-   -   ZJ idling rough (http://www.jeepforum.com/forum/f13/zj-idling-rough-1531945/)
TKFlight 06-03-2013 05:46 PM
ZJ idling rough
As the title states my jeep is idling rough when at a red light, etc, I'm assuming its nothing serious since my jeep drives fine. I was thinking maybe it was the throttle body needing to be cleaned. Any other info would be appreciated.
picflight 06-03-2013 06:32 PM
9 Attachment(s)
It could also be a fuel delivery system that's faulty.
JasonStebbins 06-03-2013 09:01 PM
Clean the throttle body and the IAC. It's a little spindle on the back of the throttle body held in by two torx bolts. Take it out and clean it, but don't push it in/out while you are cleaning it.
Report back.
TKFlight 06-03-2013 09:07 PM
Just need to go out and get throttle body cleaner now, and I'll check the IAC while I'm at it. Will report back when its done
WhiteOut 06-03-2013 09:10 PM
Report back.
This. It's a T25 torx
Oldfrog 06-03-2013 09:50 PM
After cleaning the throttle body and IAC, go ahead and pop the distr. cap open too. Clean and inspect it. Lift the plate inside ( cam sensor) and clean under it. Then pour a 1/3 can of Seafoam in your gas tank.
L_Kilkenny 06-04-2013 10:06 AM
Check your vacuum lines..............
I do it by spraying carb cleaner around every hose and fitting. You'll hear the change pretty quick when you hit the leak.
TKFlight 06-04-2013 04:56 PM
Thanks for the replies guys. I was doing some research on here and found out that there are no MAF sensors on Jeeps(laugh at me if you want)
http://www.jeepforum.com/forum/f310/maf-sensor-1084165/
I got a picture of my throttle body, and is the IAC the part to side with a power connector going to it?
http://i.imgur.com/e2AsiYK.jpg
JasonStebbins 06-04-2013 06:36 PM
The IAC is North in your picture. The sensor North East is the TPS. (Throttle Position Sensor)
:D
dnuccio 06-04-2013 10:05 PM
my 5.2 was idling rough so i took the throttle body off, took off all the sensors, and cleaned it really well. also cleaned the IAC. runs much better and smoother
The time now is 03:47 AM.
