zj on the side of the freeway with belt off - Page 3 - JeepForum.com
post #31 of 37 Old 06-30-2013, 06:01 PM Thread Starter
webhostingdesig
thanks everyone!
webhostingdesig is offline
post #32 of 37 Old 06-30-2013, 07:21 PM
HandsOn
Just checked out the one on this I-6 and the pulley is split diagonally across the grooves. Looks like the actual drive section is separate from the steel hub, which does not seem to be effected.
I wonder if this is how they come (it's so clean a split it looks like a cut seam) or if it's shrapnel waiting for a place to fly?
The actual brackets on the 4.0 are multi-piece steel stamped plates, so I'm guessing cracked and broken brackets are not as common on the 4.0?
Paul
HandsOn is offline
post #33 of 37 Old 07-01-2013, 01:43 AM Thread Starter
webhostingdesig
Paul
mine's a v8 so i dont know
post #34 of 37 Old 07-01-2013, 06:03 PM Thread Starter
webhostingdesig
ok so i took off the power steering pump, i have a V8 5.2L 4x4 so it might be different for others, but my power steering pump bracket was cracked in 4 pieces and it should be easy to replace...
question:
1) can i just go to autozone or pepboys or do i need to go to the dealer or to an aftermarket for the best bracket?
post #35 of 37 Old 07-01-2013, 10:48 PM
vonericsen
I could only find a replacement at a junk yard or a dealer.
Moss Green 95 5.2l ZJ- 5.5" IRO lift, 255 75 R17 BFG M/T on JK Moabs, Mopar ECU, Mopar Tire Carrier
vonericsen is offline
post #36 of 37 Old 07-02-2013, 02:02 PM Thread Starter
webhostingdesig
they have them at the jeep dealer, in stock in my location, for $56.75. My dealer "closed promptly" at 5:30pm and i was there at 5:29pm so they lost my business and i ordered the bracket and the pulley online via ebay and saved more than $10, but will have to wait a week to get the parts. i could go today and get the parts but will not work with people who are rude. it took me all of 10-15 min to take off the power steering pump and bracket to see it broken into pieces, easy/quick fix.
post #37 of 37 Old 07-07-2013, 03:17 PM Thread Starter
webhostingdesig
Originally Posted by WhiteOut View Post
Take the belt off the idler pulley, put it around the tensioner, then put the wrench on the tensioner and loop the belt around the idler.
This worked! Thanks everyone. The original problem was the power steering bracket cracked into many pieces.
