ZJ REAR DIFFERENTIAL issue - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > ZJ REAR DIFFERENTIAL issue
Swag Off Road BIG-HIT TJ-YJ Rear BumperThe RuffStuff "I can't go to EJS" Sale!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 12-11-2013, 05:35 PM   #1
Alexandru999
Hello guys,
My jeep : jeep zj 97 215000 km 4.0 il6 stock
Today going to work and coming back i heard an almost UN-noticeable clunk clunk (as if a ball is in a pan, rolling) coming from my rear driver site wheel, at first i thought it was my nuts going loose so i stopped afraid ill loose the wheel, all were tight ... (the low noise comes at high speeds - over 60-70 km/h)
i took it to my 4x4 usual garage, they said i need to change the WHOLE rear diff, a 1500$ job, i asked them to show me since my mechanic knowledge is limited , the ONLY problem they showed me was the "dana" thing i believe? they didnt give me exact terms just pointing finger,so ill upload a pic i took there, i call it (hole that looks like a hole in a tree holding the 4 gears that move the wheels, that "chamber" ) ok laugh they just showed me that it was a little play, thats it, "teeth" are perfect, not chipped at all ...... this car means a lot to me, my 1st car, i have it since 2006,never had problems, i change oils, everything, saved me from 2 accidents with no damage to it, its a part of me
im not bad with my jeep, but this exceeds my capabilities, anything i can do for cheap? im a broke student, they said its a "1 piece" everything, thats why so expensive, and they have to re-do brake lines, ABS, ETC that comes with the whole replacement , thats why 1,5k
please help
Alexandru999 is offline   Reply With Quote
Unread 12-11-2013, 05:45 PM   #2
riot1987
Location: In your attic, with the squirrels and wrapping paper
Holy RTV Batman
Your crosspin holding your spider (the 4 small ones inside the carrier) gears is wallowing?
Your question is hard to understand.
A DANA refers to an axle not a specific part IN the axle.
IE dana 30, 44, 60,70 ect.
http://www.jeepforum.com/forum/f22/riots-97-grand-1436100/
^build thread^
riot1987 is offline   Reply With Quote
Unread 12-11-2013, 05:46 PM   #3
CJ7-Tim
Real Jeeps have dents.
CJ7-Tim's Avatar
You can buy a good used complete axle assembly, and install it yourself using regular hand tools. That will save you about $1250.
Progressive Liberalism: Bringing you new ideas so wonderful, they have to include mandatory participation ......
Originally Posted by Ronald W. Reagan: Government is not the solution to our problem; Government is the problem.
CJ7-Tim is offline   Reply With Quote
Unread 12-11-2013, 05:54 PM   #4
riot1987
And this^^ Id pull axles from a yard all day before I paid that kinda money for an axle repair
^build thread^
Unread 12-11-2013, 07:00 PM   #5
papitt
... ME TOO I'd go to the wrecking yard and I'm an old dealer guy.. I was always that we charged folks so much to rebuild their rear end .. When we could have just got them a COMPLETE AXLE from the YARD .....
papitt is offline   Reply With Quote
Unread 12-11-2013, 07:03 PM   #6
Alexandru999
crosspin as in the pin between the spiders? no, is the "outside ring" as the arrows show, that whole chambers has a little play, BUT gears inside dont play, just the "exterior shield" if i can call it like that ..... but if a shake in that can CAUSE the 4 inside to shake, that i have no knowledge of
obviously i will not pay that much money even if i had too, yards was one of my 2nd idea as well
thanks for replies
Unread 12-11-2013, 08:14 PM   #7
joe19934
Originally Posted by Alexandru999 View Post
Hello guys,
please help
It looks like a Dana 35 and they are a lot easier to find and less money !
I'd look for a good one and swap it for a ton less $$$$$$$$$$$$$$$$$$ !!!!!!!!!!!!!
You should look for one in a junk yard
If You can't Go Around It then Go Over It !!!!!!!!!
joe19934 is offline   Reply With Quote
Unread 12-11-2013, 10:21 PM   #8
JohnnyZJ
JohnnyZJ's Avatar
bull****
tell them for 1500 they can give you a ****ing mechanical term............
its easy to swap a rear diff. done lots, blah blah blah. but you can always get a bad one from the wrecker as well.
curiousity wants to know what they said is 'bad'
swapping a diff yourself is ok if you have the tools. that includes a good jack, some 6 ton jack stands, 2 ton stands, a bunch of hand tools. its simple enough really. but 1500$ to rebuild a D35? no.
92 YJ ~ back at it
RIP 95 ZJ ~ 33s built/longarmed/locked/awesome Feb 2014 ZJOTM winner
JohnnyZJ is offline   Reply With Quote
Unread 12-12-2013, 04:52 AM   #9
coralman
coralman's Avatar
To give you an idea of whats involved look here. I got technical with it but you'll still get the gist. Click the link in my sig.
coralman is offline   Reply With Quote
Unread 12-12-2013, 07:02 AM   #10
Alexandru999
cool thanks, im still not clear, lets say THERE is basic swap, re-doing the brakes lines, abs, etc, is that true also? because i find it hard to get why if i replace for example, with an identical one, i need to re-do those things? there are no new modifications
Unread 12-12-2013, 07:15 AM   #11
KJK
There's going to be a little "play" in that so called "chamber " that is holding the 4 gears in the picture. The play is the backlash in the gears and a little is O.K. As far as the clicking sound by the wheel, it could be a bad wheel bearing or maybe a bent splash shield lightly contacting the rotor. I'd take it to another shop. I smell something fishy here.
5.9 ZJ SCT tuned PCM/ KJK CAI/ Thorley headers with 3" Magnaflow cat and muffler/ Modded kegger/ TransGo shift kit/ Vanco brake kit/ Braided steel brake lines/ Mopar cupholder insert!
KJK is offline   Reply With Quote
Unread 12-12-2013, 07:42 AM   #12
Alexandru999
yes, i will for sure visit another shop or two to get an idea before any decision / yard, as for bearings, i tried moving the wheels to see if they wobble but there was no play, they were solid from what i could tell, if i could remember the exact play, id say, 1 ~ 2 mm, what ALSO puzzles me, is if they say the issues is there, why do i get the noise exactly from the rear left end wheel ? shouldnt it be more centered? and why not both wheels?
Unread 12-12-2013, 07:59 AM   #13
KJK
I think the problem is at the left rear wheel where the sound is just as you suspect. The bearing could be just starting to go bad and not have a lot of play in it yet but still make noise. Also that axle shaft could have wear on the surface that the bearing rides on causing a noise. Not being there it's hard to diagnose but I would seriously doubt you need a whole new rear end.
Unread 12-12-2013, 06:43 PM   #14
papitt
.. While I was at the Stealership we replace a lot of wheel bearings .. ANd all the customers were told they had to have a new axle shafts at the same times.. Swap shops and find one that want to bad mouth the one you came from..
... Shops always want to Disk the Shop before them to make a customer. So if you work this story against the new shop. They'll hang themselves to give you a good deal .. Their counting on getting your business on the next job..
.. Sorry But I don't have a lot of trust in shops.
Unread 12-12-2013, 08:15 PM   #15
Alexandru999
yes, you're right ... will do so, axles,differentials is something i never touched, so this i cant do without help
thank you all for your time, i got more feedback than expected so i appreciate it !
