01-20-2010, 10:11 AM
#1
ZJ Laredo Steering is Loose and Loud
Okay.. So I have a 1994 ZJ Laredo and everything is wonderful. Almost everything that is.. My steering is very very loose. I'll have to turn about 2 inches either way before the wheels actually turn and when I have to make a sharp turn I hear a weird *** noise. It's only when I hav to make that sharp turn or turn my tires to the left or right when I'm at a stand-still.
Any suggestions?
4.5 RE Suspension Lift
32 inch Tires
15x8 Wheels
1 inch Body Lift
01-20-2010, 11:00 AM
#2
01-20-2010, 11:14 AM
#3
^thats what I wanna know!
-Jesse-
GO DUCKS!
www.facebook.com/jesse.whitehargrove
01-20-2010, 11:16 AM
#4
Probably worn draglink or TRE's.
1995 ZJ 2" BB, 31x10.50/15 KM2's painted stockers, B&M RV shift kit, 18k cooler, Extended Energy sway bar links.
01-20-2010, 11:34 AM
#5
Resident Audio Guru
You have severely worn steering components ... Start at the firewall and check the lower steering shaft, then the steering box (lower shaft moves, but pitman arm does not means excessive play in the steering box), then from there your drag link and the ends of the drag link.
-Matt
White '94 YJ Sport
Black '98 ZJ Laredo - 45x60 Surco Rack - 2" Budget Boost, Addco Front Swaybar
Project (s)Low - A build log.
01-20-2010, 01:24 PM
#6
My xj was like this, it was terrible. I could steer with 1 finger.
01-20-2010, 01:28 PM
#7
Had this issue. Changed some tie rod ends and it ended up being the steering box just being old and worn out. So I changed that and a leaking power steering pump and BAM tight.... body lift? how did you possibly do that?
01-20-2010, 01:33 PM
#8
Surprised you don't have DW. My steering turned out to be a bad upper TRE.
'93 ZJ, 4.0L, D30 & D35, NP231, 4" Lift, 31" BFG's, Soft 8's, Painted Cladding, Glasspack, JVC Deck, CB, Lightbars, JKS Discos & TB, Tow Hooks Everywhere...more crap.
01-21-2010, 10:02 AM
#9
I honestly have no idea with the body lift. I didn't ask my mechanic. He knows his ****. He made it happen. I just told him what I wanted and he fabricated something for me. It works so I'm not gonna complain.
01-21-2010, 10:07 AM
#10
Well for future reference, your mechanic doesn't know everything. I'd second guess how much he knows if he says you have a 1" body lift.
01-21-2010, 10:12 AM
#11
^^understandable on your end...but if you hav a mechanic that sells you a body lift for a uni-body vehicle i'd jump ship before he sales you a new diode for your door handle !!!
01-21-2010, 10:20 AM
#12
A body lift is impossible on a unibody such as your grand cherokee. I hope it didn't cost you much. The frame is part of the body and can not be separated to install said lift. Do you mean spacers on top of the coil springs ?
95' Jeep Grand Cherokee Laredo, 148k, 5.2, NP242, 46RH, 4" RC lift, all new adjustable ca's(2 IRO front uppers and the rest RC adjustables), nitro shocks, JKS TB's, Jet Chip, Dynamax cat back, Magnaflow cat, GTP hood vents. 31" Pro Comps with Rock Krawler "D"s. Westin brush/grill guard with Hella 500s, 411's, Solid diff covers, detroit locker rear, power lock in front, SYE and Tom Wood's front/rear shafts, RE discos, BPE's, d-rings front and back, factory tc and rad skid, hitch, Sliders next.
03' Jeep Grand Cherokee Laredo, (wifes Jeep) 99k, 4.7 5 speed auto, K&N, KYB shocks, drilled-slotted rotors, All the toys.
2000' Ford Superduty, F250, 7.3, 198K, 37's, too much to list.
Built Not Bought #257
Parts for sale d30 and d35 parts http://www.jeepforum.com/forum/f126/...-parts-1004499
01-21-2010, 10:38 AM
#13
Resident Audio Guru
Your rig should be in a 4x4 magazine as an engineering marvel if he made a 1" body lift for a Grand Cherokee.
-Matt
White '94 YJ Sport
01-21-2010, 11:03 AM
#14
Mr. Hyde!
Moving on from the "body lift" folks
Az-Green what did you find when someone turned the wheel back and forth while you examined the steering box, shaft, pitman arm, drag link (ends), and tie rod (ends)?
01-21-2010, 07:50 PM
#15
Okay. Correction. Chase (me) is an idiot. I called my mechanic up and it was 1 inch spacers which he just gave to me since my family is always in the shop having stuff done to my dad's truck. Not a body lift. Sorry for the wrong info and such.
Now for the steering issue; it was the steering box. It's toast.
Any suggestions for a new one? I was thinking about an AGR steering box for the ZJ (onviously). Since this is also my daily driver I don't wanna drop the $$ for a super heavy duty steering box.
