ZJ leaking coolant from behind/above crankshaft pulley - Page 2 - JeepForum.com
post #16 of 17 Old 11-15-2013, 11:20 PM
FPKites
ZJjazzyJim
FPKites's Avatar
Good point there.
Replace the steel inlet if you haven't done it in a while, or ever. It's probably warped and pitted.
$13 is what I paid at Napa if I remember correctly.
Jim Karlin
"Duh! Big RED Jeep!!!"
or
96 ZJ Laredo
5" lift, Claytons, KOR radiator support, rear bumper, steering brace, etc, etc, etc.
04 WJ Overland
Clean.... :D
FPKites is offline
post #17 of 17 Old 11-17-2013, 09:32 AM
Gearhead31
Take it from me, that thermostat housing is extremely easy to break.. Just did mine and the lower bolt hole sheared off when torqued down to shy of 20ft-lbs with a felpro gasket. That crap leaks like a sieve btw, just use rtv gasket silicone. 16ft lbs is recommended but wouldnt seal up at that, 20 snapped off the lower bolt hole. A washer has it held together till i get 3 hrs to take apart, replace the parts and let the rtv harden up. I have like 1/8" between the bolt head and belt right now XD
1995 ZJ ltd, 4.0 i6, *cough stock cough* 253,xxx and still pumping strong
1998 Chevy Cheyenne K1500, 5.7L Vortec, mostly stock
*In peace, sons bury their fathers. In war, fathers bury their sons. - Herodotus
Originally Posted by JasonStebbins
We can call it the Whoosh King Catalog System. :D
Gearhead31 is offline
Coolant leak , water pump , water pump failure , zj
