zj long arm kits - Page 2 - JeepForum.com
post #16 of 46 Old 03-15-2012, 03:03 PM
gabrod72
Why would anyone want long arms if their short arm 5"+ lift on short arms drives beautifully on and off road??? I mean really, what's the point of arguing that SA works well at that height one day, then come back saying that LAs are in progress??? Sorry, I'm naturally just a little bit confused on this one.
gabrod72 is offline
post #17 of 46 Old 03-15-2012, 04:41 PM
Technohead
Originally Posted by gabrod72 View Post
Why would anyone want long arms if their short arm 5"+ lift on short arms drives beautifully on and off road??? . . .
Because then you can be one of the cool kids!!!
-Eric
Technohead is offline
post #18 of 46 Old 03-15-2012, 07:12 PM Thread Starter
insaneshane
I'm starting to lean towards the BDS now next problem I have the 249 transfer case and it says won't work with this kit and I read bad things about this transfer case
insaneshane is offline
post #19 of 46 Old 03-15-2012, 07:31 PM
Technohead
The main issue with the 249 and lifts is the CV driveshaft. All the extension is built into the CV and after lifts greater than about 3.5" there is not enough travel. Easily fixed with a Cardan style driveshaft.
-Eric
post #20 of 46 Old 03-15-2012, 08:30 PM Thread Starter
insaneshane
Cool sounds like an easy fix
Thanks for the input
post #21 of 46 Old 03-15-2012, 09:24 PM
PurpleZJ
run away from the Rough Country kit IMO. One piece crossmember is a terrible design if you need to drop the trans or tcase you'd need to drop the suspension as well.
1996 ZJ- 4.0, AX-15 5SPD/NP242, RE 4.5" lift, 36x12.50x16.5 Goodyear military surplus tires, Longarms/Tri-4 link/one ton axle build/swap in progress, arb bumper, a bunch of other goodies
1995 XJ- 4.0 HO, ax-15(stolen for swap), stock
2001 GMC Sonoma-RIP...
2002 GMC Sierra 1500 ECSB-roadtrip/long haul vehicle
RIP Troy (bigbluezj94) you wont be forgotten
December 2010 GCOTM
5spd ZJ Club Member 001
Glad you are ok. If you were a cat, you would be down to 8.:D
Originally Posted by Greengc4x4 View Post
Everything looks great, Hellen Keller! :D
Originally Posted by rritch View Post
plastic + Fuel + Ignition = "Bubba wake up this is gonna be good" :rofl:
RIP William Anthony Kolich(DAD)
you were the best father i could have wished for. I'll always miss you
04/28/58-2/13/11
PurpleZJ is offline
post #22 of 46 Old 03-15-2012, 09:43 PM
gabrod72
Agreed. If you have a tranny or t-case issue and expect to pay someone to do it for you, it can be a total loss based on most reasonable labor rates. On the other hand, it will still suck if you're the one who pulls the tranny or t-case and takes it to someone to fix it. Even sucks if you're the one who pulls and fixes because then you'll have around 3x the wrenching needed to get to either - I can go on and on here.
gabrod72 is offline
post #23 of 46 Old 03-15-2012, 10:13 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
Originally Posted by MilanJeep View Post
I am speaking from experience. I'll be sure to take pictures when I'm all done and send them to you...you might learn something
A long as you don't use quality joints, shocks, and springs.
I did the math myself, my time was worth more that their time and profit margin. So i worked two weekends to pay for it.
ratmonkey is offline
post #24 of 46 Old 03-18-2012, 11:28 AM Thread Starter
insaneshane
Has anyone used the BDS kit ??
I'm really starting to like the triangulated 4 link of Clayton but needs to get welded in which is ok I have a good friend with the fancy welders and great welder just was trying to have a bolt on kit so I could move it to a different zj if need be. So if I'm welding in the rear I think the front should be welded in too.
Is the Clayton front bad if people tend to go IRO front and Clayton rear??
post #25 of 46 Old 03-18-2012, 12:50 PM
psyviperx
I dont think anything with Clayton's name on it could be called bad...
04 Overland | K&N Intake | Kumho AT51
(Hers)
97 TJ Sport | D30/35 | Mods incoming...
(His)
psyviperx is offline
post #26 of 46 Old 03-18-2012, 08:46 PM
sammyb123
Was wondering the same why would one prefer an iro front to a Clayton front or vice versa
sammyb123 is offline
post #27 of 46 Old 03-18-2012, 11:42 PM
Technohead
Clayton is stronger and adjustable. IRO is cheaper.
-Eric
post #28 of 46 Old 03-19-2012, 06:43 AM
biggoofy
Clayton is better than iro IMO since when you wanna swap out the d30 you wont need new long arms.
Zack
13 JKU Stock
93 ZJ F/R Long Arms, 4.56 gears
96 ZJ HP44 / 9" (RIP)
biggoofy is offline
post #29 of 46 Old 03-19-2012, 11:27 AM
sammyb123
Clayton seems like the better deal in the long run if you want to upgrade the rest of the drive line.I know I wouldn't want to spend an arm and a leg on a confirm kit just to have to rebuy it down the road
post #30 of 46 Old 03-19-2012, 01:35 PM Thread Starter
insaneshane
Thanks guys
This discussion is going good in helping me decide what kit to run
Sounds like I'm going to end up with a weld in kit. I better start brown nosing my bud so he'll do the welding for me. LOL
lift kit , long arm
How long does a code stay in memory *LONG* Death-Mobile ZJ Grand Cherokee Forum 8 07-20-2009 06:47 AM
Looking for pros + cons on long arm kits for WJ Ned97sahara ZJ Grand Cherokee Forum 17 05-02-2007 04:14 PM
Long travel susp kits for WJ? Z0RR0 ZJ Grand Cherokee Forum 4 04-09-2007 02:02 PM
Long arm kits Pros, Cons, recomendations? Sure Shot ZJ Grand Cherokee Forum 19 11-21-2006 02:11 PM
Kevin's vs. RE Long Arm Kits ZJeepThing ZJ Grand Cherokee Forum 4 06-21-2005 08:32 PM
