ZJ no start has spark and fuel pressure - Page 2 - JeepForum.com
post #16 of 24 Old 02-24-2011, 02:54 PM
Fisheadstew
Mine ended up being the coil. I changed the cap and rotor first, pulled the fuel pump relay... same thing, cranked with no start.
Then changed out the coil, cranked and it sputtered and belched a few times. So I pulled the plugs which were of course soaked,
and ran for a new set.
Replaced the plugs and it started right off, put the fuel pump relay back in and the rest as they say is history
Started right up this morning ready for another 229k !
Thanks, Fish
Fisheadstew is offline
post #17 of 24 Old 02-24-2011, 03:05 PM Thread Starter
greentank
Fish, glad to hear there is another jeep still on the road
as for mine the noise does not go away after it has warmed up. I just had it running for about an hour while i tried to figure out where the noise was with a stethoscope. so far no luck it does sound like it is louder from the bottom side of the engine. (of course everything is loud under the engine when its running) it doesn't seem to miss at an idle, but if you rev the engine, or try to drive it the engine is all over the place.
one other thing, after running it a few times i no longer need to hold the throttle open to get it to fire.
greentank is offline
post #18 of 24 Old 02-24-2011, 03:25 PM
SGTCornewell
2002 KJ Liberty
if your having trouble tracking a noise, put a vacuum gauge on the engine. if its a valvetrain problem the needle will tick for you. if not, it will be steady. a good engine should read between 16-20 in of smooth vacuum on idle. i love my vacuum gauge
SGTCornewell is offline
post #19 of 24 Old 02-24-2011, 04:54 PM
Fisheadstew
Be sure and check your oil for gas, mine was loaded... to the point I could light it!
Hope it's just a lifter *****ing about the thinned out oil.
Fish
post #20 of 24 Old 02-25-2011, 09:07 AM
SGTCornewell
2002 KJ Liberty
this is more known with ford explorers but if your fuel pressure regulator blows out your fuel pump can pump your crank case full of gas through your vacuum lines.
post #21 of 24 Old 02-25-2011, 02:21 PM Thread Starter
greentank
for an update, i decided to 100% retrace my steps back to the crank sensor. I found that the flywheel had been hitting the flywheel. I'de say that the probability of that being the cause of the noise and maybe the misfire are pretty good. going to cross my fingers, go out in the snowstorm and venture to the dealership to get a factory replacement crank sensor.
post #22 of 24 Old 02-25-2011, 07:01 PM Thread Starter
greentank
OK so as a final conclusion. The original problem apparently was the Crank Position Sensor. I used an after-market CPS that was not a good fit. The noise, and misfire that I was experiencing was due to it rubbing the flywheel. I found that the dealer didn't have one in stock so i exchanged the bad one for another the same brand, and all is well. So If anyone ever ends up with a miss/ noise after using a after-market CPS check that first you may save yourself a lot of time.
post #23 of 24 Old 02-25-2011, 08:24 PM
Fisheadstew
Great news, glad it wasn't more serious.
What was the brand of the defective unit?
Fish
post #24 of 24 Old 02-25-2011, 08:30 PM Thread Starter
greentank
it was a Borg Warner, which Is actually a very reliable brand in my past experience. I guess everyone puts out a bad one here and there. Like I said I couldn't get on from the dealer so i tried another BW and it worked.
thanks everyone for the help.
cps , ignition , no start
Jeep GC 93' 4.0 no start, cranking but no fuel pressure! Curry ZJ Grand Cherokee Forum 15 05-25-2015 05:09 PM
96 grand cherokee w/ good spark and fuel but won't start trh4989 ZJ Grand Cherokee Forum 7 02-14-2010 06:28 PM
4.0 cranks but does not fire have fuel pressure at rail but no spark from the coil 98whtgcl ZJ Grand Cherokee Forum 4 09-10-2009 12:34 PM
94 ZJ 4.0 Won't Start - No Fuel Pressure bja_zj ZJ Grand Cherokee Forum 5 03-01-2009 04:23 PM
Fuel pressure, spark, no start dirt machine ZJ Grand Cherokee Forum 23 02-24-2007 09:53 PM
