Zj no crank no start - Page 2 - JeepForum.com
post #16 of 26 Old 08-23-2013, 07:23 PM
Uniblurb
Uniblurb's Avatar
Originally Posted by ZeeJay1997 View Post
Quick Cable Fusion
git ye sum
dem do look like real good'uns!
So do you buy direct from them or are they available retail somewhere else? And what size would you buy that fits 2 wires like our cables? Thanks!
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 96 4.0 XJ (son's)
Uniblurb is offline
post #17 of 26 Old 08-24-2013, 06:16 AM
JeepNicholson
I ordered my lugs from here since they have no minimum order -
http://www.delcity.net/store/Fusion-...-Lugs/p_804211
But I guess you're looking at the terminal clamps themselves
http://www.delcity.net/store/Straigh...inals/p_804069
They arrived in about 5 days, including a weekend (pretty fast!)
I got 4 of the 4-6 gauge lugs and did each cable individually. If you plan on joining two stock cables into one lug/terminal you'll want the 1/0 gauge, and if you opt for lugs be sure to get the right lug size to fit the bolt it will attach to, for example my military terminals were 3/8". And be aware that the positive and neg terminals are different if you didn't know already :-)
Here's a pic of mine, finished-
http://i1287.photobucket.com/albums/...ps7bd89609.jpg
Though it's less blurry in real life lol
ZJ FSM
https://drive.google.com/folderview?...Fk&usp=sharing
JeepNicholson is offline
post #18 of 26 Old 08-24-2013, 09:46 AM
Uniblurb
Uniblurb's Avatar
ZJ FSM
Thanks for all the links/info JeepNicholson and you have a great looking terminal setup! Pretty evident you ran new/larger gauge cable and like those military style terminals.
So if I just used the existing/OE cables with the straight battery terminals I'd just order a 1/0 pos and a 1/0 neg straight terminal while the 2 cables in each would fit? Pretty nice all their lugs/terminals are pre-loaded with flux/solder. Thanks again!
Uniblurb is offline
post #19 of 26 Old 08-24-2013, 10:14 AM
JeepNicholson
Yep, two 6 gauge cables should pack nicely into a 1/0 neck. Don't forget to put your heat shrink on the cable before you solder, and keep it far back from the ends while you solder, otherwise the cable will get warm enough to shrink it before it's in the right place.
post #20 of 26 Old 08-24-2013, 10:33 AM
Uniblurb
Uniblurb's Avatar
Real good point and where do you buy the HD heat shrink?
Uniblurb is offline
post #21 of 26 Old 08-24-2013, 10:45 AM
JeepNicholson
The place I linked above has it, or Grainger, even Lowes might have it. Or any industrial electrical supply place (probably not Radio Shack though, they've got tubing but not heavy duty).
post #22 of 26 Old 08-24-2013, 10:52 AM
Uniblurb
Uniblurb's Avatar
Ok, thanks for the info!
Uniblurb is offline
post #23 of 26 Old 08-24-2013, 11:11 AM
JeepNicholson
No problem, man.
If you're not taking the cables out first, be vigilant to keep the tip of that fire away from anything that will melt, hoses, wires, plastics!
Hmm what other tips can I think of... I didn't have a helper, so I put the lug open side up in some vise grips and set those on a cement paver so I didn't catch my bench on fire. Grabbed the cables with some channel locks (they'll get too hot for hands) and put the cable ends as far into they lugs as they would go, hit the lug and cable end with the torch until the flux bubbled, and pushed the cable in as far as it would go, which was 7/8" (but might be different for the terminal ends). Then I just held it for about 30 seconds to cool enough not to pull back apart. You'll have to wait like another five minutes for it to be cool enough to get the shrink tube over, oh and make sure your tube is large enough to get over the terminal neck, not just the wire!
Ok, well now I'm just starting to ramble....good luck, let us know how it turns out!
post #24 of 26 Old 08-24-2013, 11:48 AM
Uniblurb
Uniblurb's Avatar
No problem, man.
Yeah, when I soldered my crappy neg terminal on I was real careful where pointing the torch and put a board on the battery tray since didn't need any hot solder dripping/melting into the vacuum reservoir. In fact I even put my portable vise on the board to hold the hot terminal with vise-grips holding the cable to it.
May not get to it right away but will let you know how it goes!
Uniblurb is offline
post #25 of 26 Old 08-24-2013, 12:06 PM
ZeeJay1997
the shrink tubing with sealant inside is the ticket. this may be what y'all mean by heavy duty...
ZeeJay1997 is offline
post #26 of 26 Old 08-24-2013, 12:20 PM
JeepNicholson
Yessir, adhesive lined double wall
Just for kicks, here is what battery terminals shouldn't look like, and are probably why mine used to turn over 5 or 6 times before starting.
http://i1287.photobucket.com/albums/...ps3c38424e.jpg
Now it turns over one time, every time!
