ZJ long arm suspenion quiz time ;) - Page 2 - JeepForum.com
post #16 of 22 Old 04-18-2013, 06:57 PM Thread Starter
Maine1994ZJ
Originally Posted by riot1987 View Post
I could give you measurements off mine if you want? I have 4 link rears and 3 link or triangulated ..I believe they're called.. up front
That would be awesome, man!!! I'd appreciate it!!
If you're getting a plasma cutter, all I can say is.... I'm jealous....
'93 V8 ZJ Mountain Goat Edition.
'95 V8 ZJ Limited, '97 4.0L ZJ TSi
'96 4.0L 2wd XJ, '88 4.2L YJ
Maine1994ZJ is offline
post #17 of 22 Old 04-18-2013, 07:06 PM
riot1987
front uppers-14.5"
front lowers-25.5
rears-35"
Build thread^^
riot1987 is offline
post #18 of 22 Old 04-18-2013, 07:17 PM Thread Starter
Maine1994ZJ
Excellent! Thank you very much!!!
post #19 of 22 Old 04-18-2013, 08:07 PM
WhiteOut
WhiteOut's Avatar
Do a lot of practice before you do actually work on the arms and cross member. You don't want poor welds.
WhiteOut is offline
post #20 of 22 Old 04-18-2013, 08:09 PM
riot1987
^^this
Build thread^^
riot1987 is offline
post #21 of 22 Old 04-18-2013, 08:37 PM Thread Starter
Maine1994ZJ
I certainly will!! I have dozens of ideas of things to build for the ZJ!
I'm almost done building the roof rack light bar I designed with a Hi-Lift jack mount that swings out and down for standing height access to the jack.
I have been practicing quite a bit. I rebuilt my wife's ZJ's rockers with 1/8"x3"x4" steel tubing. I connected them to the main unibody with 4"x6" tubes I built from 1/8" flat stock.
Some of my welds look professional, MOST of my welds look okay, and then I had a few that looked like a 5yr old welded them... I ground them down and started over again.
That's the beauty of steel work, if you botch the weld, grind/cut it out and try again
post #22 of 22 Old 04-18-2013, 08:57 PM
JohnnyZJ
36"
07' JKUR rollin on 35s
JohnnyZJ is offline
