ZJ Jeep radio install help/issue - JeepForum.com
post #1 of 3 Old 07-09-2010, 11:55 AM Thread Starter
TonyMontana
Well today I was installing a radio in my Jeep. It was all good until I noticed there was a wire loose. I fixed it and the damn heat peeled off the tape. Well sadly, the exposed wire hit the frame of the radio which caused it to spark. So now I have no Module/Vehicle Information Center and I have no radio. Along with no power door locks. Also I noticed when I put the car in the "ON" position it doesn't have full 12 volts. But it still has sufficient energy to start the car up. My question is do I replace a fuse or do I replace the battery. Also, which fuse should I replace? I noticed I had fuses in the passenger panel and the engine compartment. The reason I say fuse is because some of my electronics are acting funny. The ding disappeared and it makes a weird ticking noise instead of the ding when I have the doors open.
All help is appreciated. Thank you!
TonyMontana is offline
post #2 of 3 Old 07-09-2010, 12:31 PM Thread Starter
TonyMontana
Never mind. I found it was the fuse.
post #3 of 3 Old 07-09-2010, 12:48 PM
-Joe-
-Joe-'s Avatar
Heatshrink tubing.
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline
zj , grand cherokee , radio , install , electric , problem , issue
radio issue in a 94 GCL 5.2L BreckJeep ZJ Grand Cherokee Forum 16 01-15-2012 10:46 AM
1995 Grand Cherokee Laredo Radio Issue JepJeep ZJ Grand Cherokee Forum 0 03-09-2010 09:06 AM
94 gc limited radio issue/steering issue? r34civic ZJ Grand Cherokee Forum 7 01-04-2010 06:00 PM
Electrical issue with Shifter/Radio sledgehammer199 WK Grand Cherokee & XK Commander Forum 1 10-28-2009 01:23 PM
Wierd Radio issue impuresoul2k3 ZJ Grand Cherokee Forum 7 03-27-2007 11:02 PM
