zj long arm kits - Page 3 - JeepForum.com
post #31 of 46 Old 04-18-2012, 12:53 AM
Emac
x2 . I'm considering the IRO 5.5" LA ( http://www.ironrockoffroad.com/Merch..._Code=IR-Z5CPK ) or the RC 4" LA "extreme travel kit" ( http://www.roughcountry.com/jeep_zj_4xla.html ) Id rather fab some and save money but this is my first mod on the zj and I figure I might as well get a kit cause I don't weld...yet. Ive heard the 4" RC x-flex kit needs track bars, more CA's, brake lines and other junk so it seems worth it to get the full long arm kit. I'd end up spending about 400 bucks less after piecing the x-flex kit together. Does anybody have either the IRO 5.5" long arms or the RC Extreme Travel? I know there are plenty of discussions on this topic but none specific to either of these kits for the zj. Thanks for the input.
Emac is offline
post #32 of 46 Old 04-18-2012, 11:06 AM
gabrod72
I just punished my IRO kit and it performed great on the rocks. I never needed to romp on the throttle ever getting around some boulder littered trails. I've also got a locked rear and 35" Goodyear MT/Rs so that helped a ton, but on short arms I would have probably broken something considering how difficult the trails were. The IRO LA kit has made me a real believer in long arms... there's just no comparison for off-road ability - no way, no how. Unfortunately, it's the only setup I've tried, and the design for the rear long arms could be better like Claytons but then you have to weld it in.
As for the RC extreme travel LA system, it has some design concerns IMO. Mostly, the front subframe is designed in a way that it's one piece. Servicing the transmission and transfer case will be a PITA without removing the front long arms and subframe. The rear doesn't seem to be as secure as IROs since it doesn't use a subframe, only has two LA mounts that bolt into the unibody. This one is argueable for strength though. Where the RC kit outshines IRO is it is much cheaper. IROs is proven though.
gabrod72 is offline
post #33 of 46 Old 04-18-2012, 02:21 PM
nickszj
Aee you running the full IRO long arm setup or long up front and short out back?
1998 ZJ 5.9 limited in white. M1 intake and $20k+ mods brewing up in my head... SOLD
Looking for the right WJ to build into an expedition rig....
nickszj is offline
post #34 of 46 Old 04-18-2012, 02:52 PM
gabrod72
Full front and back LAs.
gabrod72 is offline
post #35 of 46 Old 04-18-2012, 03:56 PM
Dyn0mitemat
If I absolutely *HAD* to buy a kit, I'd get a rock krawler or TNT 3-link xj front and make it work, and then claytons rear.
That being said, I chose to build all of mine that way. If I had to pay for all the metal I wouldn't have saved much over buying the above. Just the joints alone (went with full rock krawler krawler joints) were $500+
09 Rubi 2dr:MetalCloak2.5", 37"MTZ's/Slabs, EVO Stff, ORFab Cage, Chromo's, Driveshafts etc
Dyn0mitemat is offline
post #36 of 46 Old 04-18-2012, 07:08 PM
biggoofy
Clayton's!!!!!
Zack
98 Slate Grey 5.9
96 ZJ HP44 / 9" (RIP)
90 XJ on 33s (sold)
biggoofy is offline
post #37 of 46 Old 04-18-2012, 09:53 PM
BigSteve
Do any of you guys have any experience with the Full Traction long arm kit? http://full-traction.com/detail.php?...CTID=395&NOTES= I like the idea of full bolt on, but the way that rear axle piece bolts on seems kind of iffy. Then the price is more expensive than the Clayton kit.
BigSteve is offline
post #38 of 46 Old 04-19-2012, 12:14 AM
nickszj
Steve-after staring at it for a while, I do like that kit....a lot! Price is steep though.... I wish it were $500 cheaper and I would buy it!!
nickszj is offline
post #39 of 46 Old 04-19-2012, 08:58 AM
BigSteve
That was my thought exactly. I mean for the price you might as well buy the clayton kit and have it welded on.
BigSteve is offline
post #40 of 46 Old 01-11-2014, 09:14 PM Thread Starter
insaneshane
Well I finally got a long arm kit and installed it
I went with the Rubicon Express 4.5" kit looks great but haven't used yet because now I have to do next upgrade do to the long arm kit
insaneshane is offline
post #41 of 46 Old 01-11-2014, 10:27 PM
JohnnyZJ
what mod is that? tcase?
congrats. welcome to the long arm club. you're one of the cool kids now
07' JKUR rollin on 35s
JohnnyZJ is offline
post #42 of 46 Old 01-11-2014, 10:33 PM Thread Starter
insaneshane
To bad there's so much more I want to do b4 I start using it
Better open up the checkbook I guess lol
Thanks I'm glad it's started
post #43 of 46 Old 01-11-2014, 10:53 PM
JohnnyZJ
hahahahahaahha.
go get one of those airmiles/rewards credit cards. then at least after you've spend a small fortune on jeep parts you can get the wifey a little something for free via gift cards to justify the spending ask me how I know..........
JohnnyZJ is offline
post #44 of 46 Old 01-11-2014, 11:02 PM Thread Starter
insaneshane
Gotta have a wife first
Haven't found one of those yet
I bet your wife gets spoiled with how much you've probably spent on your jeep
post #45 of 46 Old 04-28-2016, 06:59 PM
Jeep4ever4x4
Hey I know this thread is old but I wonder how you like your long arms kit? I got a ZJ 1995 and I am thinking to go LA lift kit
Jeep4ever4x4 is offline
lift kit , long arm
How long does a code stay in memory *LONG* Death-Mobile ZJ Grand Cherokee Forum 8 07-20-2009 07:47 AM
Looking for pros + cons on long arm kits for WJ Ned97sahara ZJ Grand Cherokee Forum 17 05-02-2007 05:14 PM
Long travel susp kits for WJ? Z0RR0 ZJ Grand Cherokee Forum 4 04-09-2007 03:02 PM
Long arm kits Pros, Cons, recomendations? Sure Shot ZJ Grand Cherokee Forum 19 11-21-2006 03:11 PM
Kevin's vs. RE Long Arm Kits ZJeepThing ZJ Grand Cherokee Forum 4 06-21-2005 09:32 PM
