ZJ Quadra-Trac slips out - JeepForum.com
post #1 of 6 Old 02-12-2003, 08:43 PM Thread Starter
vngdh
When attempting to use the 4wd low on my mom's 95 ZJ v8 quadra-trac it slipped out into neutral twice. The tranny selector was firmly tugged into the slot.
Any thoughts on what kind of repair job this will take?
TIA
Dan
2000 WJ Limited: V8, QuadraTrac-II, Black with Camel leather.
Every option except 10 disk CD Changer.
Mods: K&N GenII Ram Air, Helix Powertower
Future Mods: HID level I High & Low beam, Larger Rims (undecided), Kenne Bell Supercharger (screw-type) with water injection kit (to prevent pre-detonation).
vngdh is offline
post #2 of 6 Old 02-13-2003, 05:22 AM
blackbelt
blackbelt's Avatar
If your transfer case is fine otherwise, it might be something as simple as adjusting the linkage. My ZJ was a bit out of whack, i had to pull the lever almost to the neutral position to engage full time(select-trak). Adjustment took care of the problem.
2001 XJ Sport
2007 Caliber R/T AWD
2000 Subaru Forester
2006 Scion xB
1987 VW Wolfsburg Cabriloet
1969 SAAB 96 V4
blackbelt is offline
post #3 of 6 Old 02-13-2003, 08:00 AM
Howler
I assume you mean the Transfer case is jumping into neutral and not the transmision. If it is then it is probably the linkage. When you shift make sure you are moving at about 2 MPH (slight coast) and put the Trannny into neutral then shift really hard into 4 LO. The gears in the Tcase engage better when you are moving.
Howler
97ZJ 5.2L with 5" lift. 31" SuperSwampers TSL
To boldly go were no Grand has gone before.
Howler is offline
post #4 of 6 Old 02-13-2003, 10:45 AM Thread Starter
vngdh
Whopse! Yes Transfer case not the Tranny :eek:
Thanks for the thoughts. Ill try the 2mph slip and let you know if that worked, if not I may need some info on how to adjust the transfercase linkage.
PS Yes it seems to work fine in 4 HI
Dan
vngdh is offline
post #5 of 6 Old 02-13-2003, 01:30 PM
Camster
Camster's Avatar
to get mine to go into LO i have to be moving slightly as well. make sure it's in neutral though.
Cameron
Camster is offline
post #6 of 6 Old 02-13-2003, 02:02 PM
Howler
Re: Whopse! Yes Transfer case not the Tranny :eek:
LOL We've all done that before.
As per the drivers manual you need to be moving about 2-5 MPH (not 100% sure on speed. I'm canadain and its bout 3-6 KMP ) or so. Shift transmision into neutral and firmly grab the transfer case shifter. Give a nice solid strong pull into 4 LO. You will/might hear grinding but that is normal. It is the gears aligning themselves.
Hope that helps
Howler
Howler is offline
is quadra trac/quadra drive electronically controlled? dirtdad ZJ Grand Cherokee Forum 2 01-01-2010 04:45 PM
quadra drive II or quadra trac II 2008 WK ? bill.rivard WK Grand Cherokee & XK Commander Forum 12 06-16-2009 07:14 AM
quadra drive II or quadra trac II 2008 ZJ ? bill.rivard WK Grand Cherokee & XK Commander Forum 3 11-01-2008 04:52 PM
Possible Quadra-drive/Quadra-trac II binding problems orbornhitorn ZJ Grand Cherokee Forum 3 06-06-2007 01:21 PM
Difference between quadra trac and quadra trac II? loudog3114 ZJ Grand Cherokee Forum 1 10-10-2005 12:07 PM
