Zj no crank no start - JeepForum.com
post #1 of 26 Old 08-22-2013, 08:23 PM Thread Starter
bustedasszj
When I try to start my 95 zj I get one lone click. I just put in a new battery and starter. Solenoid is good I'm stumped
bustedasszj is offline
post #2 of 26 Old 08-22-2013, 09:30 PM
two98ZJs
First, swap the starter relay with one of its black box cousins. Try the start key. Next,
Get someone to help you start it by doing the old starter tap. Slide under the vehicle with a hammer and when the person on the ige key turns and you hear the click, rap the starter body with a firm knock a couple of times and see if you can jar the rotor off of the dead spot if this is the problem.
How old is the starter? Sounds too, may be the solenoid (starter relay).
"Don't fight a battle, if you don't gain anything by winning". (German General)
"Isn't a 'near-miss' somewhat of a 'hit'??????"
two98ZJs is offline
post #3 of 26 Old 08-22-2013, 09:36 PM Thread Starter
bustedasszj
Brand new starter and flip flopped solenoids
post #4 of 26 Old 08-22-2013, 10:15 PM
JeepNicholson
Keep in mind that many "new" starters are actually rebuilds, and some of the cheaper rebuild companies must not check their work. Last time I had to change one, the first two new ones I got didn't work at all. Third one worked just fine. Not saying that's definitely the issue, but a possibility.
ZJ FSM
https://drive.google.com/folderview?...Fk&usp=sharing
JeepNicholson is offline
post #5 of 26 Old 08-23-2013, 05:11 AM
Rich93ZJ
Have you tried starting in neutral. May be your NSS...
93 ZJ 5.2V8 3.5 iro 31x10.5
08 Silverado 6in lift 35's
Rich93ZJ is offline
post #6 of 26 Old 08-23-2013, 05:15 AM Thread Starter
bustedasszj
Tried it nothing just the one click
post #7 of 26 Old 08-23-2013, 05:19 AM Thread Starter
bustedasszj
Same thing one click in neutral
post #8 of 26 Old 08-23-2013, 06:40 AM
Rich93ZJ
Make sure your battery terminals are clean and making good contact. If they look good clean them anyway.
Rich93ZJ is offline
post #9 of 26 Old 08-23-2013, 07:33 AM
Uniblurb
Uniblurb's Avatar
What size engine and are you using the OE cables? Check your grounds like the one on the inner fender next to the battery and the one on the front/side of the engine block which leads from the negative terminal.
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 93 4.0 XJ (spare), 96 4.0 XJ (son's)
Uniblurb is online now
post #10 of 26 Old 08-23-2013, 07:38 AM
JeepNicholson
Have you tried jumping the starter directly from the battery?
post #11 of 26 Old 08-23-2013, 07:39 AM
thegipper
Definitely check the battery terminals and the grounds. My grandprix randomly wouldn't crank right after I just got done driving it. After hours of searching, it ended up being corroded grounds. Cleaned them up and it immediately fired up.
I would be willing to bet its a bad ground, start there....
PS - When I say battery terminals, make sure you check not only the part that makes contact with the battery but the cable itself. Sometimes the corrosion goes into the cable itself.
GL
thegipper is offline
post #12 of 26 Old 08-23-2013, 01:53 PM Thread Starter
bustedasszj
Yeah ended up being a loose cable in the terminal just over thought the whole thing
post #13 of 26 Old 08-23-2013, 04:18 PM
Uniblurb
Uniblurb's Avatar
Kinda the reason I asked it you still have OE cables on it. If you're using those crappy terminals with the 2 bolts w/metal plate on the top, like I have on my neg cable, the regular ones seem too small for 2 ground cables and the HD truck ones are too big.
I spent forever flipping the metal piece over, pounding it out straight, even pounded a big lead fishing sinker flat to take up the slack/space. Finally removed the battery and soldered the cables right to the terminal with a propane torch. Still was able to have the metal plate on the top and you have to watch you don't melt the lead. Swear someday I'm going to get new/good cables.
post #14 of 26 Old 08-23-2013, 06:44 PM
ZeeJay1997
Quick Cable Fusion
git ye sum
ZeeJay1997 is offline
post #15 of 26 Old 08-23-2013, 07:15 PM
JeepNicholson
Originally Posted by ZeeJay1997 View Post
Quick Cable Fusion
git ye sum
Yep, easy peasy!
