#1 | |
ZJ KOR Radiator Support
Well I'm going to be replacing my radiator with a metal 3-row one and would think it may be a good idea to put in a KOR radiator support while it's out. I'm curious on what the major benefit of this? It simply has a stronger bottom brace and does it cover the bottom of the radiator's open area? Are the tow hook mounting points that much stronger than the factory locations?
[FONT="Impact"][SIZE="3"]1997 5.2L [COLOR="Red"]ZJ[/COLOR] [COLOR="DimGray"]Limited[/COLOR][/SIZE][/FONT] [URL="http://www.norcal4x4forum.com"]Norcal 4x4 Forum[/URL] | [URL="http://www.fquick.com/RrCoX22"]My Garage[/URL] |
#2 |
it just braces the bottom of the radiator. doesnt restrict any flow. the benefits are protects the bottom of your radiator and it gives you 2 solid front tow points. KOR rated at 65k lbs and factory are 55k lbs
1993 Jeep ZJ. 4.0 |
#3 |
more ground clearance and approach angle
#4 |
this is with the bumper off right? i mean the stock bumper sits lower than the radiator
#5 |
Headed Out West
Or trimmed ... yes
Jeff |
#6 |
anyone know if this will fit with the ARB bumper? or does notching have to come into play?
#7 |
Living dead mod
will need modded to work with an arb.
'97 zj 5.2, some stuff, some other suff, and some things that even work sometimes. |
#8 |
greengc4x4 has a couple good pics showing what to trim here: (post 88)
http://www.jeepforum.com/forum/f197/my-zj-currently-691932/index6.html
'97 ZJ '92 Wrangler Renegade- SOLD! 1987 Monte Carlo Aerocoupe- (My on-road baby) 305 HO Factory T-tops 2005 Chevy Silverado Duramax/Allison- Daily Driver |
#9 |
Bringing an old thread back just because I have related question. Will the KOR support work with the new Iceland Offroad fiberglass bumpers? Been thinking of getting one of those in time, but this looks like a good current upgrade. I wonder if you can install this without having to pull the plastic bumper cover off. That'd be a pain in the you know what, especially if I'll have to pull it again when I can afford the Iceland bumper. Don't really like the cover-free look, but it might be what I do if I have to. Bleh. Plastic is just bad. You can remove steel and replace it, but plastic always ends up cracking, bending, breaking, snapping on me. I hate removing anything plastic. I just can see the little plastic retention snaps all breaking so it doesn't reinstall right. Can you get those anywhere aftermarket?
#10 |
ya... you need to take the bumper off. believe your will have to play around with any bumper that will be using KOR radiator support behind it
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
