ZJ long arm suspenion quiz time ;) - JeepForum.com
post #1 of 22 Old 04-17-2013, 10:28 PM Thread Starter
Maine1994ZJ
So, being the creative guy with a newly acquired welder that I am and considering that the '93(Weezy) has CAs & bushings that are falling apart, I've decided to build my own lift kit.
Plus, I need more welding practice... Hahahahaha
I'll be taking the 3" BB out of the '94(George) and returning him to stock configuration. I plan on using the BB in Weezy, but with her Upcountry springs, I'll be in the neighborhood of 4" of lift.
Too much for stock CAs. Does anyone have(or know someone who does have) a ZJ 4" LA lift that they could give me the CA measurements off, from bushing center to bushing center, upper and lower, front and rear?
I figure 1/8" thick tubing should suffice?? Track bars would be made of the same tubing with adjusters at one end.
Possibly 1/8"x1.5"x1.5" square tubing with another 1/8"x1.5" strip welded to the bottoms of the lower CAs, just for a little extra protection.
Any help would be greatly appreciated!!!!
'93 V8 ZJ Mountain Goat Edition.
'95 V8 ZJ Limited, '97 4.0L ZJ TSi
'96 4.0L 2wd XJ, '88 4.2L YJ
Maine1994ZJ is offline
post #2 of 22 Old 04-17-2013, 10:50 PM
biggoofy
This ought to be good. 1/8" is no wear near enough material for long arms they will fold like tin cans.
Zack
98 Slate Grey 5.9
96 ZJ HP44 / 9" (RIP)
90 XJ on 33s (sold)
biggoofy is offline
post #3 of 22 Old 04-17-2013, 11:06 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
lowers should be 2"x.250 wall round or 2x2x.250 wall square. uppers can be 1.5"x.250 wall the round will be less expensive as it's less weight, but the square is slightly stronger in the areas that matter.
do not use black pipe or conduit. use hrew, DOM, or chromoly DOM. or solid aluminum if you've got the change to spare.
1.5" dia tube is just not strong enough for lowers.
ratmonkey is offline
post #4 of 22 Old 04-17-2013, 11:14 PM Thread Starter
Maine1994ZJ
Thickness suggestions? 1/4"? 5/16? Hence the ??? in the original post...
Stock CAs are only 18ga or 20ga IIRC. Yes, they are taller than 1.5", by probably a good inch+.
post #5 of 22 Old 04-17-2013, 11:21 PM Thread Starter
Maine1994ZJ
Thanks!! Much appreciated!!!! That's exactly what I wanted to know!!! Notes taken!!!
Don't suppose you know the lengths, by any chance??
Oh, any recommendations on bushings to use???
Again, Thanks!!!
post #6 of 22 Old 04-18-2013, 12:04 AM
kg6mov
Hears the voices
kg6mov's Avatar
http://www.ruffstuffspecialties.com/catalog/
kg6mov is online now
post #7 of 22 Old 04-18-2013, 12:10 AM
kg6mov
Hears the voices
kg6mov's Avatar
This would probably be a good place to start: http://www.ruffstuffspecialties.com/...g/4LKTUBE.html
post #8 of 22 Old 04-18-2013, 05:38 AM
jtackerman28
You don't really need long arms at 4"
3.5 re lift, double sheer front tb, 31" wrangler duratecs
jtackerman28 is offline
post #9 of 22 Old 04-18-2013, 05:47 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Again, Thanks!!!
Use joints. Bushings put too much stress on brackets with a suspension that can travel as much as a Long arm system.
Use Currie joints, they're worth the money.
At 4" the front will probably be OK, but the rear will contact the body at less then full stuff.
The arms will be as long as they are. For the front most places replace the transmission cross member with a control arm mount set up.
post #10 of 22 Old 04-18-2013, 06:53 AM
Technohead
Huh????
-Eric
Technohead is offline
post #11 of 22 Old 04-18-2013, 09:08 AM
rooster51
Look again at the geometry, LA's will be much better
Terry
rooster51 is offline
post #12 of 22 Old 04-18-2013, 09:13 AM
riot1987
Im just over 4" with LA's
Build thread^^
riot1987 is offline
post #13 of 22 Old 04-18-2013, 07:14 PM Thread Starter
Maine1994ZJ
Thanks again!!
I'm gonna spend some time checking out LA kits and do some more research.
I shoulda bought a welder years ago... Building stuff is a blast!!
post #14 of 22 Old 04-18-2013, 07:18 PM
riot1987
Thanks again!!
I ****ing love building **** too man. Welding is awesome. Im SOO stocked to get a plasma cutter soon. Then ITS ON
Good luck man!
Build thread^^
riot1987 is offline
post #15 of 22 Old 04-18-2013, 07:20 PM
riot1987
I could give you measurements off mine if you want? I have 4 link rears and 3 link or triangulated ..I believe they're called.. up front
Build thread^^
riot1987 is offline
