Which zj's came with 3.73 rears? - JeepForum.com
post #1 of 17 Old 06-18-2012, 12:05 PM Thread Starter
dj_justice
I need to replace my rear in my 98 limited that has the d35 with 3.73 gears. Which other zjs came with 3.73 gears from the factory?
dj_justice is offline
post #2 of 17 Old 06-18-2012, 12:09 PM
ajmorell
ajmorell's Avatar
I think all v8 ZJ's had 3.73s. 93-95 will have a d35, 96-98 had the 44a. Also 4.0s with the tow/tow-prep package had 3.73s.
ajmorell is offline
post #3 of 17 Old 06-18-2012, 12:24 PM
sevenscrew
my 97 5.2 full time 4wd with tow package came with the 3.73 in the d44a.
1997 Limited 5.2L - SOLD
2016 2DR JK
sevenscrew is offline
post #4 of 17 Old 06-18-2012, 12:30 PM
PolkaPower
Yes all of the v8's came with 3:73's. either 44a or d 35.
PolkaPower is offline
post #5 of 17 Old 06-18-2012, 04:49 PM
greyhnd
I have a 96 ZJ Laredo 4.0L with the towing package. According to my build sheet it's equipped with 3.73 gears and Dana 35C.
greyhnd is offline
post #6 of 17 Old 06-18-2012, 06:03 PM
pincheburro956
try getting the axle out of a 96+ v8 zj...get that d44a with 3.73..nice simple upgrade...
if you can weld, find you an 8.8 with 3.73 and call it a day.
"Not a single **** shall be given."
99 WJ, 2" BB, 245/75/16 Falken Rocky Mountain ATS.
pincheburro956 is offline
post #7 of 17 Old 06-18-2012, 06:12 PM
Scopez
1994 ZJ
I think the 96-98 V8s had the D44a with 3.73s. 96-98 I6 had a D35? Not 100% sure about the I6s.
94 ZJ Laredo. 5.2 Crate engine. 6in JKS SA Lift. 33in Destination MTs. ARB Front Bumper.
Scopez is offline
post #8 of 17 Old 06-18-2012, 06:50 PM
Pugulis
All tow package option ZJ's have 3.73 gears.
[_][]☺[][][]☺[][_] RIP to my 96' Grand Cherokee Laredo 344,700 miles and welcome to my new 2001 WJ
Pugulis is offline
post #9 of 17 Old 06-18-2012, 07:50 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
All the V8s had the 3.73s.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #10 of 17 Old 06-21-2012, 12:21 PM Thread Starter
dj_justice
Is the dana44a a direct swap? Do I need to change driveshafts?
post #11 of 17 Old 06-21-2012, 12:27 PM
PolkaPower
The D35 is shorter than the 44a so you would need to adjust your drive shaft unless you have a 249 TC and you might be able to just get a DS from the doner vehicle with the 44a.
post #12 of 17 Old 06-22-2012, 02:50 PM
jdj624
if your 98 zj has the 5.9L motor it came with a dana 44a and 3:73 gears. if your thinking of find some gears out of a junk yard, your better off just getting new ones. a new ring and pinion will set you back any where between 150.00-250.00. the dana44a is different the a regular dana 44 the bearing's are not interchangeable, i don't know if the ring and pinion are the same. which ever way you go make sure it's for the 44a. if your rear end is making noises and that,s the reason for putting new gears in, unless there are teeth missing or ground down on the ring and pinion, then i new bearing set should cure the problem and cheaper. your zj also has a trac-lock in it which could be your noise problem. one other bit of advice unless you know how to set up a rear (or front) end properly let a pro do it. you need a dial caliper to set the backlash correctly. if you are wanting to swap the whole rear end to a regular dana44 hen i think but am not 100% sure a dana 44 rear end out a wrangler tj has the same track width or maybe a cherokee xj. you might have move the coil pads to match your zj .if you want PM me and i can tell you what i have done with my 98zj,there are several options for that type of rear end. but because it has a aluminum center section you are limited.
jdj624 is offline
post #13 of 17 Old 06-22-2012, 03:02 PM
PolkaPower
All V8's from 96+ have the D44a and 3:73 gears. The 5.9 have a thicker rear drive shaft though. Did all v8'scome with a track lock after 96? I know every option was on the 5.9 standard.
post #14 of 17 Old 06-22-2012, 04:32 PM
jdj624
i don't think they did, it may have been an option. but was standard on the 98 5.9l.
jdj624 is offline
post #15 of 17 Old 06-23-2012, 12:44 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Not all V8s after 96 had the trashlock.
They did all have the 3.73s.
BTW, if they had 3.73s in the rear diff, they had them in the front diff as well....unless you had a 2wd which didn't have a front diff.......or a YJ front bumper.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
rears question reeds86xj ZJ Grand Cherokee Forum 10 01-16-2012 12:30 AM
more brake dust on rears than front 07JGCL WK Grand Cherokee & XK Commander Forum 13 11-07-2007 06:07 PM
Are front lower lca's the same as the rears? bjl95mustang ZJ Grand Cherokee Forum 0 12-26-2006 10:35 AM
Front brake pads/rotors wear faster than rears acitydweller ZJ Grand Cherokee Forum 2 02-08-2006 02:12 PM
