zj rough country lift + BB - JeepForum.com
post #1 of 17 Old 12-22-2008, 11:41 PM Thread Starter
soccerfreak3377
ok guys so i think ive figured out what I want. I think im gonna put on a 4" rough country lift kit with a 1" BB (to easily clear 33's), an adjustable front track bar, and longer brake lines. is there anything else ill need?
thanks
4.5" Lift, 33" BFG KM1, 15x8 Black steelies, RE adjustable trackbars, IRO Sway Bar Links, Pro Comp SS, K&N Intake, Prerunner Front Bumper, Flowmaster Super 44 with turn down, Cobra CB + PA
soccerfreak3377 is offline
post #2 of 17 Old 12-22-2008, 11:47 PM
thebgkoolio
if your talkin bout the rough country one from IRO id say you need to get yourself a rear adjustable trackbar. and maybe front upper adjustable control arms. also maybe rear swaybar extended links.
13 JKU -33's, afe exhaust, more to come
Sold: 94 zj -3.5" on 31's, bunch of other mods.
thebgkoolio is offline
post #3 of 17 Old 12-22-2008, 11:55 PM Thread Starter
soccerfreak3377
i was thinking about getting a rear adjustable trackbar, but are the rear swaybar extended links necessary?
post #4 of 17 Old 12-22-2008, 11:56 PM
thebgkoolio
maybe i mean just things i would probably buy but no, i dont think they are a necessity. lol
post #5 of 17 Old 12-22-2008, 11:58 PM
sadass
at 5", Ask Rough country for the upper front control arms or you will have front pinion angle issues. Next, be advised that you will break that front prop shaft or CVstyle driveshaft that jeep put in the v-8s , the length can not be adjusted. you will have to change to a u-joint style for about 75$ if you hit the junk yard. 50$ drive shaft out of a I-6 WITH THE 249. And then the yoke out off any zj d30 that does not use the prop shaft as a front ds.=$25
5NineZJ,35mtr/k IRO 7" LA F/R Detroit F/HP-4.56 R/Aussie 44A. ARB Snorkel/JRC Sliders/ Protofab w/9500S./Bushwhackers. Novak242 TCcable.
sadass is offline
post #6 of 17 Old 12-23-2008, 05:28 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
If you add the BB to your 4 inch lift, you're looking at new:
Brake lines
extended links for swaybars front and rear (they should be within +/- of 15 degress of level for best handling)
trackbars, if you don't already have them.
and, once you go to 33s, you'll wonder where your torque and acceleration went. If you are thinking of regearing, do the traction aids at the same time. Why? because you are already in the same area and won't have to break into the diffs more than once.
Hunter
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #7 of 17 Old 12-23-2008, 05:45 AM
sandman
alright i have direct experience with this and this kit will work with a 1" BB on top of it if you replace both front and rear t-bars. the rear is necissary because the rear RC bracket is the biggest downfall of that kit. it breaks bolts, i even drilled it out and installed some beefy hardware and it still broke bolts. i wouldnt run the RC kit alone with that rear bracket. ooh X2 on the drive shaft.
1993 Jeep ZJ. 4.0
sandman is offline
post #8 of 17 Old 12-23-2008, 10:11 AM
tbick
I did the same thing except used added 2" boost. I did get an adjustable track bar and upper adj. front control arms. I have a 6 so I cant help you with the other stuff. I used the XJ discos from RC and they worked and had the proper length. They are made for four or six inch lifts. Although, I have mine in the 4" holes.
tbick is offline
post #9 of 17 Old 02-13-2011, 09:33 PM
supniceyeah
very old post but incase anyone ever stumbles upon this in looking to do the same thing i did the rc 4" with 1.5" spacers on a 93 i6 zj so i can offer advice if needed
1993 Jeep Grand Cherokee, 4.0 liter 5.5" lift, 33x12.5 mud terrains, black steel pro comps, 231 tc, 3.73 gearing
1996 Jeep Grand Cherokee, 4.0 liter, 242 tc, stock
1987 Jeep Wrangler, 4.2 liter, stock
supniceyeah is offline
post #10 of 17 Old 02-14-2011, 12:12 AM
bigkee
Looking at doing the rc 4" plus 2" spacers on a 93...6 cylinder. It's strictly an off road rig i don't care how it does on the street. Just looking to clear 33" boggers without rubbing. I'm not worried about swaybars...but do i need extended brake lines or track bars? What about the t-case drop? Any help appreciated.
bigkee is offline
post #11 of 17 Old 02-14-2011, 09:14 AM
supniceyeah
i'm a half inch lower but i don't have extended brake lines. on top of the rc kit i had to get a front adj tb, i use hte kits sway bar end links but they arent exactly long enough haha i use them anways for now, and i havent needed a tcase drop but each rig is different.
also, if its strictly offroad then it won't matter but my rear axle is off about a 1/4" so i should get an adjustable rear tb but don't feel like spending 140 bucks for a 1/8" shift. and the 33"s should clear, i have 32"s and feel i could get 33"s under there no problem, so that extra half inch should definately clear them
post #12 of 17 Old 02-14-2011, 11:28 AM
JeepMan95ZJ
Im glad I stumbled upon this thread. I want to add 4.5" lift coils on my 2" BB on my 98 limited
2001 Jeep XJ. 4.5" R.E Superflex lift. 31" Goodyear Wrangler Authorities. Dick Cepek DC-1's
JeepMan95ZJ is offline
post #13 of 17 Old 02-14-2011, 11:37 AM
cirame1
im currently at 3.5" on my 5.9. just got 33's and am pretty much doing this. im adding a 2" bb to my lift now for 5.5" ish. i already have both adj. track bars and extended sway bar links. all im adding is some control arms from IRO and the BB. Nice way to clear my rubi's and 33's. As for the control arms im not positive on wat im doing yet im still on stock at 3.5" lift. thinking lower fixed with upper adjustables or maybe spring for full adjustables if i have the loot.
98' 5.9 slate on slate...
3.5" F>R swap, front and rear adj. track bars
17" rubicons w/ 285 70 17 inch hankook mtr's
full 3 inch exhaust w/flowmaster 40 series
242j tcase swap completed by jeeps unlimited providence,R.I.
cirame1 is offline
post #14 of 17 Old 02-14-2011, 11:39 AM
cirame1
as for gearing all of you with i6's and 33's kinda stinks but im gonna be running 33's with my stock 3.73's with my 5.9 v8 so i dont think ill have torque issues. Its fast as is with a lift and 31's.
cirame1 is offline
post #15 of 17 Old 02-14-2011, 01:49 PM
supniceyeah
all you i6 guys? mine came with 3.73's, don't be so quick to judge ; )
4in WJ Rough Country Lift JkTheItalianoWJ WJ Grand Cherokee Forum 31 12-07-2012 12:03 PM
ZJ 4" Rough Country Lift Richard1997ZJ ZJ Grand Cherokee Forum 6 01-29-2010 06:40 PM
rough country lift ? zjberry ZJ Grand Cherokee Forum 16 02-02-2008 08:10 AM
Rough Country 4" lift S_L_W ZJ Grand Cherokee Forum 5 01-24-2007 09:54 PM
Rough Country 4 incn lift BLU88 ZJ Grand Cherokee Forum 11 06-02-2006 10:57 AM
