zj- Interior lights will not turn off - JeepForum.com
post #1 of 14 Old 06-23-2009, 07:06 PM Thread Starter
Fireball027
Hey everyone. I have another problem with my 96 grand cherokee. I recently found out that the reason my interior lights would not work was because the previous owner pulled the relay/fuse. I replaced it but now the interior lights will not shut off. All the doors are shut (the vic shows the doors shut as they all light up, except the hatch when open) and still the lights will not turn off. However if you put the key in and turn it they will then shut off, but thats the only time. I have no idea where to start or what to look for. Also the light in the hatch will not turn them off either if I push the button.
If anyone can help or has any ideas please let me know.
Thanks for the help
Shawn
Fireball027 is offline
post #2 of 14 Old 06-23-2009, 07:25 PM
Mickey_D
I'm too tired right now to go hunt it down, but in the FSM it says that the interior lights are controlled from the Body Control Module. I think it sends a signal out to a master control relay for the lighting.
Once I take a nap I'll look it up for you.
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
#4
Mickey_D is offline
post #3 of 14 Old 06-24-2009, 09:34 AM
ZJTechie
I had that exact problem for several months, which meant the easy fix was to remove the fuse as well. The fix I found was that there is a redundant switch system in the doors that makes the lights turn on when you turn the key in the lock. I simply disconnected the switches that are connected directly to the lock cylinders in the doors. The lights will still come on when you open the doors mind you, so disco'ing the lock switches won't affect anything badly. Also, that hatch button is really useful to check to see if your lights can turn off, by switching that over a few times, if the lights won't turn off, there is a problem still! Otherwise one click will turn them on all the time, and the other click will turn them off assuming the doors are all shut good.
ZJTechie,
My current JEEP score: 205 (see site below)
ZJTechie is offline
post #4 of 14 Old 06-24-2009, 09:42 AM
97DCZJ
ZJtechie, i had ur first original problem where the previous owner removed the relay/fuse, but i dont see any missing in my box. my interior lights never turn on when i open any of the doors. i have the same year, which means we have the same fuse box. which fuse/relay did u replace?
1997 Grand Cherokee Orvis: V8 5.2L, stock.
(Sold) 1998 Cherokee Sport: 4.0L I6, Stock.
(Sold) 1990 Cherokee: 4.0L I6, 4.5" Lift, 33" BFG's.
(Sold) 1997 Grand Cherokee Limited: V8 5.2L, 2" BB, 31" Dick Cepeks.
(Sold) 1999 Grand Cherokee Laredo:
; V8 4.7L, Stock.
(Sold) 1996 Grand Cherokee Laredo:
; V8 5.2L ,3.5" lift, 32" Tires
97DCZJ is offline
post #5 of 14 Old 06-24-2009, 10:20 AM
StellaTheZJ
Hey, there's a very simple cause for this. The switches on each door are self adjusting. If you close the door on the sealtbelt, or your coat, or whatever, it pushes the switch too far into the body, and the lights won't go off. This should also trigger the "door ajar" chime and light up the door on your VIC (if you have a VIC). That will tell you which door switch it is.
To fix it, get a tiny screwdriver or a thin blade to ease behind the button head of the switch. The head is actually held in place just with friction, so if you gently the head away from the switch, it should extend a ways. To "reset" to the proper length, simply close the door!
Why not spend the 5 minutes to do this to all 4 doors, just to be sure they're OK?
StellaTheZJ is offline
post #6 of 14 Old 06-24-2009, 10:31 AM
97DCZJ
as quoted by techie "(the vic shows the doors shut as they all light up, except the hatch when open)"
thats why stella
; V8 4.7L, Stock.
97DCZJ is offline
post #7 of 14 Old 06-24-2009, 10:34 AM Thread Starter
Fireball027
All the doors on the vic show they are shut, and the lights will only turn off if you turn the key forward in the ignition. Also should the vic light up if the hatch is open?
post #8 of 14 Old 06-24-2009, 10:54 AM
Marcos
The "redundant" switches on the door lock cylinders are the disarm switches for the alarm function. They also signal the BCM to turn on the lights via a relay (the door jamb switches mentioned elsewhere turn them on directly by providing a ground, so they wouldn't shut off when you turn on the ignition.
Some people have issues with the alarm going off by itself, so they bypass it by grounding the disarm wire (Violet w/ yellow tracer). This often results in the interior lights remaining on (some people claim it doesn't do that for them). They then "fix" this by pulling the courtesy light relay or fuse.
The disarm switches are only present on models with the theft alarm. Look at the body controller connectors for the Violet/Yellow wire. Pull that connector and check that wire to see if it is permanently grounded. It should ONLY have ground if the key is in one of the door locks and turned to unlock.
Marcos is offline
post #9 of 14 Old 06-24-2009, 11:37 AM
ZJTechie
Wow, I didn't know those "redundant" switches were for the alarm, I may be able to fix my problem better than simply removing the switch, thanks for that. By the way, the only fuse I found removed was the passenger side kick panel one for the cabin lights, though you may want to check to make sure it isn't burned out.
ZJTechie,
ZJTechie is offline
post #10 of 14 Old 06-24-2009, 11:32 PM
wightkliff
I had same prob when I bought my 97 zj.. got it cheap cause of it. I honeslty spent two days messing with it, then opened all the doors, locked them with the remote, and manually pushed the lock "slide switch" to the max locked position all the plastic could handle. Then I shut the doors, and the alarm armed, and lights went out. Seems like the switch needed a reminder or something. Previous owner killed three batteries cause he was to lazy to pull the 2 fuses... Haven't had a problem with it since.
wightkliff is offline
post #11 of 14 Old 05-19-2012, 11:30 AM
58dodge
1997 FSJ Cherokee
i have a 1997 cherokee jeep were is the relay fuse for the interior lights as mine ant working.
58dodge is offline
post #12 of 14 Old 05-19-2012, 12:49 PM
Bigdjs123
Stupid question but what/where is the slide switch?
Bigdjs123 is offline
post #13 of 14 Old 05-19-2012, 12:57 PM
dusterdude
Its the sliding interior door lock on the door
dusterdude is offline
post #14 of 14 Old 05-19-2012, 02:16 PM
Bigdjs123
Oh lol ok I feel like a genius
Disabled alarm and now the interior lights won't turn off. agentp5 ZJ Grand Cherokee Forum 8 01-28-2011 08:21 AM
Interior Lights Turn ON by themselves when moving sato ZJ Grand Cherokee Forum 5 02-03-2009 11:45 AM
WJ interior lights don't always turn on in cold weather? Windowsrookie ZJ Grand Cherokee Forum 6 12-22-2008 07:49 PM
interior lights wont turn off yborghunter ZJ Grand Cherokee Forum 1 08-13-2007 11:51 AM
All Interior lights Flash with Turn Signal jgedwards3 ZJ Grand Cherokee Forum 4 03-31-2007 10:50 PM
