Send Message Advertisers Vendors Announcements
Jeep Forum Classifieds JeepSpace Reviews Gallery Blogs Clubs Groups Videos Wiki Links Events Articles
Jeep Home Jeep Forum Jeep Classifieds Jeep Registry JeepSpace Jeep Reviews Jeep Gallery Jeep Blogs Jeep Clubs Jeep Groups Jeep Videos Jeep Wiki Jeep Links Jeep Events Jeep Articles
Moto Alliance Viper Elite 8,000lb Winch Giveaway!
Go Back   JeepForum.com > Models > Grand Cherokee & Commander Forum Group > ZJ & WJ Technical Forum
Jeep Registry Register FAQ Mark Forums Read Search Members
Old 08-26-2007, 05:11 PM   #1
BrokenLimits
Send a message via AIM to BrokenLimits
The ZJ Parking Brake Post...
I just moved to Texas from Ohio and found out that I have to have an inspection here to get Texas plates. Well my Jeep failed inspection for lack of a parking brake. To be honest I dont CARE but the state of Texas does.
So I got on here and searched some threads and found a lot of helpful information and decided to organize it and pass it on to some of you.
So here it is. For those of you like me that have a winter car you will most likely encounter this problem. The reason is, Jeep designed the parking brake system pretty crappily causing two parts to become one.
Some of you on here managed to free up the two parts and get them moving alone again but I COULD NOT.
Tools you need:
3/4" ratchet (or lug wrench) to remove tires.
13mm socket to remove brake caliper.
Here is a pic of the tools and the parts I purchased:
Now the parts I bought were:
Left and Right side metal hook,
Left and right side metal sway
(2) adjusting screws
(2) adjusting nuts
(2) adjusting shafts
I also bought all new brake shoes as you will see why when you see mine.
Step 1: Loosen lugs while car is on the ground
Step 2: Remove tire to expose brake disc and caliper (mine are brand new as I literally just replaced them)
Now you can get a good look of the hook part that is attached to the cable that actually moves your parking brake. Have a friend pull on it and make sure the cable still moves. If it does you dont need to replace the cableing (I did not have to)
Brandon
00 Civic Si and 96 Jeep GC (totaled by a Ford 10/31/05)
BrokenLimits@aol.com
1998 Chargold Jeep GC
BrokenLimits is offline   Reply With Quote
Old 08-26-2007, 05:12 PM   #2
BrokenLimits
Step 3: Remove the upper and lower caliper bolts and make sure you dont hang the caliper by the brake hose (if you have ever changed brake pads you know how to do this obviously)
Now you can see the rusty parts that are supposed to actuate the parking brake. I had already removed the shoes because I was trying to fix this problem earlier and didnt want to put my rusty shoes back on so I zip tied it for now so I could drive it.
Now the parts I have zip tied are actually TWO PARTS that are supposed to move independently. This is where the design flaw is. They FUSE together.
I used:
and absolutely COULD NOT free them up.
So I needed:
It made short work of them:
So I was able to remove them to replace them.
Brandon
Old 08-26-2007, 05:15 PM   #3
BrokenLimits
Now here is a funny side story. Here are the parts for both sides. What is different about them?
They are just the opposite right? Well for some reason one of them is in the Jeep parts database for $19.99 and the other is $55!!!!
I made a big stink about this and they made them both $19.99 for me. I dont know if its just in the system wrong or what but if you are going to order all these replacement parts beware.
Old Rusty Compared to new:
Here is the adjuster bolt, slide, and nut I replaced as well:
Put it all back together, make some adjustments with the adjuster screw you just replaced and then make some adjustments at the cabling and you should have a working parking brake
Hope this helps with some detailed pictures and whatnot...
Brandon
Old 08-26-2007, 05:22 PM   #4
BLACKzj52
good write up! and thank you!
iv been needing to fix mine too but just never got around to it/never knew what to do..
now i do
- John - 20 and learning <-- ORIGINAL
-Black 96 ZJ Limited 5.2L V8 lifted 5" and blacked out with some fun stuff
My Build Thead
The Dark Side #001
Facebook
Sophomore at The Ohio State University
BLACKzj52 is offline   Reply With Quote
Old 08-26-2007, 05:24 PM   #5
BrokenLimits
I wanted to go more in to detail but it was hot out hahaha.
Brandon
Old 08-26-2007, 05:24 PM   #6
KJsharpNH
2005 KJ Liberty
Awesome write-up... I've been needing to fix that for awhile. Thanks!
