ZJ roof rack pics/designs - Page 3 - JeepForum.com
 2Likes
post #31 of 45 Old 12-20-2008, 02:29 PM
SpeedyCat3
Survivor
SpeedyCat3's Avatar
This one cost a bit more, but is sturdy and has all the necessary hardware to install the spare on it.
I don't have mine in it though since I have the matching rear bumper with tire carrier.
_o o o o_
|_Jeep_|
(OlllllllO)
[] ---o-[]
SpeedyCat3 is offline
post #32 of 45 Old 01-31-2011, 06:32 AM
seanom
Originally Posted by Bannonjr View Post
I took 2 extra roof rack bars off a scrapped ZJ, put em on, used the front for a light bar, the 2 rear to mount my spare tire and the rear for my back up lights...cost me nothing but time...
how did you tie the tire securely? I was thinking of making something out of steel and then using a wing nut and bolt... did you just tie it?
I need to get the damn tire out of my trunk
seanom is offline
post #33 of 45 Old 01-31-2011, 07:39 AM
treycox
Here's mine. Don't really know much about it due to it being a gift. Its a smittybuilt and it sat in my father inlaws garage for a few years. Apparently he got it for like $50 through some promotion they ran years ago.
96 ZJ
treycox is offline
post #34 of 45 Old 01-31-2011, 08:57 AM
smokeyeager
Originally Posted by -cAcHe- View Post
these are the best pics i have on my photobucket right now...i have some closer ones at home. took the design from KOR!! and cost me less than half to make.
I'm working on designing a rack using google sketch up with about the same design. I was thinking of mounting a light rack up front and 1 light off the back, running all the wire through the tubing to a modified trailer wiring harness to a quick disconnect over the interior dome light. It's still in the planning phase but it should be pretty slick when it's done.
smokeyeager is offline
post #35 of 45 Old 06-14-2013, 10:45 AM
PhoenixZJ
Originally Posted by Jones View Post
Here's mine.
I wouldn't recommend putting the spare tire on the roof. A rear tire carrier would be a much better approach.
Why you shouldn't:
More difficult to get to if you need to use it.
Lowers mpg by a few miles.
Creates an even more top heavy center of gravity.
Where did you get your roof rack form? Did you get it locally in Phoenix?
PhoenixZJ is offline
post #36 of 45 Old 06-14-2013, 07:43 PM
SCZJ
1994 ZJ
I'd like to know, too. That's a great looking rough rack.
'94 ZJ, 4.0, D30/D44A, 4 1/2" lift, 32" tires, 3.73 gears, etc... Just another cookie cutter ZJ.
SCZJ is offline
post #37 of 45 Old 06-15-2013, 03:42 AM
ErikTheRad
I'm currently building my own roof rack, should be done with it in the next couple of days. I made it from 1" square steel tube that I got free from work. Its 4" deep, 54" long, 34" wide, got an X-braced rear area for the spare which uses a length of all-thread welded to the center of the X for the spare tire hold-down (will fit up to a 35" tire) and an 18"x34" area up front for cargo. All I need to do is figure out a good mounting technique and then paint it and whaa-laa, its done. Total cost = several feet of .030 MIG welding wire, a bit of argon/co2 gas, and a can of Rustoleum Professional flat black. :-) Figure it would cost well over $200 for one like it, this sucker is a serious rack--- not flimsey thin-walled Chinese crap. It weighs about 35 lbs but the strength is worth it.
ErikTheRad is offline
post #38 of 45 Old 06-15-2013, 11:25 AM
ROFLwaffles
Holy 5 year old thread resurrection Batman.... lol
ROFLwaffles is offline
post #39 of 45 Old 06-19-2013, 12:51 PM
Zakimations
I bought a custom made roof rack from someone nearby. It wasn't made for a ZJ.
This rack has a flat bottom, and the ZJ has a curved roof.
