Zj Lift Help - JeepForum.com
post #1 of 10 Old 05-29-2003, 10:44 PM Thread Starter
REDDOG55
Zj Lift Help
i am getting 4.5 inch coils for the front and doing the switch for a quick 4 in the back..i am adding 2 inch spacers also...what would i need to get besides trac bars? what type of shocks that would fit that lift... also would i need brake lines and steering stabalizer..
If u have any of these parts for sale
REDDOG55 is offline
post #2 of 10 Old 05-30-2003, 10:17 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
If you are adding the pucks to the top you are going to need the adjustable control arms up front to keep the tires from rubbing the rear of the front fenderwells. You will need the adjustable trac bar for front and at least the trac bar bracket for the rear. New brake lines.
If you have the cv front driveshaft, toss that and get a Tom Woods custom for about 200. You'll probably need to regear for the tires.
If you have questions, send them.
Hunter
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #3 of 10 Old 05-30-2003, 12:19 PM Thread Starter
REDDOG55
yea..i am riding on 31's and plan to do so for awhile until money comes..so i prob wouldnt need those arms...they rub now but when u turn all the way..
REDDOG55 is offline
post #4 of 10 Old 05-30-2003, 02:15 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Reddog.
with that much lift your control arms (stock) will have a very steep aggresive angle to them. You are going to feel every bump in the road. They are too short. With that much height, you're going to look like a monster truck on its trailer wheels and tires.
You will need a new steering stab also.
Hunter
04 4.7 HO, limited
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
post #5 of 10 Old 05-30-2003, 03:29 PM Thread Starter
REDDOG55
i know what u are saying about the tires..but i dont have the cash to do that right now..maybe over the summer..but how much are control arms and what exactly do i need..just 4?
REDDOG55 is offline
post #6 of 10 Old 05-31-2003, 06:05 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Okay,
if you don't have the money right now, then wait. Your jeep is too nice and costly to lift it halfway and then regret doing it.
If you are really set on lifting it. Go with a 3.5 kit at first. Then you can add the BB later if you want. *this is the least expensive route.
Or you can wait and save and get something like the RE 4.5 and then go bigger later.
Keep in mind, the short arm kits are reversible. You can take them off if you don't like them. Long arm kits are permanent. They are welded and parts get cut off. You can't revert back to stock.
Hunter
04 4.7 HO, limited
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
post #7 of 10 Old 05-31-2003, 10:20 AM Thread Starter
REDDOG55
i am getting a skyjacker 3" lift with spacers..it comes with reloactaion brackets and arms,shocks,springs...i cant wait
REDDOG55 is offline
post #8 of 10 Old 05-31-2003, 12:58 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Sounds great. Make sure to get some extended front brake lines and extended bumpstops. The brake lines will allow you some crazy flex and the bumpstops will limit the flex to not eat the inside of your front wheel wells. Yes, I've done it and cut the tire from the top of the lug completely through the belts. Not very pretty, but man IT WAS STUFFED>
Hunter
You had better post or send me some pics.
04 4.7 HO, limited
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
post #9 of 10 Old 05-31-2003, 01:35 PM Thread Starter
REDDOG55
hell yea...i cant wait
REDDOG55 is offline
post #10 of 10 Old 05-31-2003, 01:46 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
I've got some pics. Send me your email via pm and i'll send them.
Hunter
04 4.7 HO, limited
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
ZJ Front to rear lift How much lift should i expect? jeep95xj ZJ Grand Cherokee Forum 30 02-08-2015 08:00 PM
BDS 2" Lift vs. Budget Boost lift csi ZJ Grand Cherokee Forum 14 04-20-2009 03:26 PM
iron rock offroad 4.5 premium lift, or rubicon xpress 4.5 lift? jeepheller98 ZJ Grand Cherokee Forum 22 02-08-2009 10:34 PM
lift question. thinking of going bigger and now i am slightly confused about old lift Irish_Assassin ZJ Grand Cherokee Forum 12 01-22-2009 02:17 PM
Max towing with lift/trail blazer lift s2gots ZJ Grand Cherokee Forum 6 11-03-2006 07:00 AM
