ZJ idling rough - JeepForum.com
post #1 of 10 Old 06-03-2013, 05:46 PM Thread Starter
TKFlight
ZJ idling rough
As the title states my jeep is idling rough when at a red light, etc, I'm assuming its nothing serious since my jeep drives fine. I was thinking maybe it was the throttle body needing to be cleaned. Any other info would be appreciated.
TKFlight is offline
post #2 of 10 Old 06-03-2013, 06:32 PM
picflight
It could also be a fuel delivery system that's faulty.
picflight is offline
post #3 of 10 Old 06-03-2013, 09:01 PM
JasonStebbins
Clean the throttle body and the IAC. It's a little spindle on the back of the throttle body held in by two torx bolts. Take it out and clean it, but don't push it in/out while you are cleaning it.
Report back.
Poop
JasonStebbins is offline
post #4 of 10 Old 06-03-2013, 09:07 PM Thread Starter
TKFlight
Just need to go out and get throttle body cleaner now, and I'll check the IAC while I'm at it. Will report back when its done
1995 Jeep Grand Cherokee Laredo 4.0L
251K+ miles
TKFlight is offline
post #5 of 10 Old 06-03-2013, 09:10 PM
WhiteOut
WhiteOut's Avatar
Report back.
This. It's a T25 torx
WhiteOut is offline
post #6 of 10 Old 06-03-2013, 09:50 PM
Oldfrog
2007 WK
After cleaning the throttle body and IAC, go ahead and pop the distr. cap open too. Clean and inspect it. Lift the plate inside ( cam sensor) and clean under it. Then pour a 1/3 can of Seafoam in your gas tank.
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #7 of 10 Old 06-04-2013, 10:06 AM
L_Kilkenny
Check your vacuum lines..............
I do it by spraying carb cleaner around every hose and fitting. You'll hear the change pretty quick when you hit the leak.
L_Kilkenny is offline
post #8 of 10 Old 06-04-2013, 04:56 PM Thread Starter
TKFlight
Thanks for the replies guys. I was doing some research on here and found out that there are no MAF sensors on Jeeps(laugh at me if you want)
http://www.jeepforum.com/forum/f310/maf-sensor-1084165/
I got a picture of my throttle body, and is the IAC the part to side with a power connector going to it?
http://i.imgur.com/e2AsiYK.jpg
TKFlight is offline
post #9 of 10 Old 06-04-2013, 06:36 PM
JasonStebbins
The IAC is North in your picture. The sensor North East is the TPS. (Throttle Position Sensor)
Poop
post #10 of 10 Old 06-04-2013, 10:05 PM
dnuccio
my 5.2 was idling rough so i took the throttle body off, took off all the sensors, and cleaned it really well. also cleaned the IAC. runs much better and smoother
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