Solution: Removed stock rail system, went to local hardware store and found some perfect cone shaped rubber spacers in a small and large size. Drilled holes down through the center of them, bought longer bolts of the same size/thread as the ones that came out of the stock rails. Before I knew it I had a flat roof rack perfectly shimmed onto a curved roof. Its solid as a rock too.
IslandZJ likes this.
Zakimations is offline
post #40 of 45 Old 06-19-2013, 02:14 PM
PhoenixZJ
Very nice! That gives me a good idea on what to do with mine
post #41 of 45 Old 06-19-2013, 08:00 PM
Cherokee95kid
Here's a link to my conduit roof rack with awning. And I'm gona look into what zakimations did to mount his cause that's really smart.
http://www.jeepforum.com/forum/f13/m...wning-1533661/
Cherokee95kid is offline
post #42 of 45 Old 06-19-2013, 10:59 PM
Zakimations
I think mimicking my approach will work great. The floor of my rack is a chain-link style steel so I could run the long bolts through it with large washers to add holding strength. That's all there was to it.
If you need any measurements / bolt sizes let me know.
If you haven't already found out, the threads holding the stock rails on are actually plastic inserts. I was skeptical to whether or not they offered any real structural support but they have proven to be tough and reliable. I've been wheeling hard with a spare 32" tire on top for 2 years and they still don't have any play in them.
Whatever spacers you use, treat them like bushings. They are susceptible to dry rotting in the sun. Do what you can to make them last more than a couple years.
Cheers.
post #43 of 45 Old 06-20-2013, 03:53 AM
zjfamilyman
1) Sleeping in the back of a ZJ is awesome, I'm six foot and my feet don't get past the bumper. 2) Roof top carriers are great for guys with smaller lifts and tires, lifting a Jeep more than 3 inches will do much more to its COG than putting a tire on the roof.
I just finished mine. I found an old lift basket and hacked it up. I may ad some more structural supports later but right now it's strong and light enough for my needs, it didn't cost me more than the paint and looks pretty good imo.
Every mountain is unclimbable until it is climbed, every ship unsinkable until it is sunk.
zjfamilyman is offline
post #44 of 45 Old 07-03-2013, 06:52 PM
Jramos43
Here's mine.
Why you shouldn't:
Im in love with your truck man. Whats in it? From the tire size to rim style, roof rack and lights. and where can i get some, cuz damn bro thats a sick looking Jeep.
96 ZJ
Jramos43 is offline
post #45 of 45 Old 07-03-2013, 07:42 PM
dnuccio
Heres mine. just finished it.
its made from 3/4" 16 gauge square tube. bottom frame is 53"x44" (i have a sunroof and didnt want the rack to go over it. less wind noise that way). top frame is 44" square, and its 5 inches tall. i made the top part smaller than the bottom so i could make the front slanted to deflect trees and such while wheeling. the whole thing is very strong and i can stand on it and jump and theres hardly any flex at all (i weigh around 260lbs).
anyway heres some pictures:
made a shovel mount on it too. just some extra square tube with some holes drilled (so i can put a lock thru it) and 2 wing nuts and a little plate i made.
not mounted yet, just sitting there:
still need to paint it, it will be flat black. i will post more pictures when its all painted and mounted.
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
my 5.9 Roof rack is on lol Pics Dillonzj ZJ Grand Cherokee Forum 11 03-12-2009 04:39 AM
ZJ Roof Rack PICS........ cb2630 ZJ Grand Cherokee Forum 28 01-29-2009 12:04 PM
Pics n prices of roof rack for ZJ kjh_sweden ZJ Grand Cherokee Forum 6 12-29-2008 08:49 AM
Best roof rack for zj? Kota04SXT ZJ Grand Cherokee Forum 28 12-03-2008 02:25 PM
Durable Roof-rack vs. Trailer-hitch Rack? DenverCruiser ZJ Grand Cherokee Forum 12 01-10-2006 03:58 PM
