ZJ runs only on battery. - JeepForum.com
post #1 of 14 Old 09-29-2013, 03:56 PM Thread Starter
THLL
So check engine light came on, headlights starts to dim, battery gauge slowly going down, gauges shut off then dead. Even the battery full charged it runs until the battery dies. I got the alternator tested and its great. Battery is good too. The engine code gives me a 34. What could this possibly be??
THLL is offline
post #2 of 14 Old 09-29-2013, 04:38 PM
WhiteOut
WhiteOut's Avatar
Have the battery tested. Are the grounds at the battery and alternator good?
WhiteOut is offline
post #3 of 14 Old 09-29-2013, 04:40 PM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
Check the alternator fuses in the PDC. Sounds like the alt and battery are disconnected.
HighLonesome is online now
post #4 of 14 Old 09-29-2013, 07:15 PM Thread Starter
THLL
yeah got the battery tested too and its good. Wheres the PDC? is that the fuses on the passenger door? I lost the side panel to that so anyone have a diagram?
THLL is offline
post #5 of 14 Old 09-29-2013, 07:16 PM Thread Starter
THLL
NVM I googled it. Ill start checking all the fuses. and I cleaned off the grounds
THLL is offline
post #6 of 14 Old 09-29-2013, 07:48 PM Thread Starter
THLL
Checked everything.. very weird. maybe is the ecu?
THLL is offline
post #7 of 14 Old 09-30-2013, 09:09 AM
HighLonesome
Doubt its the PCM, but could be. At idle, check the DC voltage across the battery and then the alternator. Should be exactly the same.
post #8 of 14 Old 09-30-2013, 01:48 PM
JohnnyZJ
how old is the battery?
07' JKUR rollin on 35s
JohnnyZJ is offline
post #9 of 14 Old 09-30-2013, 05:50 PM
HighLonesome
If the system voltage is slowly decreasing until stall it means the alt isn't working or disconnected. He should be measuring around 13.8+ volts at both the battery and alt.
post #10 of 14 Old 09-30-2013, 11:32 PM
rep-tile
Cash 4 Clunkers Survivor
rep-tile's Avatar
Check the belt tension. Maybe the belt isn't driving the alternator, just slipping through. Is it the 4.0? The belt must be VERY tight on the 4.0, about 180 lbs.
rep-tile is offline
post #11 of 14 Old 10-01-2013, 10:31 AM
JohnnyZJ
or the battery isn't holding a charge.
i've had 2 batteries tested that measured around 14. and they died right away when you put a load on em. one of them was my fancy 3 yr old Optima redtop........ lasted 3 years and 4 months...... just long enough to get out of warranty. best 300$ i ever spent................ (sarcasm and lies)
just saying don't overlook the obvious stuff first! no juice leads to battery/alt 90% of the time.
JohnnyZJ is offline
post #12 of 14 Old 10-01-2013, 01:09 PM
HighLonesome
no doubt...and a couple voltage measurements would tell you a lot
post #13 of 14 Old 10-01-2013, 04:01 PM
NewHorizon
I had to put an alternator on my 96 this morning. Yesterday I had the battery tested and it was good. Would not start this morning. I hooked my charger to it a few minutes then turned it over to boost and fired her up. Was running very rough and all the interior lights and such seemed dim.
I took the socket handle and tapped the alternator and everything brightned right up. I drove about 12 miles had it tested and it was bad. So, from that I gather an alternator may be in the process of quitting but work intermitently.
NewHorizon is offline
post #14 of 14 Old 10-02-2013, 05:19 PM
JohnnyZJ
k thats it. lets goto this guys house and figure out why its dying lol
JohnnyZJ is offline
