don't hold up too well when below water!
But seriously, I also think that because we're lifted higher than a TJ for fitting the same size tire we have less breather height issues than TJs or WJs.
Phil
'95 ZJ Ltd. White 4.0L
TW DC DS; ARB Bull Bar, F&R Air Lockers; Superior Axles; Warn Winch; 4.56 gears; ACOS, Addco F&R Sw Bar, JKS Discos, Rr Track Bar & Nerfs, 249>242 Swap, Stillen rotors+Kolak pads, 3 pc. Armor, RE 4.5 Kit + 2.5"BB, Adj. UCAs&LCAs, OME SS, Bilstein 5150s, 15x8 AR Diamond Backs, 33 Truxus MTs, K&N FIPK, RE 62mm TB, Perf. Distr. 4.0L Kit, Exhaust: 2.5" Kolak exhaust FM 70: Optima Yellow, Mean Grn Alt., PIAA 520s, 540s, Kevins Rack, & TB Conversion
Phil Gerard is offline
post #3 of 15 Old 12-26-2006, 01:14 PM
Woody
Retired back to Bowties
Woody's Avatar
1985
I'm gonna build one this spring, admittedly, it will probably be PVC homebrew.
I'll reroute all the breathers to it to get them up higher as well.
Woody
1985 1 ton K-5, Detroit diesel, 36" tires (going bigger when money permits), 4-speed manual swap, Rockwell T-case, Hybrid lift, 12.5K winch.
Woody is offline
post #4 of 15 Old 12-26-2006, 03:10 PM
Trouble Maker
reckless endangerer
Trouble Maker's Avatar
I personally would prefer some kind of cowl induction system over a snorkel. Just need to figure out an easy and cheap yet good looking way to do it.
I learned a long time ago that I can't walk on water and try my best to stay out of the deep end.
Russ
02 Dakota Quad Cab 4.7 5 spd
93 ZJ Stolen and wrecked Mar29/08
Trouble Maker is offline
post #5 of 15 Old 12-26-2006, 06:01 PM
GreenDean
GreenDean's Avatar
Well said.
I think a simple pipe up to the cowl would sufice on any jeep.
Any higher then that and your up to your neck.
GreenDean is offline
post #6 of 15 Old 12-26-2006, 06:32 PM
driabyor
driabyor's Avatar
1994 ZJ
someone uses a pathfinder snorkel i think.... i looks pretty good on it. there is a write up one of the forums
94 Grand Cherokee ... 332,000 miles
5.2 liter 242 :)
Rancho 5000 steering stabilizer
driabyor is offline
post #7 of 15 Old 12-26-2006, 07:54 PM
Sporer65
Sporer65's Avatar
Location: Powder Springs, Georgia/University of Tennessee
On NAGCA, the write-up uses an snorkel for an X-terra.
Ben
1993 Jeep Grand Wagoneer ZJ V8: Rear Aussie, 3.5" Lift, 31" M/Ts
Sporer65 is offline
post #8 of 15 Old 12-26-2006, 09:50 PM
BlaineWasHere
BecauseRacecar
BlaineWasHere's Avatar
I am just going to stay outa the water.
2013 FR-S
BlaineWasHere is offline
post #9 of 15 Old 12-27-2006, 06:33 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
I stole this from Pirate...
the worst looking snorkel ever!
Hunter
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #10 of 15 Old 12-27-2006, 08:06 AM
Beest
this is also an option...
http://www.turbocity.com/default.php
looks like this
Beest is offline
post #11 of 15 Old 12-27-2006, 08:08 AM
Phil Gerard
Former Mod
Hunter
post #12 of 15 Old 12-27-2006, 08:14 AM
gunthagunth
gunthagunth's Avatar
A little high but it works . I believe he made this attachable to the stock airbox. He removes it when hes done with the water crossing. Think his winch remote would work?
97 ZJ 5.9L 242/4.5" RE Coils/1.75" Spacers/Clayton arms/Addco's/RE brake lines/35x12.5 bfg muds/Currie steering/K&N/Claytons Front Drop tracbar/Dropped pitman/Bilstein 5125's/JKS BPE/JKS loop conversion/JKS Sliders/ZJilla rear bumper/Clayton front winch bumper/durango steering box/warn 9000i/Hambek Customs carbon fiber cowl hood #2of16/Hp30-8.8 4.56/ARB f+r
gunthagunth is offline
post #13 of 15 Old 12-27-2006, 08:16 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Originally Posted by Phil Gerard
It works for everyone else. Check your prescription.
Hunter
04 4.7 HO, limited
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
post #14 of 15 Old 12-27-2006, 12:12 PM
Redbob
Originally Posted by GreenDean
It's a Compass thing, I guess I don't understand
Boy, that makes two of us!
Redbob is offline
post #15 of 15 Old 12-28-2006, 10:54 AM
fr3db3ar
fr3db3ar's Avatar
It didn't work for me either Phil until I copy and pasted the link.
98 5.9 Some stuff attached
It's true that I'm old enough to probably have been there and done that....it doesn't make me an expert....it gives me an educated opinion.
fr3db3ar is offline
Wj Snorkel KWAG WJ Grand Cherokee Forum 16 11-21-2010 09:48 PM
WJ Snorkel Kit PJNovinskee27 ZJ Grand Cherokee Forum 5 08-18-2008 06:22 AM
ZJ Snorkel offroader156 ZJ Grand Cherokee Forum 7 08-02-2007 04:50 AM
WJ Snorkel? MuddyLuxury ZJ Grand Cherokee Forum 5 07-03-2007 02:55 PM
WJ snorkel TriggerHappy ZJ Grand Cherokee Forum 5 03-16-2006 12:25 AM
