ZJ Slow Build - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > ZJ Slow Build
Attention to the TJ owners 1996-2006 NEW LED LIGHT OPTIONSOPTIC ARMOR WINDOWS all sale now !!!!!!!!FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 03-13-2014, 11:31 AM   #1
Grand93Cherokee
I have had my 93 Grand Cherokee for almost 2 years now and have not done any upgrading. PO upgrades: Some Flowmaster muffler Off brand intake(replacing with stock air box this weekend)
Replaced/Repairs:
-Rear main seal in original engine. (too little too late)
-Replaced with used engine with about 30k less miles than the original.
-Replaced Oil pump
-Repaired frayed wires in driver door loom for power windows.
-Repaired rear hatch opening mechanism
-Replaced Head Lights for some nice non-oxidized ones
-Replaced PCM (found perfect match on second try at JY.)
-Oil sending unit.
-Front Calipers
Near Future:
-Front pads and rotors
-Rear shoes
Plans:
2" BB
Shocks
31x10.50x15 Treadwright Warden AT
Cragar Soft 8s 4"BS
1993 Grand Cherokee Laredo
Stock
Grand93Cherokee is offline   Reply With Quote
Unread 03-13-2014, 11:33 AM   #2
PolkaPower
That crimped blue elbow on the intake looks quite restrictive. Why not get a proper one?
Originally Posted by jabba974
"And yes, there is always a torque spec...but its not necessary...and takes way to much time...."
PolkaPower is offline   Reply With Quote
Unread 03-13-2014, 11:36 AM   #3
xcaliber81
1994 ZJ
He said he was putting the stock airbox on.
Im indian my elders name is Jeep Grand Cherokee, I mean Chief Grand Cherokee. Quoted from Peter Griffin.
xcaliber81 is offline   Reply With Quote
Unread 03-13-2014, 11:38 AM   #4
Grand93Cherokee
Stock is going back in this weekend. It's sitting in the closet right now.
Stock
Unread 03-13-2014, 11:40 AM   #5
PolkaPower
That will teach me to read before I post. Sorry.
Unread 03-16-2014, 02:43 PM   #6
Grand93Cherokee
Got the trac bar swapped out yesterday. She rides much nicer now. Next on the repair is brakes all the way around and rotors up front.
Add thermostat and flush to my list for the weekend.
Stock
Unread 03-22-2014, 07:53 PM   #7
Grand93Cherokee
Temp has been looking better since the temps have been above freezing. Well until tomorrow.
Cleaned the throttle body and finally got the stock air box on. Hopefully breaks and rotors go in tomorrow.
The two PCV valves on the valve cover need replace bit I can't find the part on O'Reilly's site. Does anyone know the part number?
Stock
Unread 03-22-2014, 07:59 PM   #8
xcaliber81
1994 ZJ
front one is a 90 degree elbow rear is a special one and may have to go to dodge its got an 1/8 inside diameter its cheap dont worry. clean the front one assuming you can get it out without breaking it and get two grommets. The back one is a serious pita to remove be prepared to remove the valve cover it a broken piece falls in.
Unread 03-22-2014, 09:51 PM   #9
Grand93Cherokee
Front one is easy in/out. Cleaned it a little today. Had major build up. I haven't messed with the back one yet. Maybe tomorrow.
Stock
Unread 03-22-2014, 10:30 PM   #10
xcaliber81
1994 ZJ
Yea the back one is a dealer part it was 16$ or there about just replace it and get a grommet.
Unread 03-29-2014, 01:01 PM   #11
Grand93Cherokee
So I have created a slight issue. My back driver side door would not open from the outside to I sprayed it down with some PB and tried working the latch. In my infinite wisdom I at one point put the child lock on. Needless to say I can not open from the out side or inside now. Anyone have any suggestions?
Stock
Unread 03-29-2014, 01:23 PM   #12
xcaliber81
1994 ZJ
Open the door and theres a spot above the latch part where an allan key will fit loosen it up move it to one side and tighten it up.
Unread 03-29-2014, 03:19 PM   #13
Grand93Cherokee
Door won't open at this point because of child lock being on. Breaks and Rotors: Nice little line in the passenger side outside pad image-1636644652.jpg The matching rotor: bottom of post Grooves from pads image-3656791249.jpg Driver side all bolted up: image-3565230592.jpg Engine with stock air box back in: image-2612621191.jpg Maintenance is getting caught up. Next sunny day will be thermostat, core flush and harmonic balancer. Then the BB, shocks, Cragar soft 8s, tire rod ends and an alignment.
Stock
Unread 03-29-2014, 03:25 PM   #14
xcaliber81
1994 ZJ
You may be able to remove the panel with the door shut if your creative enough and patient enough and use the bar that goes from the outside handle to the actuator.
Unread 03-29-2014, 03:31 PM   #15
pajhns6
My rear drivers door wasnt opening. My buddy hit the door lock switch on the passinger side and it unlocked. Works fine now
pajhns6 is offline   Reply With Quote
