ZJ Latch repair - JeepForum.com
post #1 of 17 Old 02-07-2013, 06:04 PM Thread Starter
TheRealOldjeep
ZJ Latch repair
The 98 I bought for my son had a saggy drivers door that had caused the latch to get damaged and door skin to tear and dent. Couple days ago we took care of the lower hinge pin and bushings so that the door was solid and then ordered a new latch/actuator. I initially planned on welding the crack but then decided that the metal was so thin it would be a waste of time. So a reinforcement plate was in order. Oddly enough, Jeep provides you with one when you replace the latch - you just take the metal off the old one, cut off the tabs and there you go. A perfect plate that already has the countersinks on both sides and fits perfectly.
Chuck P
94 YJ 2.5L/AW4 (Gone)
98 ZJ Limited 5.2 - sons car
97 TJ 2.5L/30RH - daughters car
My site
TheRealOldjeep is offline
post #2 of 17 Old 02-07-2013, 06:51 PM
KoreaZJ
1994 ZJ
Great idea! Much easier than fabbing a new plate.
KoreaZJ is offline
post #3 of 17 Old 04-05-2013, 09:25 PM
gonehuntin817
how much did you pay for that? get it from the dealer or online?
gonehuntin817 is offline
post #4 of 17 Old 04-05-2013, 09:41 PM Thread Starter
TheRealOldjeep
The new latch? Bought it from the dealer, I think it was about $120.
Chuck P
My site
post #5 of 17 Old 04-06-2013, 06:08 PM
BLacher
Any idea if you can just buy the plate?
BLacher is offline
post #6 of 17 Old 04-06-2013, 06:38 PM Thread Starter
TheRealOldjeep
The plate was a piece I cut off the old latch - so no.
Chuck P
My site
post #7 of 17 Old 04-06-2013, 06:57 PM
BLacher
Ha, ha. My bad, didn't read thoroughly, I saw 'Jeep provides you with one when you replace' then didn't catch that it was off old one...
I just put on 3 really thick washers on the outside, had to trim a little bit of one of them, but didn't have new latch so no old plate. Thanks.
BLacher is offline
post #8 of 17 Old 09-05-2013, 11:00 AM
JeepNicholson
Just did this on mine, thanks for the hot tip!
Though I didn't cut the tabs off (mostly because I burnt my Dremel out cutting off the hinge pins and haven't replaced it yet), instead I heated up the plate with a torch and flattened it out with a hammer, it still fit well, and found that it adds room to put a couple self tapping screws in to hold the plate in place so it doesn't move around.
Thanks again, and GREAT idea!
ZJ FSM
https://drive.google.com/folderview?...Fk&usp=sharing
JeepNicholson is offline
post #9 of 17 Old 09-05-2013, 03:12 PM
V65Ozzie
Really great idea.....about 6 months late for me....but still a great idea.
Retreat? Hell, we just got here......
V65Ozzie is offline
post #10 of 17 Old 12-13-2013, 10:28 AM
EastCoast
hey man do you think this will work for me too?
mine looks a lot worse then yours did...
http://www.jeepforum.com/forum/f13/s...at-do-1885273/
EastCoast is offline
post #11 of 17 Old 12-13-2013, 10:33 AM Thread Starter
TheRealOldjeep
I doubt it since there isn't enough metal left there to really keep the plate in place. You could try doing what I did and then weld a couple spots to secure the plate to what is left of the door so that it can't rotate.
Chuck P
My site
post #12 of 17 Old 12-13-2013, 11:03 AM
EastCoast
thanks for the response.
post #13 of 17 Old 12-13-2013, 04:53 PM
Gearhead31
I have the same partial shear at the exact same bolt on mine that the PO used some bondo or something on... Looks like this is in order. Sub'd!
1995 ZJ ltd, 4.0 i6, *cough stock cough* 253,xxx and still pumping strong
1998 Chevy Cheyenne K1500, 5.7L Vortec, mostly stock
*In peace, sons bury their fathers. In war, fathers bury their sons. - Herodotus
Originally Posted by JasonStebbins
We can call it the Whoosh King Catalog System. :D
Gearhead31 is offline
post #14 of 17 Old 12-13-2013, 10:20 PM
BLacher
Go to pick-n-pull and grab a bracket (from inside door latch) as shown above. That should fix problem (if you fix the dor pins causing the sag...May get away with no welding.
BLacher is offline
post #15 of 17 Old 12-15-2013, 09:49 AM
Gearhead31
PO fixed door sag but didn't fix it soon enough and the door was damaged. They did a poor bondo job on it and called it good. It's been on my bucket list of things to fix when I found a good, cheapo way to do it a proper way.
