Zj lift question - Page 2 - JeepForum.com
post #16 of 27 Old 05-01-2013, 03:30 PM Thread Starter
Skinnykid19
Finally!!! thank you I get a answer thanks everyone for your help
Skinnykid19 is offline
post #17 of 27 Old 05-01-2013, 06:33 PM Thread Starter
Skinnykid19
My jeep does have a tcase drop
post #18 of 27 Old 05-01-2013, 11:43 PM
bigb229
Originally Posted by ZJMatt View Post
Stock control arms on 5" of lift is fine? At that point you prettymuch have the wheelbase of a VW Bug! And good luck getting even 31s to clear your rear fender wells in the front. Also lifted vehicles do not align the same way as stock. Your caster is going to be different, which you adjust by the control arms. On the factory setup the only thing you can adjust is toe which is easy enough to do at home.
Haha. This guy! Alignment specialist huh? You can adjust caster with stock arms. I've done it up to 4.5" with no problem
bigb229 is offline
post #19 of 27 Old 05-02-2013, 08:50 AM
PolkaPower
Take the T case drop off. I wouldn't go over 3" with stock arms. Been there done that with a front to rear swap on my first ZJ. I ended up buying all the right parts later. Don't listen to this guy it's bad advice /\
PolkaPower is online now
post #20 of 27 Old 05-02-2013, 09:04 AM
WhiteOut
WhiteOut's Avatar
I wouldn't be calling people out for giving what you think is bad info. You just suggested that doing an alignment and balancing the tires will cure death wobble.
WhiteOut is offline
post #21 of 27 Old 05-02-2013, 12:03 PM
EOD-97-ZJ
Agreed
97 4.0 ZJ All adjustable JKS CA's, TB's, and Disco's, Rancho Stabilizer, Full-Traction Springs.
98 5.9 ZJ soon to have above list.
EOD-97-ZJ is offline
post #22 of 27 Old 05-02-2013, 02:11 PM
ZJMatt
Mind explaining that then? That's not only from my experience (backyard mechanic - I never said I was an alignment specialist) but also what I've been told from a former jeep tech, and alignment techs at two different Chrysler/Jeep dealers and a chain store. If the chain guy didn't know what he was talking about I'd believe that but two dealership techs? Technically yes I was wrong, you can adjust it a little with the elongated hole, but certainly not enough to make up for 4.5"
The "Mall Crawler" - 1998 ZJ Grand Cherokee 5.2 V8, 5.5" LongArms, 32s, 12000lb winch & more.
ZJMatt is offline
post #23 of 27 Old 05-02-2013, 09:08 PM Thread Starter
Skinnykid19
I think I started WWIII
post #24 of 27 Old 05-02-2013, 09:13 PM Thread Starter
Skinnykid19
So what I'm getting at our of this whole thing is I should just change them and not take a chance. Either way its solves my question and I know I can be safe either way.
post #25 of 27 Old 05-02-2013, 09:15 PM Thread Starter
Skinnykid19
Do I have to take the tcase dropp off will it hurt anything
post #26 of 27 Old 05-03-2013, 08:59 AM
dnuccio
its not helping anything. Take it out
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #27 of 27 Old 05-03-2013, 09:13 AM
PolkaPower
I have read that it can screw with the drive shaft angles. I have never used one or needed one even at 4.5"- 5" of lift. Besides, you are losing ground clearance with it in.