KJsharpNH is offline   Reply With Quote
Old 09-05-2007, 09:25 PM   #7
NoreasterPlus2
Send a message via AIM to NoreasterPlus2
BrokenLimits..you rock
Okay, so in the Parking Brakes for Dummies category.
Where did you get your parts, and did you just tell them..give me the stuff for my GC parking brake?
I think I may need to do some work on mine.
NoreasterPlus2 is offline   Reply With Quote
Old 09-05-2007, 09:36 PM   #8
Yardman Harry
O
Yardman Harry's Avatar
Nice write up dude! Maybe ill do this one day...
1996 Jeep Grand Cherokee. V8 - 5.2 litre 242 SelecTrac. SURCO Safari Roof Rack
Hunter Green
1997 Jeep Wrangler Sahara Ed. I6 - 4.0 litre, 4" SL, D44 rear, 4:56 Gears, AA SYE with double cardon custom rear Drive Shaft, IRO Adj CAs, Kevins Rear Adj TB with JOHNNY JOINT end
1999 Mazda Miata MX5 - Jet Black
1990 Jeep Cherokee Sport I6 - 4.0 litre
White
~Junked~
Yardman Harry is offline   Reply With Quote
Old 09-05-2007, 09:45 PM   #9
TJeeper
Great write up, went through this a couple years ago. It makes it a whole lot easier to show the pictures than explain it.
Patrick
'99 TJ "Big Jeep"
'98 ZJ "Little Jeep"
TJeeper is offline   Reply With Quote
Old 09-05-2007, 10:48 PM   #10
QuadraTokn
QuadraTokn's Avatar
1930 WJ
Send a message via AIM to QuadraTokn Send a message via Skype™ to QuadraTokn
if its similar to the WJ ill have to try it.
I have a modified 1999 WJ and a stock 2001 WJ
Tread Lightly
Pics
WJ Grand Cherokee PARTS FOR SALE!
QuadraTokn is online now   Reply With Quote
Old 09-06-2007, 04:41 AM   #11
Mooman
Thats funny, I am doing that same job on my mothers 5.2 this weekend. All the parts from napa cost me $54. Not a big deal at all unless they are froze up like yours were. Great write-up though.
Mud is Good!
Mooman is offline   Reply With Quote
Old 09-06-2007, 08:02 AM   #12
Omahastro
Coat the areas where both parts touch each other and the shaft with high temp antiseez. This will help keep the rusting down in the future.
96 ZJ Laredo Stock
4.0 I6 Engine
42R Trans
242 TC
Omahastro is offline   Reply With Quote
Old 09-06-2007, 10:25 AM   #13
kjopen
great write up! you now are the owner of a parking brake that works! mine still does since I was lucky and managed to free it up.
kjopen is offline   Reply With Quote
Old 09-06-2007, 10:32 AM   #14
nashmd454
1Cross+3Nails=4given
nashmd454's Avatar
tt was a great job of you to do helping out and writing that up...I have never had parking brakes either. Maybe now I will do them myself...my problem is that I refuse to ever go into the stealership to buy parts.
96' JGC V-8 5.2L ltd.
way too much to list.
Thought for the day:
If GOD gave HIS only son for us...can't we at least give HIM an hour of our time a day.
http://photobucket.com/albums/v639/nashmd454
http://groups.jeepforum.com/The_Dark_Side
nashmd454 is offline   Reply With Quote
Parking brake BigwillXJ ZJ & WJ Technical Forum 1 12-20-2008 07:05 PM
parking brake help....Please jeepster2000 ZJ & WJ Technical Forum 4 05-15-2008 12:57 PM
Parking brake Diehard ZJ & WJ Technical Forum 1 10-03-2006 11:54 AM
ZJ E-brake / Parking Brake Questions. Does yours stop your Jeep? Zoso ZJ & WJ Technical Forum 9 08-04-2006 12:56 AM
Parking brake adjustment in 01 Grand Cherokee? Bad brake shimmy too! JeepSam ZJ & WJ Technical Forum 7 03-10-2005 10:50 AM
The time now is 12:54 AM.
Jeep®, Wrangler, Cherokee, Grand Cherokee, and other models are copyrighted and trademarked to Jeep/Chrysler Corporation.
JeepForum.com is not in any way associated with Jeep or the Chrysler Corp.
